tourusa
miami
My Atwood water heater I turn on the switch goes red then no spark I can light the furnace by using a match and it works fine but using the switch and no spark any ideas thanks. Doesn't create spark but gas no problem which lights and runs no problem any ideas pls
03 Cobra sb
Colorado
When you look at the wiring the gas valve has high and low limit switches, mine has brown wires to and from. (Look like disks). If the gas valve opens and lights all is working good there. Where the goose neck goes into the burner, you will see a red boot right above, it is the igniter (mine looks like a spark plug boot). It sounds like it is bad. If you have your owners manual, you can get the model # and check with your local RV shop or check online to buy a replacement. Your manual should have a wiring diagram that can help you.
kaagee
Burlington Ontario
I had the same problem last w/end...
I replaced the circuit board..easy fix
tourusa
miami
Hi Im looking for a spark probe part number 93868 the above issue I had some months back with my water heated not lighting with the spark and am on the hunt for a used one which someone has sat in there draw thanks
sbishop
Eagle Rock, CA
Here is a contact for the element.
Atwood WH
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
1990 Bounder 27D
1995 Suzuki Sidekick 4X4
Stowmaster 5000
j-d
Sunny Florida USA
Clean the connector and contacts involving the control board. Be sure the spring contacts are sprung to where they make solid contact. It's somewhere between a sure cure and a long shot.
God Bless, jd
tourusa
miami
Hi I cleaned all the contacts and by magic it ignited once now it doesn't ignite using the switch but I can manually light. Very weird any suggestions thxs
tourusa
miami
Hi went to camping world for the part never again everything is 100% mark up will be ordering online the igniter .
tourusa
miami
camping world wanted 56$ plus tax I just found it on 22 plus tax from americanrvcompany.com, cannot believe the saving
j-d
Sunny Florida USA
At either price, it's about the cheapest board I've heard of!
Please let us know if the change solves the problem.
A friend has this issue with his and cleaning the contacts helped occasionally but the problem still seems to be there.
