FLBentRider
West Palm Beach, FL
Just got new tires installed.
Tire shop said that they could not do the alignment due to the fact that they could not get the wheels to rotate freely... ???
The also stated that they detected a warped rotor on the test drive.
I had an issue in the past with sticking brakes and the brake system overheated. I let it sit and hour and the symptom vanished. A subsequent visit to my repair facility was inconclusive.
This time they are thinking master cylinder. It seems like it is not always the same wheel sticking. The drive to the tire shop there was a whop-whop noise, but it was not pulling to one side or the other, and of course the noise went away about a mile from the shop.
Has anyone else had a similar issue ?
It is a 2003 Holiday Rambler.
We have a 665 mile trip planned starting next Tuesday for Thanksgiving.
2003 Holiday Rambler Atlantis 29
DW, DS(17),DD(16),DD(6),DS(4), 2 Chocolate Labs
Rans Screamer
BuckBarker
Overgaard, AZ
Is your brake pedal pulsating when you apply the breaks? If so, you have a warped rotor and probably a sticking caliper as well.
jauguston
Bellingham, WA
It is not unusual for water to get past the weather boot on the caliper and start rust forming in the caliper body especially behind the piston seal o-ring. This rust growth puts excessive pressure on the piston o-ring and the piston won't retract properly. Usually a disassembly and rust cleaning will fix it. New seal kits are inexpensive.
Jim
Jim, Sharon and Buddy the Yorkie
1999 Gulfstream Sun Voyager 31' ISB Cummins 275
AIMS 2500w inverter 4-6v GC batteries
4-Kyocera 130w solar panels SB3024iL MPPT controller
Pressure Pro TPMS
FLBentRider
West Palm Beach, FL
They found warped rotors, the left worse than the right. New front brakes are being installed, including rebuilding the calipers.
carringb
Corvallis, OR
Sorry to say, but warped rotor diagnosis is almost a scam. It rarely happens on light trucks. What really happens is uneven brake pad deposits, which feels like warped rotors.
Calipers do not stick because of the master cylinder. Usually it's in the caliper assembly, and happens on rigs that aren't driven a lot.
Bryan
2000 Ford E350 DRW Wagon (14-pass all captains chairs)
V10 w/ Banks PowerPack, Diablo Predator, 4.56 LS, 250,000+ miles
Had: Weekend Warrior 41' FSW
otbiker
Kerrville TX
Phenolic pistons in the calipers have distorted due to overheating. Ford quit using phenolic pistons only after a few years. The rebuilt calipers won't have them...
Marty & Martha in Kerrville
2010 Winnebago View 24A
frankdamp
Anacortes, WA
I would suggest checking whether the brake fluid is still liquid.
On my (much older) 26' Class C, I had a problem with the back brakes remaining on and overheating. It turned out the the high under-hood temps of the 460 had boiled off the volatile compounds in the brake fluid to the point that it looked like maple syrup outside in Alaska in January. It had made its way into the rear brake cylinders and gummed them up so bad that the return springs couldn't release the brakes.
Max speed on level ground was only about 45 mph! New master cylinder and rear actuator cylinders (and about $400) solved the problem. Fortunately, the goop hadn't made it into the front brake calipers, though the master cylinder fluid for them was pretty bad, too, so flushing out those lines was enough.
Frank Damp
Anacortes, WA
FLBentRider
West Palm Beach, FL
The (front) Calipers were still sticking. They are being replaced.
SULTINI
PENNSYLVANIA
What happens is the brake fluid gets moisture in it and this is transfered to the caliberss and eventually the moisture causes rust and gum which in turn fails the brakes . Happens all the time.
I always try to change brake fluid twice a year. No Problems.
SULTINI
40'INNSBRUCK
TBS 40
#1 18'NOMAD, #2 20'MALLARD #3 27'SUNLINE #4 30'C FOUR WINDS #5 40' INNSBRUCK.
BEENTHERE DONE THAT
angel3
Mastic beach, NY
I had the same problem on my 2002 E450. The problem is the lack of use, plus water in brake fluid. It cost me a set of bearings and new hub.
