Woodalls Open Roads Forum: Truck Campers: Titan hitch
Search only in Truck Campers
 > Titan hitch
H2oSprt
Cerritos, CA
Posted: 04/29/05 11:30am Link  |  Print  |  Notify Moderator
Well I am taking the advice I received on this forum and going with a Titan hitch. My problem is which do I order? Model number 45012 (Deep drop bumper) or 45008. Both work on F250's. I guess my question is do I have a deep drop bumper? I have a stock ford bumper. Is this a deep drop bumper?
04 K2500 HD, 4.1, CC, SB, 6.0
BIG TENT
Honda 2000
BradW
Flat Rock, Alabama
Posted: 04/29/05 11:42am Link  |  Print  |  Notify Moderator
I'm not sure, but I believe the "deep drop" is for folks with those very wide custom / aftermarket rear bumpers (Cowboy Bumpers).
Internet forums only exist to serve their members; never the other way around.
1996 Lance 500 and 2006 F-350 PSD 4X4 DRW
Our Truck Camper Photos........Visit the RV.net Blogs
CountryLife
Central FL (USA)
Posted: 04/29/05 02:01pm Link  |  Print  |  Notify Moderator
If you go to www.etrailer.com and select the hitch option it will list several hitches and the 2 you're interested in are there. Select the "detailed info..." link, then select the installation instructions - Hopefully that will tell you what you need to know. (One of the instruction links wasn't working just now, but maybe it'll be back shortly)
SoCalDesertRider
SanDiego, CA, USA
Posted: 04/30/05 12:57am Link  |  Print  |  Notify Moderator
If you have the stock bumper, you do not have a 'deep drop' or 'drop center' bumper. You should be fine with the regular Titan hitch for your truck. A hitch for a deep drop bumper will put the reciever opening a few inches lower than the bottom of the stock bumper. If your truck is tall and your trailer isn't, maybe that could be a good thing, but for most uses, the standard size hitch is fine.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
LoadNGo service body
HD Springs Bilsteins, EnergySuspension
4.56's & LockRite rear
 > Titan hitch
