Woodalls Open Roads Forum: Tow Vehicles: 2007 Chevy Silverado,Diesel
Search only in Tow Vehicles
 > 2007 Chevy Silverado,Diesel
taviking22
Omaha, NE
Posted: 02/09/12 09:43pm Link  |  Quote  |  Print  |  Notify Moderator
downtheroad wrote:
Turtle n Peeps wrote:
I have an 06 LBZ with org batteries.
Same here...06 D/A with original batts.
Same here!! Or ditto...or X 2...or is it X 3 or 4??
taviking22
Omaha, NE
'06 2500HD Silverado 4X4, Duramax Diesel, Firestone air bags
2008 Tracker Pro Guide V-16 Boat
2012 Jayco Pinnacle 31RLTS
christopherglenn
a little over an hour from Yosemite
Posted: 02/09/12 10:57pm Link  |  Quote  |  Print  |  Notify Moderator
My classic is on the original batts, If you are starting it daily in the cold you will be needing batteries sooner then later. Mine are fine now - I assume next winter may be another story. As the battery temp drops, the amp hours drop also. At some point there isn't enough power to run the glow plugs, grid heater, and starter at the same time.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine
2008 Chevrolet 2500 CC/SB Duramax 4X4 Hers
2011 Keystone Fuzion 405
2005 Chevrolet 2500 CC/SB Duramax 4X4 Hers (sold)
2006 Jayco Jay Flight 31BHS (sold)
racer4
Upstate New York
Posted: 02/09/12 10:59pm Link  |  Quote  |  Print  |  Notify Moderator
If your Chevy or GMC is like my 2007 GMC Sierra Classic diesel, rain water drains from the windshield on top of the passenger side battery. I have seen a puddle on my passenger side battery after a rain.
Some people over at dieselplace.com replaced their batteries, then later noticed battery acid under the truck and damage to the area under the passenger side battery. It seems for the more unlucky among us, the rain water can get past the fill caps on some brands of replacement batteries and overfill the battery.
See post 16 of A tale of two batteries.
My original ACDelco batteries do not have fill caps and look the same as Deka batteries. The telltale feature is the two vent holes on the ends and the mostly flat top. Like the two Deka Ultimate batteries in the back here.
It appears from the NAPA website that their batteries currently look the same as DEKA and the same as installed originally in my truck. The pictures of the batteries at the ACDelco website are different than my oem batteries.
I have been wondering if I should replace my five year old batteries. The truck was made in October 2006 and sold 9 months later by the dealer. I wonder if sitting mostly unused for 9 months shortened their lifespan. I do not want dead batteries someplace far from a NAPA store, like the campground at Acadia National Park.
Buyer beware and good luck.
* This post was edited 02/09/12 11:09pm by racer4 *
2007 GMC Sierra Classic Duramax/Allison CC LB Kelderman Air Ride
1998 SunnyBrook 30DB
glamisorbust
Arizona
Posted: 02/09/12 11:08pm Link  |  Quote  |  Print  |  Notify Moderator
I had to replace mine this time last year in my '07 classic. They were getting weaker and weaker. The truck would still start, but noticeably slower. I had a bed side replaced(5th wheel contacted truck bed), and while at the body shop the batteries took a dump. They replaced one battery for me with a brand new interstate, and I bought another interstate so I have two new batteries! Life is good!
kaydeejay
SE Michigan, USA
Posted: 02/10/12 03:24am Link  |  Quote  |  Print  |  Notify Moderator
Original two batts in my '05. As long as I can still crank easily on one of them at a time I plan to leave them in place.
In the unlikely event they fail together and let me down, I'll "borrow" the trailer battery until I can replace them.
Keith J.
1999 Sunnybrook 27RKFS Fiver.
2005 GMC Sierra 2500HD CC/SB/DA 2WD, LBZ air cleaner, 52 gal Titan tank, Bilsteins, Line-X, Westin steps, Prodigy, Retrax cover, 16K Superglide, 5th-Airborne pin-box, Multi-vex mirrors, TST TPMS.
Turtle n Peeps
California
Posted: 02/10/12 09:22am Link  |  Quote  |  Print  |  Notify Moderator
Gonecamping444 wrote:
Peeps,That sounds good but while on the road this summer i wouldn't want them to go dead on me somewhere,Don't really want to spend the money either,LOL,Thanks
I understand and nothing wrong with that either.
One thing I did learn a few months ago was this. I have owned a load tester for many many years and have tested my batteries when they got weak.
I bought batteries for my 6.5 diesel about a year ago and it was cranking a little funny and charging a little funny so I load tested them. Good to go; or so my load tester said. Same problem. Hope I don't need a starter! 300 and something bucks!!!
I talk to a very good mechanic and he asked me if I did a specific gravity test on them? Nope I told him, no need too, I load tested them. WRONG he told me. You need to SG test them.
So I talk to another VERY good mechanic friend of mine and he told me the same thing. He went on to say he has a new fancy electronic tester that can test each cell and also tell you the exact CCA it puts out under load. He checked them and they were JUNK.
Hmmmmmmmm I like new tools!!!! I hate doing SG tests because they are so time consuming and messy. So I check out these new testers and here is what I find. Check this tester out!
Look at the ratings and see what people say about it. If you bought something like this you might save some money because it will tell you what shape your battery is in.
I don't own it but I hope to soon!!
CAUTION: Ford 6.0 Powerstroke owners don't run your batteries down to nothing like I do or you could be sorry. Doing so may fry your FICM and they are very $$$$$$$$$$$$$.
~ Too many freaks & not enough circuses ~
"Life is not tried ~ it is merely survived ~ if you're standing
outside the fire"
45Ricochet
North Idaho
Posted: 02/10/12 10:00am Link  |  Quote  |  Print  |  Notify Moderator
LOL yeah they eat batteries faster than studs
Had mine load tested last fall at Napa and they tested fine. So far so good this winter although it don't get used much in winter.
06 Dodge 3500 CC LB Laramie 4x4 Dually 5.9 Cummins 325/610 48RE Jacobs brake Smarty Jr
GVWR 12,200 Payload 4580
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C
27' Hallett 502, 500HP
bgum
South Louisiana
Posted: 02/10/12 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
We have a 06 LBZ with the batteries that came from the factory. The truck is parked when we are not camping. From time to time I put a charge on the batteries to keep them up. I plan to run them until they don't start the truck or I sell it which ever is first.
Gonecamping444
MI
Posted: 02/10/12 12:52pm Link  |  Quote  |  Print  |  Notify Moderator
From what i here i'am waiting another year before replacing the batteries,Thanks again for the info.
vietvet66-67
southeast penna.
Posted: 02/10/12 12:55pm Link  |  Quote  |  Print  |  Notify Moderator
I think its X4 for me. My SIL has a 2005 GMC and still on the original batteries.
2006 Chevy 3500 DRW LBZ/ALLY LT2 The "DREAM CATCHER"
1999 Newmar American Star Newmar Kountry Klub #19708
Curt Q20 P-2 Controller Vietnam Veteran 1966-1967
LIFE MEMBER OF THE VFW PROUD MEMBER 335 "DUALLY CLUB"
"GOD, GUTS, AND GUNS KEEP AMERICA FREE"
