rehoppe
Denver
I suffered the inverse of normal on the camber adjustment bushings. The MDT Ford dealer said YES, we have them in stock and install them on a regular basis, However our front end man is injured and may be out for a while.
They recommended an Independent Tire shop just up the street. I took the MH to that shop, telling them that I wanted the bushings if needed. They took about 45 minutes to align it and told me it was out of alignment and that I didn't need the bushings. That it had adjusted just fine without them. They however didn't get the camber into it as I requested, haven't had it on a trip since so not sure if it's acceptable or not. If not, I'll just consider the money 'flushed' and take it to the Ford MDT dealer, for a proper fix.
Having said all that. YOUR mileage may/will vary.
Hoppe
2011 Dodge 1500 C'boy Caddy
