Woodalls Open Roads Forum: Towing: Tire Pressure Question
Search only in Towing
Open Roads Forum  >  Towing
 > Tire Pressure Question
AZ T&T
Mesa, AZ
Posted: 02/08/12 08:08pm Link  |  Quote  |  Print  |  Notify Moderator
Max
AZ T&T
2012 Jayco Eagle Super Lite 29.5RKS
2011 Chevy 2500 HD 4x4 Duramax
B&W Companion Hitch - Firestone Ride-Rite Air Bags
Honda EU2000i Generator
LTCLarry
Maggie Valley, NC
Posted: 03/15/12 12:37pm Link  |  Quote  |  Print  |  Notify Moderator
Barney, Where do you keep the pressure when not towing? Just put new Michelin LTX M/S-2 on. Max pressure is 80.....Chevy says 50 front 80 rear on the door sticker....tire dealer says 65 front 80 rear.....prior to the tire change I had been following manufacturer...all the time so the rears were always at 80.
2008 Silverado 2500 HD
2010 Aerolite 24rbs
BarneyS
S.E. Lower Michigan
Posted: 03/15/12 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
I don't change the pressure between towing and not towing. I keep the fronts at 75 and rear at 80. I do keep a bunch of "stuff" in the back of my truck all the time however, and also have a cap on the back which is heavy. In addition, my truck is a 7.3L diesel which is quite heavy. I find the ride acceptable while not towing. I use the truck only for towing, but it is our daily driver while wintering in Florida for at least three months every year. I do not get any unusual tire wear.
Barney
Hensley "Arrow" 1400# hitch
Visit our website here
LTCLarry
Maggie Valley, NC
Posted: 03/15/12 05:26pm Link  |  Quote  |  Print  |  Notify Moderator
Barney,
Thanks, that confirms what I was doing previously and so I'll just continue on leaving the pressure the same all the time.
dmax_83
Kenosha, Wisconsin
Posted: 03/15/12 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
I would follow the manufactures instructions. Otherwise you can always use a load/inflation table that can be acquired from the tire manufacturer. To use this you need to weigh your tt and then adjust the tire pressure according to load. I am going to assume that the tt manufacturer has done this already using the tt's gross weight to cover themselves for liability sake.
1998 Jayco Eagle 302FK (Honda EU3000is)
2011 GMC Sierra 2500HD 4x4 Duramax/Allison
2003 Honda Aquatrax F-12X Turbo
Jazzdrummer60
Botkins, Ohio
Posted: 03/18/12 02:38pm Link  |  Quote  |  Print  |  Notify Moderator
Almost all of the tire failures I've heard about were caused by "under-inflation," or "over-loading." Never heard of one that was caused by "inflation to maximum pressure listed on the sidewall." I always keep my tires inflated to the maximum listed on the sidewall of the tire.
dmax_83
Kenosha, Wisconsin
Posted: 03/18/12 06:33pm Link  |  Quote  |  Print  |  Notify Moderator
While I agree with the above statement in regards to under inflation causing problems, overinflation reduces the contact area of the tires which is also unsafe, it also wears the tire faster and creates an un-necessarily bumpy ride. The PSI listed on your door jam or on the info tag on your camper lists a pressure that the manufacturer deemed appropriate, the listing on your tire sidewall is the pressure that the tire manufacturer has deemed maximum.
