Woodalls Open Roads Forum: Tow Vehicles: 1999 F150 4x4 Rear Ratio
Search only in Tow Vehicles
 > 1999 F150 4x4 Rear Ratio
P40Nut
Harleysville, PA
Posted: 11/12/04 06:44pm Link  |  Print  |  Notify Moderator
I'm trying to finalize the towing, (Ease Of),capabilities of my 5.4L V8 F150. I have read some comments on this forum about rear ratios effecting the pulling of a TT or 5er on long grades. Is there a website I can go to that I can find what the rear code on the door sticker means? Or, do I have to contact a Ford dealer's service department to find out? I have the factory tow package but I don't know if that includes a 3:55 OR 3:73 Rear.
1999 Ford F150SCAB HD 4X4 5.4L
Fiver in future
Just Retired ...Wife Not.
VP-48 USN 1960-1966
2 Sons-ARMY AIRBOURNE 89-98
SUPPORT OUR TROOPS !!!
BenK
SF BayArea
Posted: 11/12/04 06:48pm Link  |  Print  |  Notify Moderator
If used, the previous owner could have changed the gear set, so whatever the VIN/Codes/etc say could be wrong.
Easiest is to tape a length of string to the drive shaft. Mark a datum point, best pointing straight down.
Roll the vehicle one tire rev using the valve stem as the datum.
Then count the number of full turns of string, which will be the first number of the diff ratio.
Any fraction of a whole turn is the second half of the ratio.
-Ben Picture of my rig
Posted: 11/12/04 06:51pm Link  |  Print  |  Notify Moderator
Fords tow package does not include any special gearing. It can be ordered with any available ratio. I doubt that you have the 3.73 unless your F-150 is a HD model 7700 GVWR. It could be 3.55 or 3.31 with 3.55 being most likely. A call to your dealer with the VIN would tell you what the truck was delivered with but like Ben says, is someone changed it you may need to figure it out. Sometimes they stamp the ratio on the bell housing also. Good luck / Skip
2004 F-250 SCREW Long Bed 20,000 towing miles (MANY REPAIRS)
OR 2004 F-150 HD 85,000 towing miles (No repairs)
Iwannacamp
near Ft. Wayne, IN
Posted: 11/13/04 12:36am Link  |  Print  |  Notify Moderator
Try looking for a metal tab affixed to the rear end housing. It should be on the passenger side of the housing, attached with one of the bolts. That tab will have the ratio on it. If BenK is correct in your situation, then the string method he suggests will be your next step.
2005 Flagstaff 831BHSS
2001 F-150 4X4 5.4L 3.73 Lariat SuperCab 7700
U.S.S. Guam(LPH-9)1984-1987 MS3
1 Wife for 21 years
1 Son for 4 years
2 Sons for 20 years
2 Sons and a Daughter for 9 years
Australian Shepperd Mix for 6 years
SpellCheck by IESpell
P40Nut
Harleysville, PA
Posted: 11/13/04 10:03am Link  |  Print  |  Notify Moderator
Seems one of my sons has done the research of rear ratio's for me. He has a F150 SuperCrew 4X4 and his rear axle code on the door is "H9". This happens to be the same code on my door label. It's a 3:55 Limited Slip. Which means my max towing is 7700 lbs. However I think staying below 7000 lbs will be better on the truck.
I've found many new/used 5er's with a dry weight in the high 5K's to low 6K's but the hitch weights seem to be over the max weight I can load onto the bed. Need to solve this problem yet.
By the way ... Rear ratios for Ford trucks can be found at ... F150online.com. Go to search and type Axle Ratio's.
Thanks ... BenK ... SkipNChar ... And Iwannacamp for your valuable advice. I was under the truck looking at the label when my son pulled up the drive in his truck.
MitchF150
NW
Posted: 11/13/04 10:21am Link  |  Print  |  Notify Moderator
Look at the AXLE code on the door jamb sticker.
H9 — 3.55 limited slip
B6 — 3.73 limited slip
If there is a number for the first character, then it's the same ratio, just does NOT have LS.
If a 5'er is in your future, it'll have to be kinda light.... You've only got about a #1000 payload before you exceed your trucks GVWR....
Good luck!
Mitch
1997 F150 XLT, 4x4, SuperCab, ShortBox, 5.4, 3.55 gears, Prodigy, EAZ-Lift WD hitch, Autometer Water/Trans temp gauges, 200,000 miles (GVWR #6250 GCWR #12500)
2003 Prowler Lynx 722F (GVWR #5000)
P40Nut
Harleysville, PA
Posted: 11/13/04 10:48am Link  |  Print  |  Notify Moderator
There's the RUB! Most 5er's in the 25 to 26' range have hitch weights about 1000 to 1200 lbs. Got to find a way to increase load carrying capability without endangering towing safety.
