Woodalls Open Roads Forum: Toy Haulers: OUCH$$$ Fuel station pump
Search only in Toy Haulers
 > OUCH$$$ Fuel station pump
Dirtclods
Newport Beach
Posted: 02/03/12 09:04pm Link  |  Quote  |  Print  |  Notify Moderator
Ebay- http://www.ebay.com/itm/GPI-EZ8-RV-Fuel-........Trailer_Camper_Parts_Accessories&vxp=mtr
Securiti
Washington PA 15301 USA
Posted: 02/04/12 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
Tractor supply has them for 269.00
Pictures of all
1996 Dodge 3500
4.88 Gears
GearVender Transmission
Extra 115 Gal Fuel tank
Banks Power Kit
K&N Air filter
5 Inch Exhaust
2007 Wide Open Endura Max
dunerunnerjw
Norcal
Posted: 02/06/12 01:44pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks all for the tips.......I`ll definately rebuild or install a new one myself.
Updated: Talked briefly with the shop and he said the actual motor itself is bad. The model is PBL FP12. Told him to not touch anything as I`ll do it myself.
* This post was edited 02/06/12 02:50pm by dunerunnerjw *
Jerrybo66
AZ
Posted: 02/06/12 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
He may be right about the motor being bad but blown fuses aren't necessarily a sure indication of this. If the gears are swelled and the motor can't turn them it will blow a fuse. I would relieve the gears then try the motor. If it runs, it's a $40.00 fix... IMO... Good luck..
Support the Country you live in or live in the Country you support
2003 Sierra SP 26'Toy Hauler
1997 F-350, PSD, 4X4, red Crew Cab, long bed.
2007 Arctic Cat Prowler, Arctic Cat 500
mapguy
Puget Sound
Posted: 02/06/12 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
Without dis-assembling the pump end (gears) the bad motor determination is 50% right or wrong.
43Duc
SoCal
Posted: 02/06/12 11:56pm Link  |  Quote  |  Print  |  Notify Moderator
Either way, a new pump will be less than $300 and is easy to install yourself. My first failure was the swollen gears issue, but since my trailer was in for service anyway, I had it replaced under warranty. The new pump failed after 6 months. I thought it was the gears and didn't want to take it in. I popped the cover and found the gears to be just fine. I removed the pump and took it apart on my bench and found that one of the magnets inside the brush assembly had grenaded. I buttoned it up and took it to the dealer who sent it back to the manufacturer who replaced it under their warranty. They even shipped it back to me so I didn't have to drive to the dealer.
Do the work yourself. It's one of the easier things to fix on your rig.
-cb
2008 Weekend Warrior FB1900
2006 Ford F-150 SCREW
rehoppe
Denver
Posted: 02/07/12 07:41am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like your dealer is trying to make a 'house' payment.
Doubling the price, not only of the part, but the shipping as well.
Can it really be a 5-6 hour R&R?
Hoppe
2011 Dodge 1500 C'boy Caddy
dunerunnerjw
Norcal
Posted: 02/08/12 11:10am Link  |  Quote  |  Print  |  Notify Moderator
Stupid question but are RV fuel station pumps fairly universal? If Tractor supply doesn`t have the exact model I have will another that is similar do the trick? I ask only because I have the GPI FP12 and tractor supply carries GPI pumps but I don`t see the actual FP12 on their website.
* This post was edited 02/08/12 11:28am by dunerunnerjw *
BobWanderer
Perris,Calif,USA
Posted: 02/08/12 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
I don't see why not, just make sure the fittings will fit, size and location. And make sure its rated for gasoline. The rest can be easily modified to fit, the mount and wires.
Bob J
2008 GMC 2500HD 4X4 DMax CC LB
2004 Thor Wanderer Wagon 247WTB
2006 TE450 Husky
2007 Rhino Sport Edition
2008 KTM250XCF-W
Viewfinders M/C member
RETIRED !!
MaxspeedGSX1300R
NY
Posted: 02/09/12 03:00am Link  |  Quote  |  Print  |  Notify Moderator
My toy Hauler uses a Holly red pump, same thing used in cars, value at the mose is maybe $300.00 for the pump. You can remove it with a few simple tools. No way $1000. is in line, they are ripping you off!
2003 International 8500 with HT530 diesel and 10 speed standard, 2006 38' Coachman Adrenaline fifth wheel toy hauler, 2000 Suzuki Hayabusa GSX1300R, 2008 Suzuki B-King, 2008 Suzuki Bandit 1250S
Take it to the limit!
