Woodalls Open Roads Forum: Travel Trailers: Cool Mods
Page of 191
Fisherguy
Vancouver BC
Posted: 02/05/12 09:01pm Link  |  Quote  |  Print  |  Notify Moderator
SabreCanuck wrote:
Fisherguy wrote:
WHAT? Only 6" to store your empty beer cans, you're such a lightweight!
That's actually true.. But remember, also fits empty rum bottle
lol
06 Dodge Ram 3500 Cummins 6 spd std with a few goodies.
2007 Komfort 274TS, SteadyFast stabilizers, Trimetric 2025RV, PD9280, Honda EU2000i, Xantrex SW600, shocks and EZ-Flex suspension, Reese Strait-Line
SabreCanuck
Winnipeg
Posted: 02/16/12 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
OK, as promised... Step 2 of winter mods complete...
Turned pantry shelves into slideout pantry.
Used 2 pairs of full slide drawer hardware rated at 100 lbs/pair.
For those that care... Weight of stock shelves/support brackets = 5 lb X 3 = 15 lbs. Weight of this unit = 23 lbs with all hardware and shelf unit.
The difference is approximately same weight as rum bottle.. Working on lightening that up right now
Stock pantry that you can't reach to the back of......
New slide out shelf unit..
IN>>>
OUT>>>
Fisherguy
Vancouver BC
Posted: 02/16/12 07:58pm Link  |  Quote  |  Print  |  Notify Moderator
Nice job!
I'd like to make each self so it can slide out individually like at home, but will I ever get around to it...?
CManley
Elk Grove, Ca
Posted: 02/16/12 08:08pm Link  |  Quote  |  Print  |  Notify Moderator
A few years ago I had a water leak on the front of the trailer between the aluminum siding and filon. The flex of the trailer separated the two.
I repaired the structure, paneling and replaced the insulation from the inside leaving the outside for later. I finally got around to it with the help of Hemet RV in ordering the aluminum siding and diamond plate. The outcome looks like a new trailer, should had fixed it all at once.
The repair was very easy, the only things I needed was time and to borrow a pneumatic stapler
Before:
After:
2001 25dbs Tahoe TT, 2005 Chevrolet Silverado 2500 Duramax
Pictures
ROBERTSUNRUS
Lakewood, Ca.
Posted: 02/16/12 10:51pm Link  |  Quote  |  Print  |  Notify Moderator
Before:
After:
Hi, what a difference; That looks so much better.
dalenoel
S.E. Michigan
Posted: 02/17/12 04:21am Link  |  Quote  |  Print  |  Notify Moderator
Very nice job. Congratulations
04 Dodge RAM Quad Crew Cab 4x4
08 Jayco Eagle 322 FKS, Hensley Arrow, Prodigy Controller
Wife and myself, Lutheran Deacon, Oreo the Malshi, and maybe a grandkid or two
Lady Fitzgerald
Tempe, AZ, USA, Earth
Posted: 02/17/12 05:38am Link  |  Quote  |  Print  |  Notify Moderator
The repair was very easy, the only things I needed was time and to borrow a pneumatic stapler...
Heck, that looks better than the original! Good work!
Jeannie
lzasitko
Regina, SK Canada
Posted: 02/17/12 11:27pm Link  |  Quote  |  Print  |  Notify Moderator
Have to agree that replacing the filon with siding and the checker plate looks a lot better. Nice job!
boatwhyteh2o
Montana
Posted: 02/18/12 08:09am Link  |  Quote  |  Print  |  Notify Moderator
I have often seen questions about what we are using to attach items to the thin walls of our trailers and RV's. I almost never use a screw unless it's going into solid wood. I use a variety of fasteners. I have used peel pop rivets, Tri-bulb pop rivets, plastic "Christmas tree" rivets and the center push plastic rivets. I have used the Christmas tree rivets to plug holes left for any number of reasons..my mistakes. This would be an example how I use the fasteners, my entry level TT has valences with fabric covered vertical sides. They are attached by little "L" brackets and tiny 1/4" screws to the vertical piece and the wall. If the valance is bumped the little screws come out stripped. So I attach the vertical to the "L" bracket with a peel rivet, and the "L" bracket to the wall with a removable plastic rivet. If I ever remove the verticle the hole will be plugged with a "Christmas tree" plastic rivet.
Sorry for my ramble, and I can't get pictures now or I would post them,
brooks
PennyPA
Out There Somewhere
Posted: 02/18/12 10:31am Link  |  Quote  |  Print  |  Notify Moderator
Just how DO we post pictures to this forum?
COPD and LVRS
On the Road Again
My Home - 2002 Glendale Titanium, 32/37DS
Our Home's Leader - Dodge Ram 3500 Cummins Turbo Diesel Dually
Our Leaders - Pounce Perfect(Dog-At Rainbow Bridge), Taco Terror (Dog), Sam Social (CAG) & Nellie Nuisance (Kitten)
Page of 191
