Woodalls Open Roads Forum: Travel Trailers: New dometic digital thermostat?
 > New dometic digital thermostat?
Coop44
utah
Posted: 01/29/12 10:45pm Link  |  Quote  |  Print  |  Notify Moderator
Has anyone tried the new dometic digital thermostat, I just installed the hunter, but don't like the fact that the low battery light flashes all the time, and that the red wire is not connected.
I would think that the new dometic thermostat would be a direct wire in?
I found one for 34.99
Coop
See ya Coop
2008 forest river sandpiper t272
http://coop45.webs.com/
coopsclutchmods@q.com
LAdams
Northern Illinois
Posted: 01/29/12 10:52pm Link  |  Quote  |  Print  |  Notify Moderator
I haven't tried the Dometic but why is the low battery light flashing if there isn't a low battery And regarding the red wire not being used - what difference does that make??? Mine has been that way for 13 years and 2 trailers
Les
Hensley Arrow
Jordan Ultima 2020
HUNTER THERMOSTAT INSTALL
HOME MADE WHEEL CHOCKS
Old-Biscuit
Across the USA
Posted: 01/29/12 11:05pm Link  |  Quote  |  Print  |  Notify Moderator
Did you install a new battery?
Did you install it the correct way?
Did you use a small pin and push the reset?
garym114
Bluff Dale, Texas
Posted: 01/29/12 11:10pm Link  |  Quote  |  Print  |  Notify Moderator
It doesn't use the red wire because that is the power lead to the thermostat and the Hunter is battery powereed.
Put a fresh battery in.
2000 Sea Breeze F53 V10 - CR-V Toad
Some RV batteries live a long and useful life, some are murdered.
Get a Digital Multimeter and Learn How to Use It
Sluggo54
Madison, SD/Livermore, CO
Posted: 01/30/12 12:04am Link  |  Quote  |  Print  |  Notify Moderator
My Hunter uses two AA batteries. They are a tad bit loose; I have to shim them a bit to keep them tight in their slots. Remember, the Hunter was not built to be mobile - so some adaptation may be in order. Mine has been very good about batteries; they will last a year or more. One quirk is that if the batteries do go flat dead, the system will keep on doing whatever it was doing when they went dead. If the heat is on, it will keep heating, etc.
Sluggo
DH = Bruce, DW = PK, DD = Maggie (Lab, Pointer, Viszla)RIP 4/13/2007
Apprentice Princess = Kaia Grace (Blue Heeler - Wire Haired Terrorist)
TV = 2005 Chev CC LWB Max & Allie
5'er = 2005 Excel R30CKW
rpegram
Eastern NC
Posted: 01/30/12 04:34am Link  |  Quote  |  Print  |  Notify Moderator
I've had a Hunter in my Starcraft for around 2 years and only replaced batteries one time. I would not have had to do it then if I had removed the batteries in between trips. Low battery never flashed, it died when we weren't using the trailer. Before replacing thermostat, the AC could barely keep the trailer cool in the summer, but after switching, the AC kept the unit cool with no problem. The difference was that there was so little temperature change in the cycling of the AC.
2011 Jayco 26RLS
'92 26' Starcraft TT
'96 Dodge 3500 CC, 12 valve Cummins
jackandh2o
Golden Valley, Arizona
Posted: 01/30/12 06:52am Link  |  Quote  |  Print  |  Notify Moderator
Coop44, where did you find that at?
Ray
Coop44
utah
Posted: 01/30/12 07:07am Link  |  Quote  |  Print  |  Notify Moderator
Here is the dometic digital
http://www.rveparts.com/dometic-duo-therm-lcd-heat-cool-thermostat-3313192-000-rv-camper-parts/
The battery's are new, and it still flashes low battery, but works fine?
Maybe I need to reset it?
We're is the pin hole to reset?
Coop
LAdams
Northern Illinois
Posted: 01/30/12 08:39am Link  |  Quote  |  Print  |  Notify Moderator
If the battery warning light is flashing and the battery is new and good, I would think the stat is bad or like you said Coop, needs a reset...
Les
downtheroad
Pacific Northwest
Posted: 01/30/12 08:41am Link  |  Quote  |  Print  |  Notify Moderator
clicky Link
I wonder if it will control the high low fan speed.
I like the hi/low feature that I added to my digital using a SPST switch.
Agree with others...change the batt. reset it and forget about the red wire. If you really hate the red wire...cut it off.
GMC Duramax/Allison (LBZ)
Reese Dual Cam HP
