Woodalls Open Roads Forum: F150 2009 - 2011 Engine Torque Curve Charts
Search only in Tow Vehicles
 > F150 2009 - 2011 Engine Torque Curve Charts
Mike Up
NW Indiana
Posted: 09/03/11 07:24pm Link  |  Print  |  Notify Moderator
Anyone looking to buy a recent F150 may want this information to help them make a more educated decision on their purchase.
There's also Toyota, Chevy, and Dodge engine torque curves.
Ford released the torque curves for all the motors in 2009 - 2011 in their marketing booklet. I took pictures and have the results:
Here's the breakdown:
3.7L
1500 rpm = 237#
2000 rpm = 250#
2500 rpm = 244#
3000 rpm = 250#
3500 rpm = 256#
4000 rpm = 275#
4500 rpm = 269#
5000 rpm = 262#
5500 rpm = 265#
6000 rpm = 262#
4.6L 3V
1500 rpm = 269#
2000 rpm = 275#
2500 rpm = 287#
3000 rpm = 287#
3500 rpm = 302#
4000 rpm = 320#
4500 rpm = 315#
5000 rpm = 300#
5500 rpm = 280#
6000 rpm = 255# (Redline)
5.0L
1500 rpm = 275#
2000 rpm = 302#
2500 rpm = 315#
3000 rpm = 327#
3500 rpm = 350#
4000 rpm = 362#
4500 rpm = 379#
5000 rpm = 356#
5500 rpm = 348#
6000 rpm = 315# (Redline)
5.4L
1500 rpm = 260# ?
2000 rpm = 315#
2500 rpm = 340#
3000 rpm = 356#
3500 rpm = 365#
4000 rpm = 365#
4500 rpm = 363#
5000 rpm = 350#
5500 rpm = 297# (Redline)
6000 rpm =
Ecoboost 3.5L
1500 rpm = 375#
2000 rpm = 381#
2500 rpm = 415#
3000 rpm = 420#
3500 rpm = 413#
4000 rpm = 413#
4500 rpm = 400#
5000 rpm = 390#
5500 rpm = 350#
6000 rpm = 275# (Redline)
6.2L
1500 rpm = 360#
2000 rpm = 372#
2500 rpm = 390#
3000 rpm = 387#
3500 rpm = 397#
4000 rpm = 406#
4500 rpm = 434#
5000 rpm = 413#
5500 rpm = 397#
6000 rpm = 372# (Redline)
3.7L has an impessive torque curve and the Ecoboost has the best low rpm torque curve.
4.6L 3V has a decent torque curve while the 5.4L 3V has a good torque curve.
5.0L and 6.2L have the worst torque curves in the low rpms.
The 3.7L, while having a good torque curve, had lower outputs.
The Ecoboost Looks to be the best motor to tow with a side of any current overheating/transmission problems.
While the 6.2L has a terrible torque curve, it's output is high enough to get past that.
All motors have the curve start at 1000 rpm while the 5.4L starts at 1500 rpm. Curve below 2000 rpms on the 5.4L looks inaccurate as the curve just starts off at 1500 rpms. Don't know why they started testing so late in the rpms on the 5.4L 3V.
For those making a decision between a 2009/2010 5.4L 3V engine against the new 5.0L, I compiled the differences of torque output at differing rpms.
5.0L compared to 5.4L
This is the 5.0L torque
2000 rpm = -13#
2500 rpm = -25#
3000 rpm = -29#
3500 rpm = -15#
4000 rpm = -3#
4500 rpm = +16#
5000 rpm = +6#
5500 rpm = +51# (5.4L Redline)
2012 Jayco Jay Flight 26BH
29'1" bumper to hitch, 8' wide, 6'9" ceiling, 5050# unloaded and ~6500# loaded.
2016 F150 XLT 5.0L, CC, 5.5' bed, 9.75" 3.73 axle, 4x4, TBC, 385 Hp/387# Torq, 10900#/1110# Tow Rating, and 1890# payload w/ Blue Ox Sway Pro Hitch
carringb
Corvallis, OR
Posted: 09/03/11 08:40pm Link  |  Print  |  Notify Moderator
Probably transmission control limitations.
Bryan
2000 Ford E350 DRW Wagon, V10 - 400,000+ miles!
2014 CreekSide 31KQBS (QuadSlide bunkhouse)
2015 Ford Fiesta 0.999L EcoBoost
SoCalDesertRider
Arizona desert
Posted: 09/03/11 08:55pm Link  |  Print  |  Notify Moderator
I'd say the 6.2 Ford's torque curve and overall torque output is better than the other engines shown on it's same chart. The 6.2 makes more torque than the others at low rpm, is about the same as the Dodge, GM and Toyota engines from about 3000-4000 rpm and is higher than the others at higher rpm. What's not to like about that? Put that together with Ford's available 4.30 axle gearing and 6 speed trans and the 6.2 should far out pull any of the others it's being compared to.
