Ivylog
Blairsville, Ga. USA
Instead of replacing my defective VHS/DVD/ATSC tuner with another one ($150) I decided to replace my 32" Plasma Monitor. Ended up with a 40" LED that is only 1.5" thick (Westinghouse LG-4080 $400) which just fits between the doors on either side.
Naturally the old mount was not big enough to use on the new TV. The nice thing about the LED is it runs 30 degrees cooler than the Plasma and has an anual engery cost of $15 instead of $150 for the Plasma. Yes, 1/10th the cost and when off it uses 1 watt.
Took the 3/4" trim piece off that went around the previous and mounted the new one on the face of the cabnet so it's only sticking out 3/4" more than the previous'
Made a bracket (1" used alum angle) that bolts where the normal bottom stand attachs. This sits on the bottom of the cabnet and supports most of the weight. Drilled the two mounting holes at the bottom of the angle for better leverage.
Since I was not at home (no shop) I had to rig the rest with plumber's strap. Ran a pair from the bottom two holes on the TV's back mount to help hold the weight and at the top I ran two to hold the top of the TV in. This picture is from the back looking up.
If I'd been at home I'd probably made two bars running vertically that would have fasten to the back bolts and would have rested on the bottom frame with lips that would let me screw them to the back of the cabnet frame.
last
edited 01/28/12 09:31am by Ivylog *
View edit history
Where am I?
How I tow.
Twomed
FL winters and then somewhere cool
Nice job Dick....and GREAT picture!
Goooooooooo Gaaaators!
Happy Trails
06 Monaco Dynasty
07 Hummer H3
FMCA 279843
roam1
Pensacola Beach
Nice tv!
Good taste in quarterbacks too!!!
piledrive
California
I used a similar method except I used 4 turnbuckles and eyebolts. Much better and way less expensive than the factory mounts they sell.
Good looking job.
Ivylog
I was able to do much the same as turnbuckles by how far in I put the screws. Can't really see this in the pictures, but several are not all the way in. Actually reused the 5/16" lag bolts from the old mount for the two long straps and the one you cannot see is not all the way in. Reused the old holes for the lag bolts.
RLHAMILTON
HOME
Nice job. Looks like a professional installer.
DICK & JUDY HAMILTON
2011 FOREST RIVER BERKSHIRE
2008 HONDA CR-V TOAD
LIFETIME GOOD SAM MEMBER
FMCA MEMBER F-386544
Mr. Shneebly 714
Anaheim,CA
I would like to mount a TV bracket to the back wall of my coach(best place for larger TV), but I don't know if it would be safe to run screws through the wall. Any suggestions?
2012 Bounder Classic 34B
ArchHoagland
Clovis, CA, USA
I have LED and my son-in-law has a plasma. I think the plasma has a better picture.
What's your take on which has a better picture?
2004 Monaco
La Palma 36DBD
Two Slides
2 Potties
Workhorse W22 Chassis
8.1 gas engine & Allison 1000 transmission
7.1 MPG based on fuel used over 46,000 miles
TOADS
2000 LEXUS RX300 FWD 22MPG 4020 LBS
US Gear Brakes
1991 Mazda Miata 5 speed 33MPG 2,310 LBS
mike brez
milford ct
Plasmas have the best picture quality.
1994 Pace Arrow 33L,454,P30
2oo4 ground up ridgid chopper 120rwhp
http://community.webshots.com/user/oneHD
erniee
Weatherford, Texas 76086
I have a 42 plasma and a 26 led- led has better picture and emits way less heat.
Ernie Ekberg, Bluebird Wanderlodge
