Woodalls Open Roads Forum: Toy Haulers: fresh water tank not filling
Search only in Toy Haulers
 > fresh water tank not filling
kjk66ss
chatsworth
Posted: 02/09/12 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
when i suck the compresor nozzle 2 inches into the vent, and sealed the opening with a rubber gromet. the hose almost blew,which meant no aire whatsoever passed thoough.
ill check for kinks tomorrow. i have to lower one end of the tanks in order to get to the top.
1L243
Astoria, Oregon
Posted: 02/09/12 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
with the vent at the top of our tank I don't think you will be able to hear air bubbles or get a siphon. I have read where some got tired of loosing water out of a vent with a full tank that they put a shut off valve on the vent line. Your rig was used did you see anything like a valve on the vent tube? Have you tried checking with the original owner and see if he knows whats going on? Might save you some time..
kjk66ss
chatsworth
Posted: 02/10/12 08:50am Link  |  Quote  |  Print  |  Notify Moderator
ok found the problem!! what can i do to fix it. 2 pictures are just a general shot of the tank and the one with the hose you can see the kink.
kjk66ss
chatsworth
Posted: 02/10/12 09:00am Link  |  Quote  |  Print  |  Notify Moderator
i was thinking of replacing the plastic fitting with a 90*
kjk66ss
chatsworth
Posted: 02/10/12 09:11am Link  |  Quote  |  Print  |  Notify Moderator
or if i can find a 45* elbow that might work better?
nayther
Burbank, CA
Posted: 02/10/12 09:29am Link  |  Quote  |  Print  |  Notify Moderator
Yep, put a 90 into the tank should be fine, there's no flow so pressure drop isn't an issue. Can you get in there to spin in a 90?
DIRT BIKES RULE
'12 Duramax CC short bed
'06 3005 Rage'n Falcon
kjk66ss
chatsworth
Posted: 02/10/12 10:12am Link  |  Quote  |  Print  |  Notify Moderator
yeah i can just barley squeeze my hand in their. so ill try the 90. hopefully i wond have to do anything else.
