Woodalls Open Roads Forum: Will my slide work with the batteries out?
 > Will my slide work with the batteries out?
renoman69
Edmonton Alberta
Posted: 11/20/09 04:35pm Link  |  Print  |  Notify Moderator
.... and still plugged in to the shore power?
2009 Jayco Eagle Superlite RK25.5
2008 Silverado 2500HD Z71 4x4 Duramax/Allison
Reese 15K slider
Honda EU2000I
SCR
Full Timer - I'm really not sure where I am
Posted: 11/20/09 04:42pm Link  |  Print  |  Notify Moderator
seems easy enough to find out... disconnect the battery and try the slide.
dodgebob08
Mississippi
Posted: 11/20/09 04:48pm Link  |  Print  |  Notify Moderator
mine won't, others may, all i know is mine won't. TAFJ.
2008 Dodge 2500 MegaCab CTD
2006 Copper Canyon 295RLS
BFL13
Victoria, BC
Posted: 11/20/09 04:49pm Link  |  Print  |  Notify Moderator
Ours does but first you have to join the two red wires that normally go on the pos battery post. (somebody on here gave me that tip years ago and I am still grateful.) I use a vice grip pliers for that clamping job on the two wire lugs. The converter has enough oomph to move the slide ok.
I saw in a newer Jayco a warning label that said you needed a battery to operate the slide. I suspect this is only to keep the slide motor pos wire and 'converter' pos wire together on the pos post so there is a path from converter to slide motor. Don't know. Try it out.
2003 Chev 2500HD ExtCab, LB, 2WD, 6.0/4.10 Gas
2003 Komfort 26FS 5er (28.5 Ft-RK-10,000lb GVWR)
ReneeG
Meridian, Idaho
Posted: 11/20/09 05:08pm Link  |  Print  |  Notify Moderator
Ours won't either. After taking the batteries out for winter storage with the slide out, had to use the manual crank handle to bring it in. First time we did that so it was a good "test run".
2006 282TS Komfort
1999 Ford F250 4x4 XLT SD Triton V10 w/Tow Package
Prodigy Brake Control
Magnaflow Cat Back Exhaust, FIPK, TransGo Shift Kit, 4.1 Differential
Hensley Arrow
Dave & Renee plus (Champ & Molly in spirit), Missy, Maggie, and now Paris!
Trailer Trash 2
Santa Fe Springs, CA
Posted: 11/20/09 06:04pm Link  |  Print  |  Notify Moderator
are the motor driven or hydrolic accuated slide.
Mine wont the amp draw is way more than the converter will put out.
Don & Georgia
AKA: Trailer Trash 2
Real trucks don't have spark plugs.
2009, Dodge, 3500, Q Cab, Cum/Diesel, D.R.W.
Pulling a Super Fine Montana 2980RL
eaw46
Regina Sask. Canada
Posted: 11/20/09 06:12pm Link  |  Print  |  Notify Moderator
I would be worried about leaving the unit plugged in for very long without the battery's in it. I am thinking that the converter might go into a heavy charge mode to bring the battery's that are not there up to charge and burn something out. Please note I am not an expert I just think there COULD be a concern. Eddy
Eddy from the Great White North
1997 Triple E Commander 35
wild bill
Mira Loma, Ca. USA
Posted: 11/20/09 07:18pm Link  |  Print  |  Notify Moderator
All are good answers....my hydraulic slide draws over 50 amps to move in and out....Sticker on trailer control panel says battery must be connected to operate slide.
05 Dodge 3500 Q-Cab,GearVendor 8 Sp,PacBrake,Banks intercooler & intake,TST R49,Transferflow 70 tank,TrailerSaver Hitch,05 Raptor 3612,Second AC, solar 6 battery sys Xantrex 3000, WEB SITE
http://home.earthlink.net/~wbrown02/wildbillwashere22/index.html
JIMNLIN
Big Cabin, OK
Posted: 11/20/09 07:35pm Link  |  Print  |  Notify Moderator
The gear drive and the hydraulic operated systems I've had in two different 5ers wouldn't operate without the battery hooked up.
edit to add that both motors were operated on 12 volts.
* This post was edited 11/21/09 06:25am by JIMNLIN *
"good judgment comes from experience, and a lot of that comes from bad judgment" Will Rogers
'03 2500 QC Dodge/Cummins HO 3.73 6 speed manual Jacobs Westach Linex
'97 Park Avanue 28' 5er with two slides 16" BFG Commercial LTs
dougrainer
Carrolton, Texas
Posted: 11/20/09 07:38pm Link  |  Print  |  Notify Moderator
The OP has a Jayco (12 volt electric slide). So, yes, his slides will operate without the batteries connected. But it is NOT a good idea to do it all the time as it puts a heavy load on the Converter. Doug
