gbsb
Mt Pleasant Texas
Bought a new 60 gallon fuel transfer tank toolbox combo going to install using a low pressure electric fuel pump to transfer fuel to main tank on truck. My truck is a GMC 3500 dually with a 8.1 gas. I get 7-8 mpg towing so the extra fuel will make for once a day fuel stops. any one looking for a nice low profile diamond plate toolbox let me know. GBSB
DrBaker
Oklahoma
Which tank did you go with?
2011 Chevy 2500HD CC/SB 4x4 Victory Red
2003 Crossroads Cruiser CF27RL
Champion Screamer, Reese 16k, and a Blue Status Symbol
roller183
Surprise,Az
I had a pump on a 60 gal unit on my first dually. Worked good so long as I "turned it off" when done. Otherwise it would overflow and dribble onto the street.I left a 15 mile trail of diesel all the way thru Phoenix to a RV park years ago, right into the parking spot ....
The next tank I bought was the 98 gal one from Northern tool. I hooked it up on gravity feed to the over flow tube on the truck tank. Works great. If i forget to turn it off, no harm, and "no trail"..LOL
eHoefler
ozark mountains
I plumbed in 2 clear glass fuel filters in line on my system. One in the suction line to the fuel pump, and one in the return line back to the transfer tank. The are mounted where I can see them in my inside rear view mirror. Top one goes to the fuel pump, if it has fuel, there is fuel still to transfer. No fuel, tank empty. Bottom one is in the return line to the transfer tank, if it has fuel in it, the main tank is full.
2010 Ram 3500, Crew Cab, Long bed, 4 x 4,Dually, Lights & Siren!
2006 40' Landmark Mt. Rushmore
gbsb
Mt Pleasant Texas
I got this one from Northern Tool. Had trouble finding one for gasoline all for diesel. This one has gasoline and DOT sticker on the tag. $699.00. I'm going to put a lighted switch on dash for on/off of fuel pump.
jimmyfred
Tx
gbsb wrote: Bought a new 60 gallon fuel transfer tank toolbox combo going to install using a low pressure electric fuel pump to transfer fuel to main tank on truck. My truck is a GMC 3500 dually with a 8.1 gas. I get 7-8 mpg towing so the extra fuel will make for once a day fuel stops. any one looking for a nice low profile diamond plate toolbox let me know. GBSB
..........Have you got a part # for that tank ? , thanks , jf
2003 Chevy 8.1 Dually 2Wdr.
1999 Travel Supreme , 33 RLSS
20K Reese , Prodigy etc.
gbsb
Mt Pleasant Texas
I do have a part number but not on me will get it and post later gbsb
roller183
Surprise,Az
go to northern tool search,put in auxillary fuel tanks/tool boxes and you will get a bunch of them.
jimmyfred
Tx
gbsb wrote: I do have a part number but not on me will get it and post later gbsb
.............Every tank I viewed on their website says basically it is not made for gasoline transfer into another vehicle ! Which means it cannot be used too transfer gas into your pickup gasoline fuel tank ! The 59 gallon Transfer Flow replacement gasoline tank for my 2003 8.1 dually is $1495 plus shipping and installation !
..............So , publish your part number cause I couldn't find one that was DOT acceptable . , jf
donpop
Derby, KS USA
When I had my 2008 Ford V10 Gas I talked to RDS and had no problem getting a new sticker for the tank I purchased. I got the 40 gal combination tank/toolbox from Northern Tool. They told me that when the new tank arrived to get the serial number from the tank and call them. I did and had a new gasoline approved sticker in three days. I used a small Holley Blue 12volt pump to transfer to my main tank. I now use the same setup with my new diesel. Talk to RDS direct and you may not have a problem getting a certification sticker. I think that it is more common that diesel users use an aux tank.
Edit: The tank did not come with a down tube that allowed me to pump gas from the top of the tank. I called RDS and they immediately made one and sent it no charge.
edited 02/12/12 06:15pm by donpop *
2012 Ford Super Duty F350 XLT CC 4x4, LB SRW, 6.7
2008 Cardinal 34QS
