Woodalls Open Roads Forum: Full-time RVing: Winter RV camping
Search only in Full-time RVing
Open Roads Forum  >  Full-time RVing
 > Winter RV camping
Page of 7
mustex
NZ
Posted: 01/16/12 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
RVRODDER wrote:
I used some "snake"or "reptile" aquarium type, infra red heaters to fight off the freezing temperatures affecting my holding tanks,this saves my propane,these heaters are not expensive,about $30 each,for a flat,1/16"thick pad.These can be attached directly with double sided tape to your tanks,very efficient and safe little heaters that put the heat where you need it the most.
How many did you put on each tank?
How cold were the temps you camped in?
pianotuna
Regina, SK, Canada
Posted: 03/24/12 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
Be aware that inverter generators may not produce their full output in cold weather DAMHIK.
Regards, Don
boston blacky
Gatineau Quebec Canada
Posted: 04/28/12 04:57am Link  |  Quote  |  Print  |  Notify Moderator
Greetings;
It's been cold the past few nights and here in Canada's National Capitol Region of Gatineau/Ottawa the local forcast calls for one more night of below freez'n temps. before it warms up. Bottom line is 35 yr. ago - when we camped out with our kids in an oversize pop-up tent trailer -cold nights didn't seem to really matter. Now, in my mid sixtys the cold gets to me. Especially after all winter in the warm Texas sun. "Help me make it thru the night". And bring on that south Texas sun. BB
p.s. Put something in the oven at 6 am to shake of the morn'n chill. That helps.
BOSTON BLK
safn1949
Mn
Posted: 05/22/12 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
So a question....I see where you have to be careful of the fridge because of the way it works but what if you don't run it and the TT is stored all winter? Mine is 21 years old so it seems to be a non issue,comments please.
I am parked in a campground with shore power and wonder how long we can stay in Minnesota's winter,wind is going to be a big factor as it is flat and windy.
pianotuna
Regina, SK, Canada
Posted: 05/22/12 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
Hi safn,
I think when the fridge is turned off the water is all recombined into the ammonia. Ammonia freezes at -77.7 C (-107.86 F). If it is that cold, you will have other problems.
If you prepare properly and use the information on this thread you can stay through the entire winter--assuming a "four seasons" Rv with enclosed tanks.
The issues are where to dump and where to acquire fresh water.
safn1949
Mn
Posted: 05/22/12 05:29pm Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
Hi safn,
There is the rub,it is not a 4 season trailer. I would more then likely no keep water on board as we have another option for showers/toilet. It would just be sleeping hanging out about 4~6 days a month as I travel driving truck during the winter months.
Thanks for your response.
pianotuna
Regina, SK, Canada
Posted: 05/22/12 05:35pm Link  |  Quote  |  Print  |  Notify Moderator
Hi safn,
If running with no water that's even easier. Just keep enough electric heat on to keep the provisions from freezing. You could even get "sexy" and have a way to have a phone system to trigger the heat up to living temperatures a day before you arrived at the trailer.
Page of 7
 > Winter RV camping
