Woodalls Open Roads Forum: Tech Issues: Plastic taste in water
 > Plastic taste in water
Jerrybo66
AZ
Posted: 04/10/05 07:35pm Link  |  Print  |  Notify Moderator
I get a plastic taste in the camper water. I drained it and use the white RV type hose to fill the tank with fresh water. I have used bleach and flushed it thoroughly a couple times and can't get rid of the taste. The water makes terrible coffee. Does anyone have experience with curing the problem .. Thanks...
Support the Country you live in or live in the Country you support
2003 Sierra SP 26'Toy Hauler
1997 F-350, PSD, 4X4, red Crew Cab, long bed.
2007 Arctic Cat Prowler, Arctic Cat 500
lmims
Big Spring, TX
Posted: 04/10/05 07:40pm Link  |  Print  |  Notify Moderator
Mine is almost 2 years old, and continues to taste like that. We just don't use the water tank water, to drink. If I needed it, i'd just put a filter at the facet, but here the water is so bad, we just used bottled all the time.
Layne Mims
Big Spring, TX
2004 KZ Frontier 2809 Picts
GoinKZ Owners Group
1999 F350 crew dually PSD
2 EU2000's, Jordan, Retrax, aeroflow covers, maxxair fan cover, atwood tongue jack, f/r quickdraw power stab jacks, watts press regulator, doran 12 tire monitoring system(dually+spare, trailer+spare), levelair air level bags.
jdcone
Riverside, Ca. USA
Posted: 04/10/05 07:41pm Link  |  Print  |  Notify Moderator
Add some vinegar. Really. This will take the bleach and plastic taste away. My wife told me to do this. And she was right.
Owners of Bob the Wonder Dog, and a bunch of other useless stuff.
1999 22' Tioga class C
CA Rambler
Northern CA
Posted: 04/10/05 08:18pm Link  |  Print  |  Notify Moderator
Hey idcone,
How much vinegar should one add? Should one flush the tank with a mixture of vinegar and water or what? Your reply will be appreciated.
IT'S BETTER TO WEAR OUT THAN RUST OUT
gibbe5115
southeast missouri
Posted: 04/10/05 08:24pm Link  |  Print  |  Notify Moderator
Make sure you use white vinegar. My wife cleaned our coffee maker with apple cider vinegar and it took forever to get that taste out!
2002 Chevy HD2500 CC 4x4 D/A
'99 H-D Road King Classic (his)
'07 HD Deluxe (hers)
'04 Kawasaki Prairie 700 4x4 (ours)
'06 KZ Sportsman Sportster 33P (theirs) {the banks}
The worst mistake you'll ever make...
will seem like a good idea at the time.
jdcone
Riverside, Ca. USA
Posted: 04/10/05 08:39pm Link  |  Print  |  Notify Moderator
I added one gallon to my 100 gallon tank. Let it sit overnight. Rinse and fill.
jeep2relax
Lakeside, CA
Posted: 04/10/05 08:40pm Link  |  Print  |  Notify Moderator
I use baking soda.
We don't drink the water though. I just want it to smell good when I take a shower.
mike4947
N. Syracuse, NY
Posted: 04/10/05 09:04pm Link  |  Print  |  Notify Moderator
We've found even RV "white" hoses can sometimes leave the GAAK taste even if the tank doesn't impart any "flavor". Our solution was a charcoal element filter hooked after the hose on the side of the trailer. If we had to fill the onboard fresh water tank we'd use a small hose section and the filter inline.
Even the best RV hoses can leak some chemicals over time if they get stored away with water in them especially if they get warm or hot.
Also a reason we try and dump the fresh water tank when leaving. Just that much less chance for any volitols left in the plastics to leach out over time.
Subscribe to the daily digest
crashpilot
Green River, WY
Posted: 04/10/05 09:27pm Link  |  Print  |  Notify Moderator
You're going after the wrong aftertaste. Try attacking the bleach aftertaste instead of trying to neutralize the "plastic taste" and you might get some results. Bleach will sometimes leave an aftertaste you will swear is caused by the plastic water lines.
The vinegar trick works!! Also, my owners manual suggests using baking soda. I've never tried baking soda, but that is what Jayco recommends.
Straight Board -
2008 Chevy 4X4 Z71 Crew Cab K2500HD LTZ Duramax/Allison
2005 Jayco JayFlight 31BHDS
2007 Kawasaki BF 650 4X4i Camo (mine)
2007 Polaris X2 500 EFI Deluxe (hers)
The mountains of Wyoming as my backyard.
Powder River, Let 'er buck!
Jerrybo66
AZ
Posted: 04/22/05 06:54pm Link  |  Print  |  Notify Moderator
UPDATE...............
Last week, as per the suggestion of you folks, I dumped a gallon of white vinegar in the tank and topped off the water. After about 24 hours I drained and refilled. I tried it today and still no plastic taste..... I thank you all.........
