Woodalls Open Roads Forum: Clear, oily liquid on floor under kitchen cabinets
 > Clear, oily liquid on floor under kitchen cabinets
runningstart
Oro Valley, AZ
Posted: 02/06/12 11:06am Link  |  Quote  |  Print  |  Notify Moderator
2011 Itasca Impulse 26 ft. class C. We are finding a clear, oily liquid on the floor beneath the kitchen cabinets, near the converter. Sometimes we will see just a small puddle, and other times it it is enough to spread across the floor to the dinette. One shop replaced the converter, saying it could be fluid from the coils. That was not the issue, as the problem continues. We recently had the propane tank filled, and have used the motorhome 3 nights since then, with use of the furnace only at night. This morning the levels tester said the propane tank was 1/3 or less full. Could this be a broken propane line? Any other suggestions? The shop says they have never seen this before, and don't know where the fluid could be coming from. Has anyone experienced this?
PaulJ2
Northwest Oregon
Posted: 02/06/12 12:31pm Link  |  Quote  |  Print  |  Notify Moderator
I would look up, maybe coming from roof air?
Mandalay Parr
Phoenix, AZ
Posted: 02/06/12 12:33pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe Hydraulic oil from your leveling system, slides, etc.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
602-321-8141
randrx2
Newport News, VA
Posted: 02/06/12 01:55pm Link  |  Quote  |  Print  |  Notify Moderator
What else is in the area? Have you taken the drawers out and looked around with a flashlight? Did something roll behind a drawer and is leaking out?
When someone says, "I'm not book smart, I'm street smart." All I hear is, "I'm not real smart, I'm imaginary smart."
crasster
Dallas
Posted: 02/06/12 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
I'd say hydraulic oil. Is there one near the cabinet?
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
btcruzer
Missouri
Posted: 02/06/12 10:47pm Link  |  Quote  |  Print  |  Notify Moderator
check your cooking oil container.
Old-Biscuit
Across the USA
Posted: 02/06/12 10:52pm Link  |  Quote  |  Print  |  Notify Moderator
Guessing is tough without seeing it, where it is and what is around/above it.
BUT I hope you are getting a refund/huge discount on that 'not needed' converter!
Maddawgs
central MA
Posted: 02/07/12 05:02am Link  |  Quote  |  Print  |  Notify Moderator
Hi, it is a 2011 Itasca so it is most likely still under your 1 year warranty. If so the bring it back to your dealer or closest certified repair center and have them fix it. It could also very well be that something fell out of one of the drawers or cabinets and is now leaking.
Todd
Todd, Shirley, and the "Maddawgs" min-pins Precious and Buster Brown
2011 Itasca Cambria 30C
2011 Demco KarKaddy 460SS
TST 507 RV TPMS
"if there is anything left when we are gone, then we miscalculated"
nagel
Missouri
Posted: 02/07/12 05:19am Link  |  Quote  |  Print  |  Notify Moderator
Near any plumbing? Could it be from a cracked drain? Sometimes the goo coming out of drains can be slimy due to the oils and soaps.
When they fill propane tanks they fill them to 80% to allow for expansion. Might be why you are seeing it lower than you thought.
Snagel
Steven R. Nagel
NRALIFR
Truck Camping Out West
Posted: 02/07/12 05:51am Link  |  Quote  |  Print  |  Notify Moderator
The oily substance that comes out of LP systems is typically brown, and there's no doubt about where it came from. It stinks to high heaven! And, where you will usually find this LP goo is in the lowest point of the lines prior to the regulator. My understanding is it's an accumulation of the odorant (methyl mercaptan) that's put in LP gas so we can tell when there's a leak. It may pick up the brown coloring from the rubber hoses used between the tanks and regulator.
Not sure what yours is, but it doesn't sound like it's from the LP system.
2001 Lance 1121, 1995 F350 7.3 PSD CC DRW with many mod's and upgrades (see profile page). Over 200,000 miles and still going strong!
