Woodalls Open Roads Forum: Class C Motorhomes: My Next Modification
 > My Next Modification
Don & Linda
Western PA / Cape Cod
Posted: 02/04/12 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
oldtrucker63 wrote:
I was thinking about the same thing, I did not know they made them that will fit the old water heaters spot, Do you know if these run off Electric and Gas...?? I'm ordering the tank water that runs off Gas or Electric or both, But I would love to have a Tank less if they run off both, This is a great upgrade.
I'd doubt electric, wouldn't seem to be capable of enough btu's for such a short coil as the one they would have to use, given space restrictions. JMO
Dusty R wrote:
We have never run out of hot water with the regular rv water heater that came in our 24' mh.
Dusty
Your lucky, not having a wife/daughter team like I. They've complained about hot availability from both a 6 and a 10 gal unit.
Bordercollie
Garden Grove, CA, USA
Posted: 02/05/12 11:57am Link  |  Quote  |  Print  |  Notify Moderator
I suppose that a generous hot water supply with AC and water hookups would be nice if you/kids want to linger in shower, including ladies washing hair, like at home. Would save on propane.
magnusfide
montana
Posted: 02/05/12 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
That's what we're thinking. My wife has long hair and needs at least a 15-20 min. shower to wash it. Me I do my fair share of dirty work and need the extra time for the grime. This on-demand unit does run on propane but it only fires up when you turn on the hot water. No tank of water to keep heated.
Our current hwh is also a propane unit, no electric and it uses a lot of the LP to keep the water heated in the tank.
Jeet yet? Keep on rollin'!
Magnus
Kamphiker
South Florida (this 'aint paradise anymore)
Posted: 02/06/12 04:46am Link  |  Quote  |  Print  |  Notify Moderator
beachcomber_1 wrote:
Our regular water heater is off most of the time. Never runs out when showering and turned on.
X2
Even when the 3 of us take showers right after the other, The recovery seems acceptiable once heated up.
The only Plus I can see for a Tankless is it will produce initial hot water much faster than the standard tank models we now have onboard.
If I parked at one location for a long time and had full time sewer connection I could see more on the positive side for the tankless.
2006 Winnebago Outlook WF324V
2009 Honda CR-V 2wd TOAD ......Campgrounds in the Smoky Mountains NP
Last Camping trip ->2011 SUMMER SMOKY MOUNTAINS NATIONAL PARK
Handbasket
Asheville, NC
Posted: 02/06/12 07:56am Link  |  Quote  |  Print  |  Notify Moderator
I recall someone posting a few years back to the B forum with a newish Sprinter B with an instant WH. As I recall, the gripe was that it didn't heat the full flow of incoming water enough for comfort, if the water was fairly cold to start with.
It wasn't able to supply enough rise in temperature.
Fine, I suppose, for washing dishes, not so much for a shower in cold weather. I don't recall for sure, but think this was an LP-powered unit.
Jim, "One good turn.... gets most of the blanket."
