Woodalls Open Roads Forum: Towing: Tire Pressure Question
Search only in Towing
Open Roads Forum  >  Towing
 > Tire Pressure Question
DGriz
Central California
Posted: 02/07/12 08:29pm Link  |  Quote  |  Print  |  Notify Moderator
The vehicle manufacturer recommends 37 lbs of pressure in my tires but my tire manufacturer says 50 lbs is max. Should I be adjusting my tire pressure when towing?
DGriz
2009 Jeep Wrangler Unlimited Rubicon
2011 KZ Spree Escape 196S (19')
donn0128
Pronounced Ore-gun
Posted: 02/07/12 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
When towing I always inflate to max as listed on the tires sidewall.
Donn,Lorri,Max (rescued Lab)
mowermech
Billings, MT
Posted: 02/07/12 08:45pm Link  |  Quote  |  Print  |  Notify Moderator
Chances are the max pressure is for max allowable load. Is the load on your tires really that heavy?
Just as an example, my '06 Jeep Rubicon came from the factory with Load Range E tires on it. Jeep says inflate to 33 PSI for normal road use. The tire sidewall says to inflate to 80 PSI to carry the maximum load.
Since there is no way I can ever put enough stuff in the Jeep to get to the maximum load for the tires, I follow the instructions given by Jeep.
To directly answer your question about adjusting tire pressures when towing, all I can give is a definite MAYBE!
Adjust the pressure according to load. You want the tread flat on the road, not bulging in the middle or riding on the edges. Use the pressure that will give you the flat tread.
CM1, USN (RET)
'94 Dodge 3500 4X2 CTD, 5 speed, 4.10 LS diff., Jacobs Rambrake, 275,000 Miles
'95 Tioga 29H Ford-based Class C
Daily driver: 2005 Jeep Grand Cherokee Hemi
Toad: 2006 Jeep Rubicon LJ
Jim2007
Greeley, Colorado
Posted: 02/07/12 08:47pm Link  |  Quote  |  Print  |  Notify Moderator
Hi: I inflate my tires to the max.(shown on side wall) when I head out to camp.
Happy Camping. Jim2007
TV: Dodge 2004 Diesel
Rig: 2004 Flagstaff 5th Wheel 30'
Old-Biscuit
Across the USA
Posted: 02/07/12 09:32pm Link  |  Quote  |  Print  |  Notify Moderator
Really depends on how much load tires are having to carry........
50# sounds like MAX PSI for MAX LOAD capability
37# sounds like 'normal' running around tire pressure
How much weight on tires when towing? Trip to scales will tell you (Jeep & trailer)...with that info you can see what tire mfg. load chart(s) indicate.
smkettner
Posted: 02/07/12 10:41pm Link  |  Quote  |  Print  |  Notify Moderator
I go at least 5 over not to exceed sidewall max. Trailer I run sidewall max.
2001 F150 SuperCrew
675 watts solar
SoCalDesertRider
SanDiego, CA, USA
Posted: 02/08/12 02:04am Link  |  Quote  |  Print  |  Notify Moderator
At least run your rear tires at the 50 psi max pressure when towing. Won't hurt to run the fronts at 50 psi too, but 40-45 is likely enough.
05E350 6.0PSD
97F350DRW 7.3PSD 4x4 4.10 11' flatbed
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
BarneyS
S.E. Lower Michigan
Posted: 02/08/12 06:45am Link  |  Quote  |  Print  |  Notify Moderator
My rig handles best when I run 80lbs in the rear and 75 in the front. (load range E tires-80lb max)
Barney
Hensley "Arrow" 1400# hitch
Visit our website here
KD4UPL
Swoope, VA
Posted: 02/08/12 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
Weigh the vehicle. Calculate the load on each tire. Look up the tire manufacturers load inflation table. Inflate accordingly.
Sinterior
Kamloops BC
Posted: 02/08/12 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
Towing I use the doorpost inflation guide, 60 front 80 rear as I'm fairly close to, but not over GVWR, not towing it's 50 front and 40 rear, a much better ride and still within weight guides.
Pete
Terry
2011 Chev 3500HD 4X4 C/C S/B D/A SRW
2011 Montana 3665RE
Hijacker 21k Ultra slide double pivot hitch
Pressure Pro
Garmin dezl 560LMT
