Woodalls Open Roads Forum: Travel Trailers: Bike Rack
tomman58
Southeast Michigan
Posted: 02/02/12 07:47am Link  |  Quote  |  Print  |  Notify Moderator
Gdetrailer wrote:
tomman58 writes "Good Grief as mentioned before I've towed 1000,000 + with the spare and two bikes and an aluminum tool box ( for leveling block storage and little else) on all kinds of roads NOW I am going to do it without the spare."
My bumper mount bike rack with only TWO bikes BARELY was able to make TWO trips for a grand total of 1800 miles before the BUMPER started to RIP away from the welds. There was no tire or any box back there, only the TWO bikes. Hit one really bad pot hole and that is all it took.
Just because YOU have lucked out doesn't mean that OTHERS or even YOU will luckout in the future.
Judging from your profile with the trailer there it wouldn't surprise me of the bumper problem you had. Don't judge other trailers by your Terry. Case closed.
You must understand that WE ALL MUST SHARE the road with others, there are OTHERS depending on YOU to do the RIGHT thing (and safest). Failure of your bumper mount puts others in harms way, this is what you are missing.
Folks YOUR MILEAGE WILL VARY but it WILL happen sometime down the road by directly using the bumper without serious modifications and reinforcements.
A fool and his bumper will soon be parted, I learned and no longer foolish, my bikes ride elsewhere.
You have been warned.
2008 Silverado D/A,CC 4x4 ,3.73,IBC LTZ+
2012 Jayco 322 FKS
2 Trek bikes
Honda EU2000i
It must be time to go, the suns out and I've got a full tank of diesel!
Lifes short enough without bitch'n about it!
hp0617
Indiana
Posted: 02/03/12 07:04am Link  |  Quote  |  Print  |  Notify Moderator
Do any of you who are using front mounted hitches carry a scooter on the front of your TV? If so, any problems with overheating? I have a 2011 F250 w/PowerStroke and would like to carry a little Honda Ruckus on the front, but, I don't want to cause a cooling problem. My travel trailer has a factory rear mount carrying rack that is rated for 200#'s and that is basically what the Ruckus weighs, but, I am hesitant to use that rack based on some of the writeups I've been following on here.
DB Family
Ohio
Posted: 02/03/12 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
The newer Outback's have a small receiver in the back of the trailer; has anyone used it to haul their bikes? I think the capacity is 200 lbs.
patinlouisiana
Baton Rouge, La
Posted: 02/03/12 07:05pm Link  |  Quote  |  Print  |  Notify Moderator
Dick_B wrote:
I wouldn't do it on my rig; too much overhung load for the rough roads and bouncing back end of the TT. Maybe try two bikes back there and two in front of the tow vehicle as we have done for years with a fabricated receiver.
Like this?
I never get lost! Someone always tells me where to go!
2012 Prime time Tracer 230FBS Touring Edition
2010 Toyota Sequoia Limited 4X2
patinlouisiana
Baton Rouge, La
Posted: 02/04/12 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
We went ahead and bought a Curt Mfg. Front Mount Receiver for my Sequoia. We will use the receiver type bike rack we already had. It will just lead us instead of following us around.
jerem0621
SE Tennessee
Posted: 02/04/12 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
I just put the Bikes in the TT. I lay them down carefully on their side and stack them one on top of the other (carefully), They are just a little forward of the axles so they help add some tongue weight
Plus being in the middle of the trailer there is much less bouncing. We have never even have a bike move while traveling. Others do the same thing but with a stand up bike rack. That is fine too.
I will never put a bike on the back of the trailer... too much risk IMHO..
I hate the "what-if" game but what if you hit a pot hole and your loaded to the max 4 bike carrier gets torqued hard enough.... well we have already seen the evidence of what happens... The frame may crack... If you are using just a bumper for support you may rip it off.. again, we have already seen the evidence... even in this thread...
Thanks!
Jeremiah
TT: 1995 Layton 2910
