Woodalls Open Roads Forum: Class A Motorhomes: Winne-will not start
 > Winne-will not start
Page of 13
Daveinet
il
Posted: 02/09/12 07:06pm Link  |  Quote  |  Print  |  Notify Moderator
DANDEAKINS wrote:
....It will not plugged up and using the starting switch. I will buy a circuit checker tomorrow to read the fuse connections and any other that i can see. Also all the other things Ya'll suggested. THANKS GUYS VERY MUCH !!!!
DANDEAKINS wrote:
...When I turn on the switch the fuel pump does run a few seconds and stops. turn switch off wait awhile back on and it repeats. I am going out now and break the fuel line coming in at the throttle body and see if any fuel is coming through. Tks again guys.
These 2 quotes seem to be in conflict with one another.
Here is the pinout for the 7427 ECM. The fuel pump relay is pin F6
Link to all of the pinouts:
ftp://ftp.diy-efi.org/pub/gmecm/manuals/16197427/
So even if the pump is not running, you can monitor the pin and see if it changes state when the ignition is turned on or when you are cranking.
* This post was edited 02/13/12 04:56pm by Daveinet *
Dave
The Flying Fortress
FMCA F298817
'83 Revcon Prince 31' FWD
502 w/Howell/GM 16197427 ECM/Edelbrock MPFI,Thorley's & Magnaflows,
4L85E 4 speed, KoniFSD,
6% grade = wanna drag?
MISC photos
Revconeers Forum
Stim
NE Florida
Posted: 02/09/12 09:42pm Link  |  Quote  |  Print  |  Notify Moderator
The oil pressure switch that turns on the fuel pump when there is pressure is known to fail on GM boat engines. I had to change the one on my 4.3. With the boat engines the wires to the switch can be jumped with a paper clip. It should be the same switch. Mine was located at the left rear of the block above the pan.
If there was a problem with the ECM it would not run on starting fluid.
PaulJ2
Northwest Oregon
Posted: 02/09/12 11:56pm Link  |  Quote  |  Print  |  Notify Moderator
It dosen't have the GM pass key anti theft system does it? This system has to recognize the correct key or it won't fire the injectors. Used on many trucks and cars but I don't know about MH's.
cwit
Upstate New York
Posted: 02/10/12 05:48am Link  |  Quote  |  Print  |  Notify Moderator
I would change the fuel pump relay from all you have done.
crankshop1000
se michigan
Posted: 02/10/12 07:05am Link  |  Quote  |  Print  |  Notify Moderator
Just because you have fuel pressure doesn't mean that you have enough fuel pressure.You need to check the pressure with a gauge when you first turn the key on.The pressure must be within factory specs or it simply will not start. This should be the very next thing you do as it sounds like you have already done the basics.You know the engine will fire if you add fuel,you can verify the pump circuits are functioning,but you don't know the pressure. If the pressure is within specs,the next check will be the computer which drives the injectors.
DANDEAKINS
CHATTANOOGA
Posted: 02/10/12 08:53am Link  |  Quote  |  Print  |  Notify Moderator
WOW--------LOOKS like another fun day!!!!!!!! I will keep all of you informed this evening. THANKS GUYS
Clay L
Sioux Falls, South Dakota
Posted: 02/10/12 09:34am Link  |  Quote  |  Print  |  Notify Moderator
As a retired mechanic you might be interested in the service manual for the P30/454.
You can download it HERE.
Clay (WA5NMR), Lee (Wife), Katie (cat).
Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
RCtime
So. Calif.
Posted: 02/10/12 10:51am Link  |  Quote  |  Print  |  Notify Moderator
Gotta like you, just bought a new rv and it poops out, no harping or, oh woe is me, just digs right in to fix the problem.
Good luck to you and welcome to a a great forum.
Ron
2002 34HD Winnebago Journey DL, Cat. 330/freightliner
2004 Honda CRV - Garmin 1490t
Great wife & Cavalier King Charles Spaniel
TT/N
DANDEAKINS
CHATTANOOGA
Posted: 02/10/12 05:05pm Link  |  Quote  |  Print  |  Notify Moderator
Hey RON and the rest of the gang. Man what a day. Starting to get cold here in the south. Expecting some snow here tonite. I ran a little heater to the mh this morning and went to work.
OK Gang Here goes---I bought a circuit tester today and checked the fuse box under the dash pod. All circuts are good and all fuses are good.
Hey Clay, I have printed out the manual. It has helped me a lot. I purchased a new distributer cap and rotor button and had the module checked under the cap and it checked good.
Hey Daveinet, sorry to confuse you---oeekeedoekey here goes-- When i unplug the wiring to the fuel pump at the top of the fuel tank and put 12 volts to the fuel pump side with a battery the fuel pump delivers fuel thru the pump, filter all the way to the throttle body. When i reconnect the wiring at the fuel pump and turn on the key the fuel pump runs a couple of seconds, but no fuel to the throttle boby.
Now the progress report-- Still no start with new battery, distruber cap and rotor button.
Thanks to the chilton manual, i printed out the fuel relay. I have a new fuel relay in hand, but yet not found it. I know the colors of the wiring that goes to the relay,BUT a problen?? There are two relays under under the dash pod that this relay will fit. Neither is the right one according to the wiring.
Thanks Gang for staying with me, tired-- going to get me a homemade burger, fries and big old dill pickle,(canned myself) See YA'LL in the morning. GOD BLESS
2bzy2c
California
Posted: 02/10/12 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
Just my 2 cents and I don't mean to further confuse you, but if the engine started with ether (starting fluid), then why do anything with the ignition system, meaning the distributor cap, battery etc? Everything points to a fuel delivery problem.
My advice is worth exactly what you paid for it.
Page of 13
