Woodalls Open Roads Forum: Recommendations for a Portable Toilet in my Conversion Van?
 > Recommendations for a Portable Toilet in my Conversion Van?
aliensquale
northeast
Posted: 06/07/11 02:36pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Ford E-250 Conversion Van and I would like to put a portable toilet in there for the long trips up and down the east coast. My wife must have to pee about every 2 hours so it would be nice to not have to stop every couple hours for a bathroom :-)
I am looking for recommendations on a good product/price and something that will definately contain the waste, not stink up the inside of the van if left in there on a hot day, and is easy to clean, etc.
I don't know much about these things so I figured I'd ask the pro's!
Thanks everybody!
dahkota
Washington, DC
Posted: 06/07/11 02:50pm Link  |  Quote  |  Print  |  Notify Moderator
We used to use one of these on our boat:
porta-potti
2008 Ford F250 diesel
2011 Jayco 22FB
GrandAZ
Indiana / Arizona
Posted: 06/07/11 02:56pm Link  |  Quote  |  Print  |  Notify Moderator
The Thetford porta-potti was going to be my suggestion as well. They have a sealed valve that keeps odors in tank (and works pretty well).
Little bit better pricing on them can be found here: Porta-Potti
Bob N.
Elkin, NC 28621
Posted: 06/07/11 03:01pm Link  |  Quote  |  Print  |  Notify Moderator
We camped for several years in a home converted Ford van (sort of a b minus) and used a Thetford porta-potty. It worked OK----you do have to lug the loaded bottom part from the van to a dump site or toilet, and when full, it's fairly heavy. You will also need to anchor the unit in the van so it will not turn over or slide around while under way. We used a strap with a slip buckle anchored to the floor, and run through the lifting handle on the bottom section of the porta-potty. We found the odor to be minimal, and this has the advantage of leaving it at home when you aren't needing it on the road.
Bob N
2002LTV Freedom 2a
1775
NY
Posted: 06/07/11 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
The simplest and easiest solution is this
http://www.cleanwaste.com/wag-bag
You can buy the refill bags in the camping department of Walmart - it will cost you for each use, but disposal is clean and simple and there is no odor once you seal the bag.
There are several companies that make a similar set up - and most camping stores should have them for sale.
If your plan is to use public restrooms when stopped this is a perfect solution to the need to go when in route. It is not bad all of the time and many use this during the winter months when their RV has been winterized to protect against freezing but still want to take a trip.
Roadtrek 190 Popular 2011
Meryl and Me Hit the Road
yizit
Central Wisconsin
Posted: 06/07/11 11:36pm Link  |  Quote  |  Print  |  Notify Moderator
ditto on the porta potties. There are many brands and they all work the same. The odor shouldn't be a problem if you use a chemical. We have been using this product www.5starhappycamper.com for over a year and have NO complaints. We have used the blue stuff in the past (in a porta potty and our TT) and found it to be to smelly (sweet sickening smell) for us. Reminded us of the porta potties used at fairs, etc. We still have our porta potty from our pop-up in case of an emergency. Friends of ours used it once in a rental cabin at a campground. Never know when it will come in handy.
Jim & Darlene
Ewok our Llasa...Pickles our Shorkie Tzu
2004 Roadtrek Chevy 190 Popular (aka..Roada)
Wisconsin Dells...Water park capital of the world
sodajerk
Dallas, Texas
Posted: 06/08/11 08:20am Link  |  Quote  |  Print  |  Notify Moderator
When we got our 1972 model 10 years ago, the potti was broke ant there was only one holding tank. It was designed to discharge the grey water on the ground. We solved the problem with a Theford Porta Potti as the black tank and re plumed the sinks and shower to use the one tank as a grey tank. It was hard to find, but I did find a hold down kit to keep the potti from sliding around in the shower. It is two brackets that screw into the floor and has sliders that fit in slots in the bottom of the potti.
One thing to watch as you drive in the mountains is a change in pressure in the tank, as it is not vented.
Works for us for 10 years.
Happy Camping
Jim & Jo Ann
1973 Wide Body Superior Class B on a Chevy 1 Ton Van. 350 4V
"Oldie but goodie"
ejbleendreeble
Posted: 06/08/11 01:24pm Link  |  Quote  |  Print  |  Notify Moderator
First, check out this:
http://www.hondarv.com/?BleenKleen
You'll see that I mention the pee-bottle in that article. If the problem is merely that someone needs to pee, you just need a good pee-bottle and the Lady J, which can be obtained from most camping stores like this one.
I have found that any really good plastic water container (such as could be used for drinking) will work as a pee-bottle. If it's good plastic, it won't let the odor through. I occasionally squirt a bit of Lysol into it, but otherwise I merely rinse it out.
I'm a big WagBag fan too, but for just peeing it's really overkill ....
JMHO.
Regards,
EJB
diyvanner
Rhode Island
Posted: 06/08/11 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
A nice alternative to having the toilet waste tank removed from inside the van is the cassette toilet by Thetford. This model needs to have an access door to remove the holding tank but other models can be set up so that the holding tank can be removed from the outside by opening the rear door. Had ours for years and is much more convienent than the portable type; IMHO of course.
diyVanner
cloftus
Roswell, GA
Posted: 06/11/11 08:24am Link  |  Quote  |  Print  |  Notify Moderator
EJB: loved that article. Very well written and informative.
As suggested by 1775 as well, I use a similar product from Wal-Mart as the Wag-Bags. I have a 5 gallon bucket and toilet seat called the Luggable Loo. I used a Thetford for many years until I got tired of the process of dumping and cleaning it. The Luggable Loo and Wal-Mart bags are fabulous! Another friend and I call the whole set up the "Lovable Loo". Since I use my Loo a lot, I find it invaluable.
BTW, I even put one in my Honda Element using a 2.5 gallon bucket "just in case". Just a little emergency preparedness for whatever takes away our comforts.
