Woodalls Open Roads Forum: Class C Motorhomes: Tow Wiring on E450 Chassis
 > Tow Wiring on E450 Chassis
Godsey97
Troy,Ohio
Posted: 08/06/10 05:35pm Link  |  Print  |  Notify Moderator
This is exactly why I am addicted to these boards.
A person needs help and the calvary comes charging....
I am going to have to install a brake controller on my 2011 Freelander and now I have saved a ton of time chasing wires..
You all ROCK!
jagage46
Angola - N.E. Indiana
Posted: 08/05/10 09:38pm Link  |  Print  |  Notify Moderator
Olddud,
You saved me. I have a 2011 Aspect and was trying to locate the electric brake feed for the same reason you did. I spent much time looking at Winnebago wireing diagrams, trying to trace the LLG wire from the seven way, continuity testing the Ford connector under the dash, and finally trying to run my own wire from the seven way to the cab. I finally googled 'E450 brake controller' and found your post. I'm glad you found the correct location and described how to get to it. It was a pain getting it below the dash, but thanks to you it only took about 15 minutes. Just curious what light you used and where you mounted it on the dash. I have the Stay-In-Play toad brake and it came with a blue light but I'm not crazy about that one. I'll look around for something that mounts nicely in the dash. Thanks again.
Jim
Olddud
Lost in Kansas
Posted: 01/29/10 02:28pm Link  |  Print  |  Notify Moderator
You are right about where it is located. The largest Ford dealer in the area told me it is behind the switch panel just above the radio. He was right. It is also a weird looking connector.
This is the panel:
This is the connector:
Man, was that a nightmare finding it. You have to remove the brown plastic dash surround by popping it off. Then, pull it back far enough to find the connector setting on top of the area above the switch panel. Now the wires ring out correctly.
I plan to put a panel light in the MH dash, and connect the umbilical cord electric brake wire to the brake switch in the toad to light the panel light. I had to run a wire from the umbilical connector through the toad firewall to the brake switch. By the way, the brake circuit is a dark blue wire on the MH connector.
Thanks for all the assistance, everyone. This is a great place.
Crem
Wisconsin
Posted: 01/29/10 02:23pm Link  |  Print  |  Notify Moderator
Olddud, when you mentioned tracing that brake wire back to the center of the coach, that rang a bell. A few years ago I remember tracing for a wire and it could have been that brake wire. I have a 2003 Itasca and I called their technical help and the fellow told me that there could be a plug ending in the middle of the chassis which was there before the frame was extended. After a lot of searching I found that plug wrapped up and then went from there to the receptacle that I was wiring. I remember now. My chassis only had a 6 pin receptacle back there and I wanted a 7 pin and had to search for the missing wire.
tatest
Oklahoma Green Country
Posted: 01/23/10 11:09pm Link  |  Print  |  Notify Moderator
If the pinout diagram in that connector says one of the pins is for an electric brake controller, then Winnebago should have wired their extension to Ford's electric brake controller wire.
Information about where that wire comes out under the dash will be in the service manual, possibly the owner's manual, for the E-series chassis. Ford dealer might be more help than the Winnebago dealer.
Tom Test
Itasca Spirit 29B
Olddud
Lost in Kansas
Posted: 01/24/10 11:54am Link  |  Print  |  Notify Moderator
Well, I give up. I sure do thank all of you who tried to help, but I must be blind.
I used a circuit tracer and followed the electric brake wire from the tow plug forward to about mid-section of the chassis. From there it went into a maze of large wire bundles, where I lost it. Then I checked every visible yellow wire under the dash, floorboard, engine bay, and no continuity.
One of the fine members here (Dusty R) is sending me a picture, so maybe that will open my eyes.
j-d
Sunny Florida USA
Posted: 01/25/10 09:03am Link  |  Print  |  Notify Moderator
When you get that picture from Dusty, I and probably others would like to see it. I think it's a very good idea to provide independent verification that the toad's brakes are applied. The supp brake system might just not know they're applied or apply them and fail to report it.
Radio Shack has various little 12V piezo buzzers, if you also want audible notice the toad brakes are applied...
If God's Your Co-Pilot Move Over, jd
2003 Jayco Escapade 31A on 2002 Ford E450 V10 4R100 218" WB
Olddud
Lost in Kansas
Posted: 01/29/10 06:43am Link  |  Print  |  Notify Moderator
Just an update.
I got the picture from Dusty -- no connector found like his. I also got a picture from Winnebago -- no connector found, and picture similar to Dusty's. Told Winnebago about the picture and how it doesn't match much of my wiring -- they told me to call Ford HQ. and gave me their number. Called Ford -- their technical advisor told me that the connectors never come out in the same place every time. Ford told me to go to any local Ford dealership, and they could find the connector. I will try a dealership near home to see if they are able to help me.
I am now very tired.
I tried figuring out how to post pictures, but it seems too hard for my mind.
Kamphiker
South Florida (this 'aint paradise anymore)
Posted: 01/29/10 07:27am Link  |  Print  |  Notify Moderator
How and where are you going to connect the wiring to the TOAD ?
2006 Winnebago Outlook WF324V
2009 Honda CR-V 2wd TOAD ......Campgrounds in the Smoky Mountains NP
Last Camping trip ->2011 SUMMER SMOKY MOUNTAINS NATIONAL PARK
carringb
Corvallis, OR
Posted: 01/29/10 10:18am Link  |  Print  |  Notify Moderator
Ahh. I forgot about the changes for '09.
The newer E-series have completely different connectors because of the optional Integrated Brake Controller.
THe wiring should be tucked up behind the dashboard, to the left of the stereo.
See page 11:
https://www.fleet.ford.com/truckbbas/topics/2010/2010_Electrical.pdf
Bryan
2000 Ford E350 DRW Wagon, V10 - 400,000+ miles!
2014 CreekSide 31KQBS (QuadSlide bunkhouse)
2015 Ford Fiesta 0.999L EcoBoost
