Woodalls Open Roads Forum: Class A Motorhomes: A & E 8500 awning question
 > A & E 8500 awning question
thunder231
Phoenix, AZ
Posted: 02/16/04 12:25am Link  |  Print  |  Notify Moderator
I am new to RVs, I aquired a 75 Dodge Superior, 25', for the most part it is in good shape, but does need a lot of little things fixed, My question is, I just brought a use A & E 8500 awning, they replace the fabric, I noticed while they were removing the old fabric that it had a 1" wide strip in the middle, it appear to be a pull down strap,.. but they didn't put one back on,... is this needed, or do you just lower the ends one at a time,... I haven't installed it on my rv yet,... but was curious, since I have never use one of these before. And info on using this type of awning would be appricated... Thanks
wtb
idaho
Posted: 02/16/04 12:30am Link  |  Print  |  Notify Moderator
yeah, you'll want them to put the pull strap back on. It's not only easier to lower the awning with it, but you'll want to hold onto it while the awning raises to keep it from slamming the side of your RV.
anconn
Qualicum Beach, B.C. Canada
Posted: 02/16/04 01:19am Link  |  Print  |  Notify Moderator
The strap is necessary, to pull down the awnig and to hold it when the awning retracts.
BigJimbo
Westminster, CO, USA
Posted: 02/16/04 09:33am Link  |  Print  |  Notify Moderator
It is absolutely essential, it would be very difficult to manually unroll the awning without it and as was mentioned before, it is used to control the rewinding of the awning. You should have an L shaped tool with an eye at the end, which is used with the strap, since the strap will most likely, be too high to reach without it.
Jim and Diana Tuttle
FMCA 353514
2004 Kountry Star 3702
2 Slides, Freightliner XC,
Cat C7 330 HP, Allison 3000
KVH Trackvision SF
2000 Grand Cherokee on a trailer
big dave
Soldotna, Alaska, USA
Posted: 02/16/04 09:51am Link  |  Print  |  Notify Moderator
The strap is easy to install as it isn't part of the fabric. The tube has three slots, the fabric slides into one, the strap in another and the third is empty. It is possible to get the strap wraped up in the fabric so that the end isn't showing.
Dave & Rose C
90 Safari Ivory 34' DP
04 Saturn VUE V6
readytoretire
League City, Texas
Posted: 02/16/04 07:53pm Link  |  Print  |  Notify Moderator
thunder231,
Yep just like big dave stated,, it is a seperate part from the fabric.
I think they cost about $7.00
If it is not there get one and get a rod for it as well.
Good Luck
Doug & Elysha & All the Boys
94 Bounder 36'P Diesel Pusher, Cummins 5.9, Osh Kosh Chassis 89'vette, 98'suburban, 04'aveo
3- Shifter Karts = 125mph Fun.:
readytoretire
League City, Texas
thunder231,
Good Luck
