Woodalls Open Roads Forum: Class C Motorhomes: Leveling
 > Leveling
YWORRYDOG
GRAND RAPIS, MI, USA
Posted: 02/08/12 06:12am Link  |  Quote  |  Print  |  Notify Moderator
We are moving up from a TT to a small class C. Leveling was always a big thing, so what do you do? Do you have bubble levelers in the cab?
mod ed: Corrected ALL CAPS in title.
* This post was edited 02/08/12 08:43am by an administrator/moderator *
CHUCK and ROSE 2010 Sunseeker
We camp on earth
WyoTraveler
Powell, WY
Posted: 02/08/12 06:34am Link  |  Quote  |  Print  |  Notify Moderator
Of all the RVs I've owned. MH, TC, 5Ver, and now a TT, IMO the TT & 5Ver were the easiest to level quickly. Place something under the low wheel and raise or lower the tongue to level. If you had trouble leveling a TT you may want to get those automatic levelers. Just a push of a button.
Curt class V hitch
AC6CV/7 ex-W8RUR since 1954
mikeleblanc413
Sour Lake, Texas
Posted: 02/08/12 06:46am Link  |  Quote  |  Print  |  Notify Moderator
This has been covered several times and there are some good suggestions in the FAQ...there were also some excellent ideas in recent posts...someone may come on and give better direction to the posts...most centered around using bubble levels and leveling as much as possible from within the cab as you drive in to the site.
Mike LeBlanc
Retired Educator, Texas Certified Art EC-12, Professional Photographer
Sour Lake, Texas
Facebook
Flicker
2000 Minnie Winnie DL, 429U, V10,
Cooper ATR, Bilstein HD Shocks, Steer Safe,
TireMan, Pressure Pro TPMS, EMS-PT 30C,
SportRack Bicycle Rack
sbishop
Eagle Rock, CA
Posted: 02/08/12 07:02am Link  |  Quote  |  Print  |  Notify Moderator
I agree with leveling by feel and sight as you drive into a space, I have driven in and out of a space or two and decided it was just too far off to level. I use the three level plank method and very seldom have a problem. I use a little "T" level set in a certain place on the counter by the sink when leveling. Followed Dometic's advice and leveled the MoHo using the level on the bottem of the fridge and then found a spot that was more convient to use that had the same readings as the bottem of the fridge.
I drive into a spot, if it feels good driving in, I stop and I set there and feel the level and then go out and put down the planks and return and drive up on them. If it feels within acceptable limits, I ask the DW to get the level out and take a reading, if she gives me the okay I park it. If she thinks it's too far off, I look and decide what adjustments to make. It's kind of a Zen thing, you know kind of like how Jerry Brown governs California.
I was in the home building and remodeling trade for years and you get a feel for level after awhile. We have an A and there is no good place for a level in the cockpit area and I think that is true of a C.
Hope you get some good answers here that work for you and Good Camping.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
1990 Bounder 27D
1995 Suzuki Sidekick 4X4
Stowmaster 5000
wolvereeny
SE Michigan
Posted: 02/08/12 07:26am Link  |  Quote  |  Print  |  Notify Moderator
I placed one small bubble level on the drivers door and one on the dash. I use that to get it close, then check it again in the coach area. We use Lynx levelers if we need to.
* This post was edited 02/09/12 06:28am by wolvereeny *
CA Traveler
The Western States
Posted: 02/08/12 07:31am Link  |  Quote  |  Print  |  Notify Moderator
I had the level where I could see if from the drivers seat. I quickly learned where to place the boards and was very successful leveling the first time.
But first level the refer (dead level) using a level. Then mount the bubble level.
2009 Holiday Rambler 42 Scepter with ISL 400 Cummins
2004 Honda CR-V
Bob
CA Traveler
The Western States
Posted: 02/08/12 07:32am Link  |  Quote  |  Print  |  Notify Moderator
snowdance
Yreka, Ca
Posted: 02/08/12 08:36am Link  |  Quote  |  Print  |  Notify Moderator
We have bubbles we can see from the drivers seat. They are in the coach. However in most of our travels we only really worry about being real level when camping. In general when traveling as long as we can move around in comfort and the coffe cup does not fall off the table its Ok for rest stops ect.
Our bubble level have the marks and show us some where near how many inches we need to add to the boards. Never takes long.
Snowdance
We spent most of our money traveling... Just wasted the rest..
Chevy 7.4 Vortex
2000 Jamboree 23b Rear Kitchen
http://www.flickr.com/photos/snowdance38
tenbear
Northern Vermont, USA
Posted: 02/08/12 11:48am Link  |  Quote  |  Print  |  Notify Moderator
We use these Hoppy levels which are mounted where the driver can see them. Find the most level spot before you try to level the MH with planks or whatever. I don't try for absolute level, within an inch or 2 is good enough. If it feels good it is good enough.
Class C, 2004/5 Four Winds Dutchman Express 28A, Chevy chassis
2010 Subaru Impreza Sedan
Camped in 45 states, 7 Provinces and 1 Territory
YWORRYDOG
Posted: 02/08/12 03:37pm Link  |  Quote  |  Print  |  Notify Moderator
thanks all, I have no problem getting the TT level, my concern was where to put bubble levels so that I could see them in the cab now that we have a motor home.
 > Leveling
