Woodalls Open Roads Forum: Fifth-Wheels: Cedar Creek Owners
Search only in Fifth-Wheels
 > Cedar Creek Owners
petfamily5
Trabuco Canyon, CA, USA
Posted: 02/16/05 05:31pm Link  |  Print  |  Notify Moderator
We just picked up our new Cedar Creek fifth wheel and was wondering if we need to use a water pressure regulator when we hook up to city
water. We used to have a cab over camper and it required that we
use a water pressure regulator. When we hooked up our new Cedar Creek we used the water pressure regulator, but the water pressure in the unit was so low that you could hardly take a shower. I attached the water pressure regulator to the park connection prior to attaching our water hose, which I then connected to the trailer.
After we got back home and started looking through all of the manuals we got with the trailer it said nothing about having to use
a water pressure regulator. Does this mean that the trailer already has on built in or I don't need to use one or ????
David
sch911
Rochester Hills, MI
Posted: 02/16/05 05:52pm Link  |  Print  |  Notify Moderator
Ours does not. I do use and external regulator. Your CC has a water filtration system on it. That system does cause a little extra pressure drop which reduces flow.
Chrysler Systems Engineer (Thermal Systems)
2003 Damon Challenger 348 Class A - F53 Triton V10
Posted by Macintosh
JTMO
Novato, CA
Posted: 02/16/05 05:58pm Link  |  Print  |  Notify Moderator
The regulator is there only to prevent over pressurizing and popping a line.
You can add more pressure by also using the water pump.
For a better shower, switch the inside/outside heads. The outside one is better, and you can take out the restrictor if you always use hookups. Much better.
When you fill with fresh, make sure the overflow valve under the trailer is open or you can pop the fresh tank. Best is to reroute the overflow to the small screen vent at the inlet. You can do, or the dealer. Bad design as is, one member blew the tank and broke the floor.
Cedar Creek 27LRLS 7359 dry with extensive options/7700+ loaded.
2003 Expedition 5.4 FX4 with factory Tow 3.73 Bilstein shocks. GCVWR 14500, Tow rating with no cargo 8650
Equalizer Hitch, Prodigy, Barker Electric jack. Coachnet ERS
Rallies=14
My travel albums
patsplace
Lake Conroe, Texas USA
Posted: 02/16/05 06:00pm Link  |  Print  |  Notify Moderator
I also have a new Cedar Creek 5th wheel which we put into service on 12-08-04
We experienced the same thing that you have. I have always used a pressure regulator. But have not been able to with my unit.
The water filter is the culprit. As long as that thing is in the unit, a
pressure regulator will be "overkill". So far, I have experienced no adverse consequences by not using the regulator. We are full-timers,
so we have been "connected" since 12-08-04.
I called the factory and they told me that frequently an air pocket
is caused by incorrect installation of the filter. If the technician
does not fill the water canister before inserting the filter, an "airlock" is created.
I don't buy into that, after 2-1/2 months. Air would have "gone away" by then. I think it's just that the water filter system
dampens the water pressure enough to cause the water pressure regulator to operate in "overkill mode".
That's my opinion! Hope this helps!
Enjoy,
Pat
2004-Dodge-3500-SLT-4x4 Long Bed-325/600
Reese-16K-Dual Pivot Hitch
2005-Cedar Creek-36 RLTS-Standard
Wife-Sheila and Killer Guard Dog-Duffy-Cairn Terrier (thinks he's a Gorilla)
Full-Timers-2nd time around
bluenote
Michigan
Posted: 02/16/05 06:11pm Link  |  Print  |  Notify Moderator
The Forest River water filter only flows at 2.5 gpm. I bought similar filters from Wally World which still fit the canister fine (can't remember which brand) and they flow 5.0 gpm. They also have similar filtration properties and micron ratings. Water pressure was fine after doing this, even with our pressure regulator hooked up outside.
2001 Silverado 2500HD LS CC/SB Duramax/Allison Indigo Blue
2004 Cedar Creek 31LBHBS 5er
Our Team
Rallies Attended: 3½
whistlebritches
Cherryvale, KS
Posted: 02/16/05 06:29pm Link  |  Print  |  Notify Moderator
To JTMO, we just took delivery of our new Cedar Creek, but haven't been able to use it yet, as it is winter here in Kansas! Curious about the overflow valve thing when filling the fresh water tank. When we did our walk-through of the 5th wheel, he didn't mention this to us, so we don't have a clue where this valve is.
JTMO
Novato, CA
Posted: 02/16/05 10:11pm Link  |  Print  |  Notify Moderator
1. I have had the filter out (used several times in winter) after de-winterizing and it really mad no difference.
2. The valve is next to the fresh water drain under the unit. One is clear white, drain, the other is meshed, overflow. Each unit is defferent though. And maybe we can hope that Cedar Creek has re-thought the overflow problem. The original had no valve, that allowed contamination and siphoning, then the valve. But that caused problems with tight fitting hoses in the inlet.
leadsled
Lindale, TX USA
Posted: 02/16/05 10:18pm Link  |  Print  |  Notify Moderator
I don't use one with mine. I have had my unit in service for more than a year now.
Leadsled
'07 Dodge 6.7ltr 6spd auto 4x4 3500 quad cab DRW ;B&W Hitch & 5th;Jordan brake control
"Silver Streak"
'08 Keystone Challenger 35CKQ
Sinemaster 3500Ti inverter generator
Work Hard! Play Harder!
cjtinkle
The Ozarks
Posted: 02/17/05 04:05am Link  |  Print  |  Notify Moderator
We bought one to use with ours, but like you had no water pressure with it on, so we don't use one either. Fulltimers here.
Have you "Tinkled" today?
WE5NACREEK
Virginia
Posted: 02/17/05 08:51am Link  |  Print  |  Notify Moderator
We use our water pressure regulator 99% of the time. Some campgrounds have higher pressure than others and the current capacity load on the campground's system can be a factor. I have had a couple of my previous RV's spring leaks (particularlly under the kitchen sink) due to high water pressure and not using the regulator. We find it's just not worth risk with our current baby.
Sheila, Tom,
2 Kids (boy 14 and girl 9)
1 Skinny Shiba Inu dog 10 years
1 Chocolate Labrador Pup 5 years
1 Long Hair Chihuahua 3 years
2006 Chevy 3500-Duramax 6600 Turbo Diesel/Allison 1000
2005 FR Cedar Creek 34RLBS
