tllstaco
Pearland, TX
The poles on my Jayco's awning are horrible. The ends pop out on the tension rods and the vertical poles. Anyone out there have a solution? I tried recrimping the metal, but it didn't work.
Right now I can't afford a Carefree of Colorado awning so I need to make due.
The Lovells
2008 Jayco Baja 10Y
2002 Toyota Tacoma 4x4 Double Cab
2006 Toyota RAV4
Biznaga
Arizona
Looks like they should be under warranty since you have 2004 model. take'm back to the dealer.
Of course if you bought from my dealer it will take some doing to get them to do anything.
Also contact JAYCO directly. That has helped me most.
TV: 2004 Explorer Sport Trac
Home away from home: 2003 Jayco Eagle 10UD
Never try to teach a pig to sing. It wastes your time and annoys the hell out of the pig.
tglazier
Hillsboro Oregon, USA
It very much sounds like a warranty issue. My 2003 Jayco probably has the same awning poles as yours and I have not had any problems. As a matter of fact, when I hear (on this forum) of people having problems with their awnings I consider myself lucky since I have been very satisfied with my awning.
Good Luck....
Tim
Retired USAF living in the Pacific NW USA
Jayco 17C Ex-Port Hybrid
2005 Jeep Liberty 3.7L
Krazyjohnny
McKinney, Texas, USA
These are some of the reasons I went ahead with the Carefree Supersport from the start. I would certainly think it would dbe a warranty issue.
john
Krazy Johnny
2000 PSD Crew Cab with Predator Tuner
Air Lift Air bags
07'Airstream 27'FB Safari LS SE
Superwoman for a wife, supercool son, Me...I'm just Krazy
Krazyjohnny
tllovell,
who was your dealer? I bough my Jayco from a Houston dealer. just wondering if they may be the same?
john
tllstaco
Pearland, TX
Krazyjohnny,
We bought it from Lone Star RV on the Gulf Freeway and the Beltway. I picked up a new awning yesterday, but I would like to prevent this from happening again.
Lone Star has been VERY good about warranty issues.
edited 11/03/04 07:10am by an administrator/moderator *
tllstaco
Pearland, TX
Biznaga,
Thanks for the advice. I picked up the new awning yesterday and have already put it on. I'm just trying to prevent the same thing from happening again.
I wrote Jayco and email yesterday. I'll reply here with what they say.
edited 11/03/04 07:11am by an administrator/moderator *
Mtn Traveler
Toby and Rita,
I sent you a message with instructions on how I resolved this (too long to post here). Some PVC fittings and less than an hour of fab work and they work wonderfully. This mod makes it a breeze for even one person to setup the awning. Let me know if you have any questions. Someday I'll take a picture of them.
'89 Jeep Wrangler
'99 Jayco 10UD
jnoflane2
Falcon, Colorado
Toby,
I had the exact same challenge. After the first end popped out, I changed the way I was setting up the awning and the other two never loosened. I realized that when I was setting up the awning, I would stress the ends when pulling against the poles that were spring loaded. Instead of pulling on the upright poles, pull on the spring loaded poles.
Another option that I was going to consider was welding the ends in place. I recently purchased one of those little wire welders and I had the option of buying aluminum welding wire. I am sure that you could take the poles to a local welder and have them welded or brazed on for a nominal fee. I would think that would be a permanent fix.
Thanks, John
2007 Toyota 4-Runner, 4x4, 4.0 L
Shopping for next Towable....Spring of 2009!
2004 Timberlodge 27 DB, 30'6" (Sold)
2001 Jayco 10V PopUp (Sold)
2007 Suzuki DL650 V-Strom
Krazyjohnny
Tllovell,
That is good to hear about Lonestar. I bought my trailer from them as well. I dealt with Earl Marquis there at the South (Gulf Freeway) store. I drove all the way from McKinney (288mi) to deal with them. I wish Earl had not been so greedy for the sale though. The norht store would have saved me about an hour of travel time each way and I could have stayed at a friends house instead of a motel.
John
