Woodalls Open Roads Forum: Class C Motorhomes: My Next Modification
 > My Next Modification
magnusfide
montana
Posted: 02/02/12 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
Definitely going to get an Atwood On Demand Tankless Water Heater.
Being able to take a decent shower in the privacy of the RV ranks high on my comfort-meter. With the big travel plans for the next two years, this will be worth it.
Jeet yet? Keep on rollin'!
Magnus
Coalminer UG
Grande Cache Alberta
Posted: 02/02/12 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
I like it also but its a tad to much $ for me.
Ches
Served In Canadian Army 1PPCLI
Retired Underground Coal Miner (Gen Foreman)
campingliz
Bay Area, California
Posted: 02/02/12 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
It's not the hot water for us -- it's room in the gray tanks. We generally do not have hook ups, so it's Navy showers for us!
Happy Camping!
JUrban
Delaware
Posted: 02/02/12 08:52pm Link  |  Quote  |  Print  |  Notify Moderator
Has anyone used one of these things?
I noticed the ad was rather conspicuous by it's lack of any spec sheet. How much water does it heat, how fast? Temp rise @ GPM flow rate. Hook up requirements, gas line size and plumbing, compartment size, insulation, max temp, electrical requirements. A copy of the installation instructions and the operating instructions would go a long way to answer a lot. Many questions, few if any, answers. I don't buy a pig in a poke.
John
2008 Tiffin Allegro Bus 40' QSP
2006 Chevrolet Colorado Toad
BlueOx Aventa LX Tow Bar
SMI Air Force One toad brake
Copilot Live Laptop 10 GPS
Don & Linda
Western PA / Cape Cod
While in a site offering full hookup, it looks like dream come true.
You would think on a $950 unit the mfg might offer digital temp control, hence no need to balance the hot and cold. JMHO
Sorry if this post seems long, I lacked the time to make it shorter.
almost quote from S.L. Clemens
Don & Linda
1st RV UL EMS 4s Dome
2nd RV 21' AMF Scamper TT PV D300 Dodge
3rd RV National Seabreeze 133LX w/Demco Dolly
4th RV Jayco 2450 5TH PV Ford F-250 SD
oldtrucker63
Harlan Kentucky
Posted: 02/02/12 09:37pm Link  |  Quote  |  Print  |  Notify Moderator
I was thinking about the same thing, I did not know they made them that will fit the old water heaters spot, Do you know if these run off Electric and Gas...?? I'm ordering the tank water that runs off Gas or Electric or both, But I would love to have a Tankless if they run off both, This is a great upgrade.
Without Trucks,....America Stop's
PapPappy
Wilmington, NC
Posted: 02/02/12 09:50pm Link  |  Quote  |  Print  |  Notify Moderator
Here is a spec sheet for one model....that will fit right in the place of the old tank model.
For those of you who are looking for more information.....
Clicky
But more expensive ($1054.00), and it appears that it's only LP....I think that an electric unit would require more load than most RVs are able to handle with 30A service.
There are some units out there, that will run off 1500Watt heater, so would work on the 30A service, if you don't run anything else.....but they aren't really designed for the RV, though you may be able to make it work??
Bill & Claudia / DD Jenn / DS Chris / GS MJ
Dogs: Sophie, Abby, Brandy, Kahlie, Annie, Maggie, Tugger & Beau
RIP: Cookie, Foxy & Gidget @ Rainbow Bridge.
Purchased April 2008 FMCA# F407293
The Pets
pnichols
Santa Cruz Mountains
Posted: 02/03/12 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
The add for that Atwood unit seems to imply that it fits where your water heater goes. IMHO, it would be best if this could be added along with your water heater so you could still keep the the water heater for backup. Just keep the water heater turned off most of the time and use the Atwood instead.
I'd hate to rely on only the Atwood for hot water in the long run on RV trips. It's probably more complex than a water heater, hence more prone to failure and thus leaving you stranded if it should fail.
Phil, 2005 E450 Itasca 324V Spirit
Dusty R
Charlotte Michigan 48813
Posted: 02/04/12 05:34am Link  |  Quote  |  Print  |  Notify Moderator
We have never run out of hot water with the regular rv water water that came in our 24' mh.
Dusty
beachcomber_1
Alton, Illinois
Posted: 02/04/12 11:24am Link  |  Quote  |  Print  |  Notify Moderator
Our regular water heater is off most of the time. Never runs out when showering and turned on.
