Woodalls Open Roads Forum: Class C Motorhomes: CB on a Kodiak 5500
Open Roads Forum  >  Class C Motorhomes  >  Super C
 > CB on a Kodiak 5500
cncdude
Racine, WI.
Posted: 02/03/12 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
Where did you mount your CB antena. I'm thinking on top of the mirror but it's only plastic and the worrys me. Got any pictures.
Four Winds 33K
bbarbee
Glendale, AZ
Posted: 02/03/12 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
Mine was mounted right at the seam of the front overhang. Kind of hard to explain, (found a picture)....
This is the first time I have tried to post a picture so hope it comes out ok. The antenna is mounted just behind the drivers side door on top of the coach.
Guess I don't know how to post an image. PM me and I will send the picture to you.
Bob and Becky Barbee
2008 Seneca 34SS
2006 Colorado Crew Cab 4x4
ronfisherman
SE Michigan
Posted: 02/04/12 04:44am Link  |  Quote  |  Print  |  Notify Moderator
Mine is mounted on the driver side of cab over. Since everything is fiberglass I installed a non-ground plane antenna. Got it from CW. Not great for long range use. But works well for getting traffic info.
Kodiak Chassis Class C Forum
cncdude
Racine, WI.
Posted: 02/04/12 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
I thought about mounting it there but I was afraid it would keep hitting the side of the rig. Any problems with that?
ronfisherman
SE Michigan
Posted: 02/04/12 02:47pm Link  |  Quote  |  Print  |  Notify Moderator
Here is a picture of my install.
I have have RainKap on MH. Along with keeping black streak off side of MH. It keeps a antenna whip of side of MH.
seattleian
seattle
Posted: 02/08/12 11:59am Link  |  Quote  |  Print  |  Notify Moderator
I have no experience with CB's, so pardon the ignorance. Who do you talk to on them?
bbarbee
Glendale, AZ
Posted: 02/08/12 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
I mostly use my CB for listening to truckers about traffic conditions however, if I am traveling with another RVer, its really nice to be able to stay in communication with each other.
oldtrucker63
Harlan Kentucky
Posted: 02/08/12 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
Lot's of people have and use CB radios, Only if these new so called Truckers was more like they use to be, Back in the day you would hardly ever hear a bad word, Now day's turn it off when you approach a truck stop, What you hear on a CB is 90% of the reason I retired, If everyone was like they was back say before 1992 I would still be Trucking, It has gone down hill really bad. On the Interstate a CB is a must have, A great safty tool, You just have to look over all of the Children these day's.
Without Trucks,....America Stop's
oldtrucker63
Harlan Kentucky
Posted: 02/08/12 07:45pm Link  |  Quote  |  Print  |  Notify Moderator
The best way to make sure your SWR is right, Use a 4 FT Frances Antenna with 18 FT of the gray G58 coax With this the SWR's will be a 1 to 1 to a 1.5 mach with No Adjustments at all. The Frances Antenna is the Orange/Red White or black sold at all Pilot Truck stops
They come in 4 and 5 foot Get the 4 footer with 18 feet of coax and your set.
oldtrucker63
Harlan Kentucky
Posted: 02/08/12 07:50pm Link  |  Quote  |  Print  |  Notify Moderator
For the one's that might not know, The SWR reading needs to be right for a CB to work right, If not right the radio waves will run up and down the Antenna and not up and out the top tip into the air waves, This means you can not get out or receive like a radio should. The SWR is a must and has to be a 1.5 or lower.......1 to 1 match being the best.
