Monterey
Salinas Ca
I have a Ford f450 with a motorhome body on it. The rear springs {the single leaf overload ones} squeak when they contact the stops. I have greased them but that only works for a short time. Any suggestion
edited 05/16/04 05:58pm by an administrator/moderator *
dontay
Mims, Florida
AirLift or RideRites. The F450 gives a comfortable ride but camper weight does make the contact between overloads and the stops. Only solution I have found is the same as on my old F350 and that is AirLifts. But I didn't add AirLift for the squeek I did it to improve what felt like mushy steering and to improve the height of my trailer hitch on the end of a 3' extention bar.
ISO9000 Certified Retiree
Mission Statement: ZZZzzzzzzzzz....
2006 Allegro Bay 34XB with Freightliner FRED chassis, 2000 Jeep Cherokee 4x4
http://community.webshots.com/user/longf450
FHOVEY32
Taunton,Ma.
Take a raidator hose slide it over the helper spring and cut the excess off. this should stop the noise.
Fred Hovestadt DAD
Layne Allen-Hovestadt MOM HYPHEN a modern day woman (THE BOSS)
Joe Handicaped brother (Downs Syndrome & blind) 49
David FOSTER SON (Downs Syndrome) 21
Frankie SON 16
Patrik SON 13
2003 Yamaha V-Star Silverado 1100
1999 Chevy Silverado Ext. cab 4X4 Z71
1985 Winnabago Elandan MH
2002 Keystone Ssprinter BH w/so
Big Bruce
Anthony Fl.
A shot of silicon spray every once in a while stops mine from squeaking.
Big Bruce
2006 Dodge, Dually, CTD, Quad Cab, 4 X 4, Automatic/ 2006 31' Cougar F/W
Hauling (1) 2009 Harley Heritage Classic and (1) 2009 Softail Deluxe.
Or Gone Fishing - 17' Carolina Skiff with Yamaha 75Hp 4 Stroke.
MR SERIOUS
COBBLE HILL B.C. CANADA
I to have sqeeky springs but i noticed with the camper on the extra springs are barely weighted and this causes the rubber blocks to rub and squeek.I put graphite lubricant on and it helps alot but you must remember to do it often.The rad hose sounds simple but what if you mounted rubber blocks on the top of the springs and when the touched it would be rubber to rubber.My two cents worth
Regards
Steve
2008 F450 LARIET LONG BOX DUALLY
2008 SIERRA 316BHT
WIFE TWO YOUTHS
3 CATS NOW WHEW?
180 CAMPION ALLANTE
20 FT TOY HAULER
RVER's for life
TekLead
San Diego, CA, USA
I had a similar noise with my Lance 1120 loaded on my 2000 F-350 SRW(camper package, overload springs, etc). A pair of Firestone Ride Rites quieted it right down.
-- TekLead
____________________________________________
2000 Ford F350 4x4 SRW V10, Ranchos, Air Lifts
2000 Lance 1120, Air, Gen, Sat, etc.
