Woodalls Open Roads Forum: Fifth-Wheels: odor in black tank
Search only in Fifth-Wheels
 > odor in black tank
rolnhome
Casa Grande, Az
Posted: 02/09/12 10:40pm Link  |  Quote  |  Print  |  Notify Moderator
The roof vents mod solved my problem. It a could be a grey tank problem has he flushed his grey tank.
We're in Arizona
biljo99
Bonaire, Ga, USA
Posted: 02/10/12 05:27am Link  |  Quote  |  Print  |  Notify Moderator
Do a google search on "the geo method"
2008 Ford F450 CC PSD LB DRW 4.30 Moonroof King Ranch 6.4 auto Tow Boss Navigation Sirius/XM radio Audiophile
Transfer Flow 70 Gallon tank with Monitor
Reese 20K hitch
2009 Elite Suite 36RSSB3/4 #5008
Dave H M
IL
Posted: 02/10/12 06:12am Link  |  Quote  |  Print  |  Notify Moderator
where exactly is the odor coming from
jwakeman
Johnston, IA
Posted: 02/10/12 10:36am Link  |  Quote  |  Print  |  Notify Moderator
Same problem with our cedar creek and friends trailer did the same.
Narrowed problem to a vent (gray water) for washer drain hookup. There is a vent after the P trap and well hidden. Put a plastic bag and zip tie over the vent,problem solved.
Seems to be a common Forest River problem.
2003 Silverado LS 2500HD 4X4 Extended Cab Duramax Diesel/Alison
2012 Cedar Creek 36RE
kcgaz
Scottsdale, Arizona
Posted: 02/11/12 11:11am Link  |  Quote  |  Print  |  Notify Moderator
I installed the new vortex vent yesterday and I located both of the vents, one in bathroom and one under the kitchen sink. I am trying to figure out what these vents do and how they go bad. Jwakeman said in his post that he placed a plastic bag with a zip tie over it and his smell problem was over. Will placing a bad over a vent cause some other upstream problems? Would I be better off purchasing a new vent at the hardware store? I am presuming that the spring gets weak and lets the smell into the MH. Would love to rid our rig of the bad smells, but don't want to cause other issues. Thanks in advance for your advice.
God Bless,
Kevin & Tracy
1993 Fleetwood Tioga Arrow, 30', Ford 460...Still on the road!
My Blog
xPIXx
Midwest
Posted: 02/11/12 04:03pm Link  |  Quote  |  Print  |  Notify Moderator
Those vents are like $3 at Lowes why not just replace it?
sh410
Northwest
Posted: 02/11/12 04:11pm Link  |  Quote  |  Print  |  Notify Moderator
The valve under the sink is a air admitance valve. It is a one way valve that will allow air into the drain system so that when you dump the grey tank it will not create a vacuum and draw the water out of the p-trap. They do fail and become a unwanted two way valve.
They can be easily replaced. They are a screw on device you can pick up at home depot or any plumbing store for less than $5.
kcgaz
Scottsdale, Arizona
Posted: 02/12/12 08:45pm Link  |  Quote  |  Print  |  Notify Moderator
Installed the Cyclone roof vent and the two under sink vents as recommended in these threads. The under sink vents cost $2.92 each at Home Depot, I will let you know if they make a difference!
bpounds
Whittier CA
Posted: 02/12/12 09:00pm Link  |  Quote  |  Print  |  Notify Moderator
Your black tank is going to smell, and no amount of cleaning is going to make it not smell. Same with the gray tank. So the problem is not the tank. As others said, it is a vent problem. Tell your friend to forget trying to clean the tanks, and inspect all the vents and traps.
Bill and Carol
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
Bachus
Stratford, Ontario, Canada
Posted: 02/13/12 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
My father in law had the same problem in his TT. If he sits on the throne, really bad smell, but it doesn't happen for his DW. So last year, I sit on his throne, and have the really bad smell. So what's the common denominator? Weight. He weighs about 230, and I'm about 210. Mother-in-law is maybe 125. I figure when the big boys sit down, the floor and or seal deforms, and opens a path to the black tank. Bad enough to make a billy goat puke. He changed out the floor seal, and that solved the problem, although I think the real problem is the floor flexing. Just a thought.
Dean and Tracy Bachellier
Isobel,Evelyn, and Stuart
2012 KZ Durango D355BHS quad bunk with 5 slides
HiJacker 16K double pivot slider
2011 RAM 3500 SRW Crew Cab 4X4 CTD
"It's five o'clock somewhere...."
