Woodalls Open Roads Forum: Travel Trailers: TT GVWR
Open Roads Forum  >  Travel Trailers  >  Vintage TT's
 > TT GVWR
iiii47
NH
Posted: 02/12/12 12:03pm Link  |  Quote  |  Print  |  Notify Moderator
OK folks, another question. As I have stated before, I purchased a 1966 Skamper TT last December. I have absolutely no information on the TT. How do I find the GVWR and the GAWR. This information would be nice (necessary) to know or there is no point in weighing the rig. I would never know if I'm overweight or not.
Thanks for the help.
1966 Skamper 24 Ft
2007 Chevy Trailblazer
Old-Biscuit
Across the USA
Posted: 02/12/12 12:10pm Link  |  Quote  |  Print  |  Notify Moderator
Look for any info/data sheets inside cabinets
Look for data sticker on outside of trailer
Take VIN to RV Dealer and see if they can get info
Call Thor Industries, INC. at (937) 596-6849 (Thor acquired what was left of AMF Skamper Corp. in 1995)
On Edit: Skamper Corporation Bristol, IN 46507 (Original MFG. name/location)
Good luck.......
And this post is useless without pictures of that vintage trailer
iiii47
NH
Posted: 02/12/12 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks. I have done all of that. There is no data plate, no info in a cabinet, and I called Thor industries. All no help. There are pictures. Look on the TT forum, I posted them back in Dec.
iiii47
NH
Posted: 02/12/12 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
My mistake. The pictures are on this forum, posted last Dec.
Can-AmDuo
Maryland
Posted: 02/12/12 12:30pm Link  |  Quote  |  Print  |  Notify Moderator
You may have to determine the weight capacity of the axles. Here is some info I found online. Hope it helps.
Axle capacity
Life is partly what we make it, and partly what it is made by the friends we choose.
Ron Gratz
full time RVer
Posted: 02/12/12 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
If you can find an axle-capacity tag on the axle or can estimate the axle capacity by other means,
the trailer's GVWR will be approximately 1.15 times the axle capacity due to the fact that some of the trailer's weight is carried on the hitch ball.
Ron
iiii47
NH
Posted: 02/12/12 12:46pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks, I just fired off an email to E-Trailers.com. Hopefully I'll get a response.
handye9
Park City, IL 60085
Posted: 02/12/12 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
This link might help.
You may also find some type of data plate or stamped info (look around rear center) on the axle(s) themselves. Example: If they are 3500 lb axles, and there are two of them, your GVWR would be somewhere in 7000 lb ball park.
Unload the trailer (including propane and battery) and weigh it. This weight, subtracted from axle weight rating, will give you ball park numbers for UVW, cargo capacity, and GVWR.
If the existing tires are correct, they may also give you some clue. Note the tire size and class (C, D, E, etc), then look up that particular tire size to see what the weight rating is. Example: Class C is rated at 1800 LBS, 4 tires at 1800 lbs could put GVWR around 7200 lbs. Here again, it is only a ball park figure.
* This post was edited 02/12/12 01:03pm by handye9 *
Check out my mods
08 F250 Crewcab,4X4, SB
5.4, 4.10 gears
Flowmaster exhaust, SCT tuner
12 Flagstaff 831FKBSS (TT) and 00 Maverick 8801 (TC)
Wife and I
USN MCPO (E9) Retired (active duty 1973 - 1995)
ScottG
Bothell Wa.
Posted: 02/12/12 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
I don't think you'll find anything definitive. They just didn't normally provide that kind of info back then.
Probably your best bet would be to find an ID tag on the axles.
Scott, Grace and Wesly
H0NDA eu2000i
donn0128
Pronounced Ore-gun
If the data plate from the left front corner of the trailer is missing. Contact the manufacturer. They should be able to supply a replacement for you.
Donn,Lorri,Max (rescued Lab)
 > TT GVWR
