Woodalls Open Roads Forum: Travel Trailers: ATTENTION ALL MEMBERS - NEW DOMETIC RECALL
 > ATTENTION ALL MEMBERS - NEW DOMETIC RECALL
Page of 10
scottsnider
Buena Park
Posted: 06/04/11 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
inside refer.jpg This may not work, mac's and post pics are not the same as pc's, I hope this pic if it comes out shows a fix to the refer.
RaviAuto
jaipur
Posted: 10/22/11 12:54am Link  |  Quote  |  Print  |  Notify Moderator
I checked this link but it not open properly i will try later..
BarneyS
S.E. Lower Michigan
Posted: 10/22/11 08:17am Link  |  Quote  |  Print  |  Notify Moderator
It seems that the website has been taken down - probably due the fact that the recall has been going on since about 2007. You can check this thread for most of the information that was on the recall website. If you still have questions, I would call Dometic and ask.
Edit: this link should work.
Barney
Hensley "Arrow" 1400# hitch
Visit our website here
Islander1
Long Island
Posted: 05/02/12 04:17pm Link  |  Quote  |  Print  |  Notify Moderator
OP link is dead.
JJBIRISH
Butler, PA, USA
Posted: 05/06/12 09:53pm Link  |  Quote  |  Print  |  Notify Moderator
Link with some pictures…
click
AnEv942
CA
Posted: 05/08/12 01:33pm Link  |  Quote  |  Print  |  Notify Moderator
Pics from the link above-help to identify if your refer has had recall done- basically a safety thermal link is added to wiring near burner and a themal disk/button added to flue-if either sees high heat shuts off power to refer. Also added is sheet metel under, behind and in front of burner-to contain fire I assume should one start.
This shows the added thermal link in wiring and added thermo disk/button that shuts down power to refer..(added front sheet metal removed). Shows added bottom tray and metal surround in back.
And the front surrounding sheet metal (yours would be square, I loped of corner cause it was rubbing heater wires)
Mark
01 Ford 250 4X4 DRW Diesel, 01 Elkhorn 9U
Our camper projects page
Page of 10
