Woodalls Open Roads Forum: Travel Trailers: New dometic digital thermostat?
 > New dometic digital thermostat?
mlts22
Austin, Texas
Posted: 01/31/12 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
From another forum post, I found the owner's manual of this thermostat. It does support high/low/auto mode.
To boot, it supports switching the temperature tolerance between +/- 1 degree to +/- 2 degrees, so I can loosen the tolerance for better battery savings. (The fan motor stops and starts consume more energy than longer runs of the fan.)
(Edited -- here is the link to the PDF.)
* This post was edited 03/12/12 05:01pm by mlts22 *
bfast54
Traverse City ,Mi.
Posted: 01/31/12 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
FDAER wrote:
Here is the link to RVParts.com showing Model #3313189.000. It has a full description and priced at $103.00
RVPARTS.COM
Holy Cow...........a Hunter at the Hardware, home depot type store, is about $29.00.(give or take)
For that savings, I can install the toggle switch, and cut the red wire.
1994 Dodge Cummins Turbo Diesel,3500,Dually (Oh YEA )
2000 Cardinal 27RK LX
Prodigy Brake Controller
Honda EU3000is Generator
Raytek IR Thermometer,Garmin 1300 Nav./GPS
Doran Pressure Pro
VU Qube Satelite
Rally's attended so far-16
My Blog
rpegram
Eastern NC
Posted: 02/01/12 04:09am Link  |  Quote  |  Print  |  Notify Moderator
Hunter model 42995 $19.95 from Wally world and a $3.69 (had 2 in the package) micro slide switch from Radio Shack and now the new Jayco has a digital thermostat with high/low fan speed.
2011 Jayco 26RLS
'92 26' Starcraft TT
'96 Dodge 3500 CC, 12 valve Cummins
jackandh2o
Golden Valley, Arizona
Posted: 02/01/12 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
befast 54, I'm not sure but I think if you want high and low on the fan you will need the red wire.
Ray
cpaharley2008
york,pa
Posted: 02/01/12 02:05pm Link  |  Quote  |  Print  |  Notify Moderator
So these new digital thermostats not only give you a more accurate reading and less "swing" in the temperature, you can also adjust the amount of swing and convert a one speed furnace to a 2 speed ?
How does the 2 speed adjustment occur?
2009 Dodge Ram Hemi 4x4-7300- lifetime warranty
2011 Jeep Liberty Jet-1500-
picked up new 2012 Lance 1575 11/4/11
nights camped already=5
Coop44
utah
Posted: 02/01/12 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
The hi and low fan is only for the AC and not the furnace fan.
Oh and I figured out the problem on the battery low flashing.
You have to run reg batteries, and no rechargeable, something to do with the mercury in the STD batteries?
See ya Coop
2008 forest river sandpiper t272
http://coop45.webs.com/
coopsclutchmods@q.com
mrudolph9929
Paducah KY
Posted: 02/04/12 10:27am Link  |  Quote  |  Print  |  Notify Moderator
I have the dometic digital thermostat in my new camper, and I'm thinking of changing it out to the hunter that I had in my last camper. With the dometic you can't see what the current temperature is without turning it off...only then will it show the current temp. Hard to tell if everything is keeping up on a hot summer day. Otherwise it seems to work fine, I just miss being able to see current temp along with what it is set at.
TURBODOG1000
INDY
Posted: 02/05/12 01:05pm Link  |  Quote  |  Print  |  Notify Moderator
Coop44, rechargable (Ni-Cad) only put out 1.2 volts when fully charged. Regular AA batteries put out at least 1.5 to 1.6 volts.
2005 F150 XLT Supercab LB Heavy Payload 5.4, 4.10
2007 Jayco Jayflight 31BHDS
Back-up camera on the TT with infrared & microphone
Prodigy
ScanGauge II
Reese duel cam hitch, U-bolt style ($40 at a garage sale)
2 canoes, 1 kayak, & camping dog (Tootsie)
TURBODOG1000
INDY
Posted: 02/05/12 01:18pm Link  |  Quote  |  Print  |  Notify Moderator
Ok, what does the "control unit" do to add 72 bucks?