The Ford 5.0 has higher torque output at every single rpm, from low to mid to high, than any of the engines on it's chart. The curve is smooth from idle to peak. What's not to like about that?
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
Golden_HVAC
Fulltime, CA, USA
Posted: 09/03/11 09:07pm Link  |  Print  |  Notify Moderator
Looks like great numbers for the Ecoboost! If they had made a 6.2L Ecoboost, they would be in the 800# range for sure! That would have started a HP race, but broken a few crankshafts in the process.
I was looking at the new 2012 Edge, and it will have the 2 Liter inline 4 Ecoboost in it. 240 HP and 270 foot pounds torque.
Fred.
Mike Up
NW Indiana
Posted: 09/03/11 10:01pm Link  |  Print  |  Notify Moderator
The 5.0L should as many of the engines compared to it are not 4 Valve and have smaller displacements. It is a great replacement for the Ford 4.6L 3V but although it has awesome horsepower, it still lacks in torque against the previous 5.4L which many directly compare it against.
I guess I love the idea of a turbo 3.5L but then again, I've never heard of any turbo gas engines that didn't require a lot of work 'other' than the Grand National which my brother owns.
As one poster on the F150 threads commented, diesel turbo engines don't put out anywhere near the heat that a gas turbo engine does and there are a few people that tow heavy trailers that have had the ecoboost go into limp mode from overheating while towing 8000 lbs trailers in the Southern heat while climbing mountains or large hills. The same people previously towed with the 5.4L and had no issues.
Either this is a new problem that was never discovered or there are a batch of bad sensors. These people are still getting their trucks worked on so the the end result isn't known yet. However this does play into the fears that many have with turbo gas engines. For those people, a new 5.0L, a new 6.2L which is only offered in Lariat and above models, or a used 5.4L, is an option.
I was really pleased to see these torque charts now as it really helps compare the different engines for different needs.
Mike Up
NW Indiana
Posted: 09/03/11 10:06pm Link  |  Print  |  Notify Moderator
Many makers are in a horsepower war with the other, so low end torque seems to be taking a back seat to higher horse power. After seeing the charts, I was really disappointed with the majority of torque curves. What ever happened to torque curves that provided 90% of peak torque at 1500 rpm?? Well they're extinct now for higher horsepower.
Mike Up
NW Indiana
Posted: 09/03/11 10:08pm Link  |  Print  |  Notify Moderator
Not really as all the engines use the same 6R80 transmission although the 2011s have updated clutch, electronics for manual shift mode, and programming. Otherwise there should be no limitations. The 2010 4.6L 3V uses the exact same transmission the 2010 5.4L 3V uses.
SoCalDesertRider
Arizona desert
Posted: 09/04/11 08:34am Link  |  Print  |  Notify Moderator
I'll agree with you there. Almost all new gas engines are high rpm screamers, versus the older gas engines (GM 350/454, Ford 351/390/460, Chrysler 360/440) that developed their peak torque in the 2500-3000 rpm range and their peak hp in the 4000-4500 rpm range. The gas engines in those days were slower turning engines with good low end torque, well suited for truck use.
lbrjet
Gold Canyon, AZ
Posted: 09/04/11 08:47am Link  |  Print  |  Notify Moderator
I have no idea why you would say the 6.2L has a terrible TQ curve.
If you want gobs of TQ at 1500 RPM's then buy a diesel. That's what their made for. Gas engines typically are not. Also remember that this TQ is being measured at the flywheel and may not accurately represent real world TQ getting to the wheels.
2010 F250 4X4 5.4L 3.73 LS
2011 Flagstaff 831FKBSS
Equalizer E4 1200/12000
Mike Up
NW Indiana
Posted: 09/04/11 11:42am Link  |  Print  |  Notify Moderator
Your not the first to be offended by the 6.2L curve so I'll give you the same response I gave to others.
I come from the muscle car period and the torque curve from the 6.2L is anything but muscle. It's all high end with a steep ramp up from the low rpms. I personally want a torque curve more rounded where the curve is less triangular or peaked. I want all my curve points to have torque as close to the peak output as possible. The Ecoboost has the best obviously.
However with the combination of high horsepower, the 6.2L is a powerhouse, it just could have better torque output in comparison to it's peak rated torque.
Obviously this is not uncommon as all truck makers are doing this for the bragging rights of having the most horsepower and torque. This is common for a 4 valve, dual overhead cam setup. The truck isn't tuned for the flattest curve but the highest output curve.
When I was young buying muscle cars, marketing then was about if the engine could provide 90% of it's peak torque at 1500 rpm so you can have plenty off pull when you needed it. Also, these were not DIESEL engines but GAS engines. [emoticon]
