Woodalls Open Roads Forum: Built a new battery rack, what do you guys think?
 > Built a new battery rack, what do you guys think?
tzclark
Chilliwack
Posted: 02/05/12 09:08pm Link  |  Quote  |  Print  |  Notify Moderator
Upgraded my 12v system by adding this extra battery rack. I was running 1 battery before so 3 is going to be awesome. These batteries were ones i had kicking around, I have 3 new matching ones. I dont think my furnace will have issues now running through the night.
http://flic.kr/p/bpjZuP
I'd rather be in a boat with a drink on the rocks, then in the drink with a boat on the rocks!
kayco53
bc
Posted: 02/05/12 09:19pm Link  |  Quote  |  Print  |  Notify Moderator
New approach to the battery mount set up.
Looks like it should work fine.I know my two 6v batteries are a tight fit.
2007 GMC 2500hd
2011 Creekside 23RKS
Lowsuv
Oregon
Posted: 02/05/12 09:42pm Link  |  Quote  |  Print  |  Notify Moderator
Good Concept.
If you search the battery hookup threads you will find the most efficient method to hook these batterys together.
Not all parallel hookups are equal.
Hook up your charging system with the Positive terminal on the left battery and the negative terminal on the right battery.
The concept is to balance your batteries by making ALL of the current flow through ALL of the plates.
With my trailer the critical voltage is the refrigerator electronic monitor system that modulates the refer when on propane.
The proper hookup has been posted on here several times and makes a difference if you have 3 , 4, or more batteries.
Here is the hookup procedure:
http://www.smartgauge.co.uk/batt_con.html
* This post was edited 02/05/12 10:39pm by Lowsuv *
deltamaster
Middletown, New york
Posted: 02/05/12 11:55pm Link  |  Quote  |  Print  |  Notify Moderator
If you wanted to you could make that top tray longer and put another one up there! you could have a bank of four!
I ride it like I stole it!
.......and I just may have.......
I'm on "CB-13", are you?
2004 Fun Mover -- 2002 Sportster -- 1997 Road King
All being pushed down the road by a 1997 "Ram Tough" Dodge Dakota
TSgt(Ret.) USAF
Golden_HVAC
Fulltime, CA, USA
Posted: 02/06/12 12:15am Link  |  Quote  |  Print  |  Notify Moderator
I am not sure where you get your propane tanks refilled, yet the tank is out of date, and not the kind with automatic shut off once full. New style tanks have three lobes in the handle, not 5 as shown in your picture.
Looks like a good rack, yet it seems difficult to refill the lower rack battery with water, and you really should be checking this every 3-4 months. I guess you can check the outer cells, and then when they become low, remove the top battery and put water in all the cells.
To heat my RV in the winter, I normally use my Olympic Catalytic Safety heater. I leave all three roof vents open about 1/4" and the window near the kitchen sink about 3/8" wide.
By the way, if you really want to "Share" the pictures, why did you copy protect them?
Have fun camping!
Fred.
nitrohorse
pa
Posted: 02/06/12 03:50am Link  |  Quote  |  Print  |  Notify Moderator
Do you plan to use battery boxes too? I might be too old school, but I like my batteries protected from road hazards and the elements. I do like your creativity in the arched second story for the lone battery.
Artemus Gordon
Redding California
Posted: 02/07/12 10:19am Link  |  Quote  |  Print  |  Notify Moderator
Looks great. The collective ideas I see on RVnet never cease to amaze me!
2012 Montana 3750 Hickory Edition, 2003 Ford F450, 4x4 off Road, 7.3 liter, Air bags, Longbed Dually. Curt Q24 hitch, Moride pin box, P3 Brake Controller
2012 3750 Montana
pnj442
Cedar City, Ut
Posted: 02/07/12 10:23am Link  |  Quote  |  Print  |  Notify Moderator
That's a lot lot of tongue weight !
Bearhawk
Away up north
Posted: 02/07/12 10:04pm Link  |  Quote  |  Print  |  Notify Moderator
I have three Group 31's accross my tongue and you will like the extra juice. Add an inverter and your good to go anywhere.
Bearhawk (n): A Plansbuilt Amature Aircraft. An expensive hobby that was replaced by 2007 29FBS Jayco Jayflight G2 & 2008 F350 Crew with 6.4L Diesel
At least this adventure flew off the drawing board and running out of fuel is not as dangerous!
beemerphile1
I'm only 57, I'm not yet a
Posted: 02/08/12 06:26am Link  |  Quote  |  Print  |  Notify Moderator
It looks real good but won't it be hard to service, remove, or replace the bottom batteries?
Tim
If you aren't paranoid, you aren't paying attention!
2006 Weekend Warrior FK1900 towed by 1998 Ford E150 4.6L = 8 MPG
2009 Aliner Sport towed by 2009 Pontiac Vibe 1.8L = 22 MPG
1996 BMW R1100GS
