Woodalls Open Roads Forum: Class A Motorhomes: Fuel Tank Leaks When Filling
 > Fuel Tank Leaks When Filling
Bordercollie
Garden Grove, CA, USA
Posted: 02/12/12 11:26am Link  |  Quote  |  Print  |  Notify Moderator
Had to order a replacement connector hose on our old rig from the Chevy dealer, t'was expensive. Was hard to get stiff old hose off and new one on due to spacing. Replacement hose material has to be compatible with gasoline.
navegator
San Diego CA.
Posted: 02/12/12 11:57am Link  |  Quote  |  Print  |  Notify Moderator
You did not mention, if the mechanic checked, and veryfied that both, the filler neck, and the tank neck, that are made of sheet metal, are completlly round, a small dent, on one of them, is all you need fron fuel to creep out, also check for small cracks where the tubes where joined and or soldered, a pin hole after the hose, is all you need to smell fuel.
Also, make shure, that the filler hose, does not have hard bends, at the tube conections, a hard bend, before the tube, will not allow the rubber, to seal correctlly when tightening the clamps.
Do not over tighten the clamps, you can actually cut the hose. Band clamps are tight, when a bit of rubber bulges out, through the band holes, sort of like a loaf on a baking pan, not to high.
Good luck Navegator
