Woodalls Open Roads Forum: Travel Trailers: No CABLE TV in travel trailer
 > No CABLE TV in travel trailer
deltamaster
Middletown, New york
Posted: 02/06/12 12:03am Link  |  Quote  |  Print  |  Notify Moderator
For the short term if your refrigerator is on the awning side just pop off the access cover and plug in to the outlet provided for the refrigerator. Later on you could have someone tap off that circuit and put a waterproof outlet right next to that bay for the exterior outlet.
I ride it like I stole it!
.......and I just may have.......
I'm on "CB-13", are you?
2004 Fun Mover -- 2002 Sportster -- 1997 Road King
All being pushed down the road by a 1997 "Ram Tough" Dodge Dakota
TSgt(Ret.) USAF
TimOnTheRoad
Colorado-Maine
Posted: 02/06/12 12:13am Link  |  Quote  |  Print  |  Notify Moderator
If your worried about drilling holes they do make a flat cable that you can run out a screened window, you can still open and close your window as you would any other time, and makes a quick easy connection, camping world has them....
Wxguru
Austin,AR
Posted: 02/06/12 09:16am Link  |  Quote  |  Print  |  Notify Moderator
Or get you a nice digital antenna.....you should be able to get all...or most of your local stations if you are within a reasonable distance.....I know some of the games are shown on your cbs/abc affiliates
2011 Cherokee Grey Wolf 28A+KS
2003 Dodge Ram Quad Cab 4X2, 5.7L HEMI, 3.55 gear ratio
cpeters
Tennessee
Posted: 02/06/12 09:28am Link  |  Quote  |  Print  |  Notify Moderator
You are correct.. the camper already has a digital TV antenna with power boost. I get several stations in the driveway at home.
rydabyk
Florida Panhandle
Posted: 02/06/12 09:57am Link  |  Quote  |  Print  |  Notify Moderator
Our Heartland Focus was cable ready but did not have anyplace outside of the trailer to attach the cable, I was told after the fact that is was an option. My cable hookup was in the rear of the trailer under one of the bunks so I drilled a hole on the piece of wooden support on the bunk to get the cable to the power cord and then I fished the cable from the outside through the hole the power cord goes out and attached the cable to the power cord with zip ties. Since the cable hookup is usually near the electrical box it works perfect and there are no holes on the outside of the trailer.
wmoses
Houston, Texas, USA
Posted: 02/06/12 12:00pm Link  |  Quote  |  Print  |  Notify Moderator
skipnchar wrote:
I'm not sure I've ever seen any trailer without a port to plug a television cable into. If yours doesn't actually have one it would take almost no time at all to install one. Just find a place on the wall near your entertainment center and mount one at that point. Usually ALL trailers have one very easy place to gain entry for an additional coax port and that's the dog shower.
Good luck / Skip
Agreed.
While mine came with a coax input for cable, it was no good for satellite TV, so I installed another jack in the side of the RV.
Drilled the hole in the side of the RV behind the radio and installed the other interior jack in the bottom of the cabinet just below the radio.
Caulked around the fixture on the outside so no moisture gets in.
Got the cable outlet at Camping World for $12 or so.
Regards,
Wayne
2010 Jayco Jayfeather EX-Port 17Z | Tekonsha Prodigy P3 brake controller
2010 GMC Sierra 1500 SLE 5.3L Vortec V8 6-speed with Power Pack Plus Package | Hypertech Max Energy tune
_
extremis
BC
Posted: 02/06/12 02:10pm Link  |  Quote  |  Print  |  Notify Moderator
My Wildwood didn't come with that cable option either. Its just the way the dealer orders them. It does have the outside AC outlet, above the axles. For my Satellite TV, I use the little flat cable you can pass through the window and screen. Mind you I've only done that once or twice. Most of the time I don't bother as I have other things to do. In the evening, I more often than not put in a dvd instead of messing with the dish. Summer time TV is all re-runs anyways, I camp to get away from that.
the cable I bought off ebay. Got 6 of them for like $10 shipped a couple years ago.
Ole Man Dan
Gadsden, Alabama
Posted: 02/07/12 05:56am Link  |  Quote  |  Print  |  Notify Moderator
cpeters wrote:
I have seen that video.. you are right.. it was a $43 option. Funny, my 22RB has several options.. 2 door fridge/freezer, Shower surround, Tankless HWH, etc.. but not the cable TV. No big deal.. I can improvise.
Any opinion on drilling a hole through the floor?
Go in a window, or go thru a storage bay.
I went thru the front cargo hold for my satellite hook up.
My TV location is near enough to my front bed that I went under the bed
and into a drawer under the TV. I mounted permanent wiring so all I need is a 20' to 50' piece of RG-6 that I can use either for Cable
or for Satellite.
Trailer manufactures cut corners on things like cable hook ups.
cpeters
Tennessee
Posted: 02/07/12 06:45am Link  |  Quote  |  Print  |  Notify Moderator
I think I have decided (for now).. to go through a window.. using the flat coax.. Not gonna start drilling.. just to watch TV.
