Woodalls Open Roads Forum: Toy Haulers: New truck bed clearance
Search only in Toy Haulers
Open Roads Forum  >  Toy Haulers  >  Modifications & Accessories
 > New truck bed clearance
Page of 7
BobWanderer
Perris,Calif,USA
Posted: 02/09/12 01:45pm Link  |  Quote  |  Print  |  Notify Moderator
nayther wrote:
DuneMe wrote:
Just so you have another referance . . . (look at my Sig.)
Not sure what you're referring to really. My old truck had no issues (same as yours), new one is much taller.
Installing the new shackles tonight.
His truck has a 4' lift
How did the lowering shackeles install go ??
Bob J
2008 GMC 2500HD 4X4 DMax CC LB
2004 Thor Wanderer Wagon 247WTB
2006 TE450 Husky
2007 Rhino Sport Edition
2008 KTM250XCF-W
Viewfinders M/C member
RETIRED !!
2BlueHeelers
Sacramento, CA
Posted: 02/09/12 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
wait, what? Installing longer shackles to lift your trailer? Will that work? or are you lowering your shackles on the hangers?
Post Pics Please!
06 Rage'n Falcon 30-5
04 Chevy D/A
mapguy
Puget Sound
Posted: 02/09/12 04:04pm Link  |  Quote  |  Print  |  Notify Moderator
Post Pics Please!
Wrong idea.
He is putting rear drop shackles on his new Duramax to lower the rear a little.
2BlueHeelers
Sacramento, CA
Posted: 02/09/12 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
mapguy wrote:
Post Pics Please!
Wrong idea.
I knew that...
nayther
Burbank, CA
Posted: 02/10/12 09:31am Link  |  Quote  |  Print  |  Notify Moderator
I started to do the shackle replacement in my driveway but chickened out. The upper bolt cannot come out as it hits the frame so it is not as easy a job as I thought. I'm taking it down to my mechanic this morning to see if they can do it. Looks like this weekend will be at the stock ht.
DIRT BIKES RULE
'12 Duramax CC short bed
'06 3005 Rage'n Falcon
DrBaker
Oklahoma
Posted: 02/10/12 12:32pm Link  |  Quote  |  Print  |  Notify Moderator
Will you measure the before/after of your unhitched heights? While the shackles might say 2" they are often a bit off.
I just got the same truck and expect to find similar height issues. Reading your results will be helpful.
2011 Chevy 2500HD CC/SB 4x4 Victory Red
2003 Crossroads Cruiser CF27RL
Champion Screamer, Reese 16k, and a Blue Status Symbol
nayther
Burbank, CA
Posted: 02/10/12 02:37pm Link  |  Quote  |  Print  |  Notify Moderator
I'll measure it today when I hook up, that will be with the hitch at max. and the pin box as low as it will go but no lowered shackles, they will go on next week and I'll measure before/after with/without trailer.
DrBaker
Oklahoma
Posted: 02/12/12 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
I have almost 6" at the back corner of the bed. Front sits a bit higher than the rear. I hope to get to the scales soon to see how much difference I have in axle weight. Depending on the results the OP has with his lowering shackles, I may try that.
edit:
ground to rear wheel 42.5" unhitched and 40.25" hitched on the driver side (.25" higher on the passenger side)
5er frame to ground front 24.25" and rear 21.25"
Uploaded with ImageShack.us
nayther
Burbank, CA
Posted: 02/13/12 09:06am Link  |  Quote  |  Print  |  Notify Moderator
All is well!
Bed clearance is now 6.5-7" not as much as I'd like but acceptable, besides there's no way to get more, hitch is at max, pinbox at max. Trailer sits 1" higher in the front than the rear. It tows like a dream, I'm not touching a thing. If the '05 was a 9 as a tow vehicle, this one's a 15!
If I install the lowering shackels the rear will be way too low when connected, the trailer drops it 2-3" so it's just about level now. If I put more bikes, etc. in with weight over the axles more It might settle just a bit more. Overall it's perfectly fine the way it is.
Stock the rear wheel well clearance is 11" so it squats close to 3".
* This post was edited 02/13/12 02:41pm by nayther *
juzplanekrazy
San Dimas
Posted: 02/13/12 10:07am Link  |  Quote  |  Print  |  Notify Moderator
It all can be pretty frustrating for sure Nayther. My Dodge set real high too, and I hit the underside once and did some damage to both truck and trailer. Not a good day.
The change to the Ford did give me another few inch’s but the truck squats in the rear helping give the extra room. I was a little concerned about it tell I drove it and it did fine so I’m good with it as long as the trailers very close to level. I’m just worried how it will do during heavy braking lifting the front end.
Good luck with the new setup.
2008 Ford F-350 4x4 Dually
2007 38' KZ New Vision Toy Hauler
Pullrite Super5th
Page of 7
