Gonecamping444
MI
Have orignal batteries in truck,Thinking about replacing them before they go dead on me,How many years can you expect to get out of them?My truck does sit in the garage most of the winter since i've had it.Thanks
samsphones
north carolina
I had to replace mine in November so you are getting close.
2006 Chevy 3500 4x4 Duramax/Allison transmission
2011 Open Range Roamer 287RLS
Prodigy Brake Controller
B&W Companion 5th Wheel Hitch
Turtle n Peeps
California
I have an 06 LBZ with org batteries. I keep them until they won't crank or get low and then use them for other things until they are dead, dead, dead.
~ Too many freaks & not enough circuses ~
"Life is not tried ~ it is merely survived ~ if you're standing
outside the fire"
Gonecamping444
MI
Peeps,That sounds good but while on the road this summer i wouldn't want them to go dead on me somewhere,Don't really want to spend the money either,LOL,Thanks
donn0128
Pronounced Ore-gun
The only way to determine a batteries true condition is to have them load tested.
A battery specialty shop will test them for you for free.
Donn,Lorri,Max (rescued Lab)
Bigfoot affair
YYC
I replaced my original batteries in my Dmax after 7 years. I wasn't having any problems, but didn't want any either.
romore
Canada
Sigh, I really should replace the ones in our 05 Ram diesel before they let me down at a bad time but don't want the expense right now. They are Mopars so likely original.
downtheroad
Pacific Northwest
Turtle n Peeps wrote: I have an 06 LBZ with org batteries. I keep them until they won't crank or get low and then use them for other things until they are dead, dead, dead.
Same here...06 D/A with original batts.
I'm going to have them load tested before I head out again in the spring.
GMC Duramax/Allison (LBZ)
Reese Dual Cam HP
48ford
Parksville,BC/Qualicum Bay,BC
05 D/A still on original batteries.
2005 GMC Sierra 2500HD EC/SB 4x4 Duramax/Allison Onyx Black
DeeZee SS Nerf Bars Line X
2006 Open Road 349RL3S-5
Bob/Olallawa
Kitsap Co, WA
Usually the batteries will give you a bit of warning before dying completely. I would run them until they start acting up and then replace them. Most anywhere you travel will have them for sale at almost the same price range you have local. Normally they start showing weakness in the winter months but work a lot better during the warmer months. If you get past this winter and want to replace them, wait until fall unless they start to give up before then.
Lord, grant me the serenity to accept the things I cannot change, the courage to change the things I can, and the wisdom to hide the bodies of those people I had to kill because they pissed me off.
