Woodalls Open Roads Forum: Tech Issues: Propane quick disconnect on 5th Wheel
 > Propane quick disconnect on 5th Wheel
NC Retiree
Summerfield, North Carolina
Posted: 11/19/09 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
I have a convenient quick disconnect for propane in the lower side of my Crossroads Cruiser fifth wheel. I am told it is a low pressure propane connection. I also have a table top propane grill that I have a long hose to connect it to a standard propane (20 lb) tank or one of those small propane bottles.
I want to know if and how I can connect my grill to my quick disconnect on the lower side of the unit.
falconman
Orange County, Ca
Posted: 11/19/09 05:46pm Link  |  Quote  |  Print  |  Notify Moderator
Your grille probably already has a regulator which means it may or may not work correctly when connected to the trailer. The quick connect on the trailer is most likely regulated at the tanks. Connecting the grille directly to the quick connect might work but at a lower heat output. You might have to remove the grille regulator and bypass it when connected to the trailer. This can be accomplished using a variety of adapters/ hoses and quick connect fittings. This is what I did for my Weber grille. If you have a propane dealer nearby, they can make up hoses and provide fittings.
4*phun*2
Canada
Posted: 11/19/09 05:50pm Link  |  Quote  |  Print  |  Notify Moderator
You need to remove the pressure regulator from your grill, because you have a pressure regulator on your propane system already.
Take your grill to any BBQ shop and they will fix you up.
I had them built mine with a quick disconnect on the grill and quick disconnects on the regulator so that I can use it with a regular propane tank if I want to.
Glenn & Karen
'06 F350 4X4 Lariat CC LB DRW (nice hips)
'09 Victory Lane 38SRV Toy Hauler
'02 HD Road King FLHRCI KRUZN
'04 F150 XLT Super Crew
Our Toys
RCMAN46
NorthWest
Posted: 11/19/09 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
Your portable will not work on the tailer port. The portable has been set up for a higher propane pressure than you trailer port has. I know because I have been there and could not get enough heat from the poratble to be of any use. They make units designed for the lower pressure. They are usually pricy and large.
Gene&Ginny
North Kingstown, RI
Posted: 11/20/09 08:25pm Link  |  Quote  |  Print  |  Notify Moderator
As falconman and 4*phun*2 said, remove the regulator from the portable grill. The pressure from the quick connect is 11 inches water and the output of most grill regulators is 11 inches water. I modified my Coleman Roadtrip and have a 15 foot hose from the grill to the TT quick connect, makes for an easy setup.
Gene and DW Ginny
2008 Toyota 4Runner 4.7L V8 w/factory towing option
2002 Sunline Solaris Lite T2363
Reese Dual Cam Straight Line HP Sway Control
NC Retiree
Posted: 11/20/09 09:21pm Link  |  Quote  |  Print  |  Notify Moderator
Gene and Genny:
How do you adjust the flame in the grill if you remove the original regulator from the grill? Is there some sort of adjustment part that I need to connect to the hose? I already have a 10 foot hose but do not know where to get the needed parts or what parts to get so that it all safely works together. Sorry to be so ignorant but this is all new to me. Thanks for your help.
webslave
Clearville, PA
Posted: 11/21/09 05:29pm Link  |  Quote  |  Print  |  Notify Moderator
Some grills, the Weber for instance, have the gas regulator (for flame height) separate from the regulator. On those grills, it is a simple matter to remove the regulator, replace it with a quick-connect, and the burner controls remain functional. Other grills, those that have the burner control built into the regulator, are either not convertible to low pressure disconnects or very expensive to do so. They would require that the control / regulator unit be removed and some sort of burner control added, along with a quick-connect.
Best bet may be to buy one of the Weber grills; remove the regulator, put on the quick-connect and you're good to go. There are other brands out there that have separate burner controls and regulators, but, the Weber seems to be the most popular ( I have the Weber Q-120 and two hoses, 4' and 12' ).
Don
Bronwyn
3 Cats - Coco, J-Lo and Ragamuffin
2008 FunFinder X 210WBS
2008 Jeep Hemi Commander Limited
Eqaul-i-zer 10K
Prodigy P3
Gene&Ginny
North Kingstown, RI
Posted: 11/21/09 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
NC Retiree wrote:
Gene and Genny:
How do you adjust the flame in the grill if you remove the original regulator from the grill? ....
My flame adjustment is on the grill itself, one knob for each of the 2 burners and after the regulator. As webslave mentioned above, some have the adjustment as part of the regulator.
Here is an older post and thread where it was discussed and where I got the idea.
http://www.rv.net/forum/index.cfm/fuseac........d/13560428/gotomsg/13561979.cfm#13561979
C Schomer
Buckeye, Az.
Posted: 11/21/09 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
My rv grill has a reg that a disposable bottle hooks to and I had to tap in between the first and second stage regs (at the dual rv tanks) to get enough pressure (about 18 psi) to make the grill get to high fire. Most of the 2 stage rv regs are one casting but mine is 2 pieces with a 1/4" nipple in between. I had to keep the reg at the grill cuz it was also the burner adjustment. I got a fitting at a propane supplier that screws into the grill reg and made up a 25' hose that comes from the center tap on the tank regs. Craig
* This post was edited 11/21/09 07:28pm by C Schomer *
03Dodge QC HO CTD Dually NV5600 4.10 Rear/WD A2K turbo Diablo Predator Quad BF 4" exh PRXB Pacbrake Rancho 9000s FS Airbags Onboard air/in-cab controls HUGE custom intake Custom hauler bed. 98 Sunnybrook 30RLFS 5er.WHOEVER INVENTED WORK DIDN'T HAVE AN RV!
renoman69
Edmonton Alberta
Posted: 11/22/09 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
I teed in a quick connect before the regulator on the trailer inside the propane tank compartment. I just poke a hose up through the underside of the compartment and hook up my grill that has it's own regulator.
2009 Jayco Eagle Superlite RK25.5
2008 Silverado 2500HD Z71 4x4 Duramax/Allison
Reese 15K slider
Honda EU2000I
