Woodalls Open Roads Forum: Class A Motorhomes: OTD Awning strap replacement
 > OTD Awning strap replacement
CaptEd
Kansas
Posted: 06/04/04 02:45pm Link  |  Print  |  Notify Moderator
My strap broke on the Over The Door awning recently. I bought a replacement at Camping World ($1.27)... but the awning does not have a hole in the slot to slip it in like the Main awning does. I called Carefree for instructions on how to install one, and they said I had to take it to a dealer! Can you imagine going to a dealer to have a $1.27 item installed?
My intentions are to drill a hole in the slot on one end like the Main awning... any other suggestions?
MCDDY
Louisiana
Posted: 06/04/04 04:48pm Link  |  Print  |  Notify Moderator
CaptEd
If you'll find a way to hold the OTD awning in the toatlly extended position, I used a 5gal. bucket tied to the old strap and put water in it till it stayed in that position. Got on a ladder and used a countersink drill at the end of the slot where the strap fits into. You might also need a straight drill +- 3/8" to get a little deeper, just don't drill into the roller. Then with a needle nose plier slide the old strap to the hole and grab hold of the rubber insert and pull it out. I now have the window awning and both slide topper awnings dirlled the same way. Takes about 5 min/awning.
Dave
GEAUX TIGERS
Dave, Miss Sue & Lucy the Scotty
Big Easy Area.
FMCA 153192
00 Windsor, 40' 2 Slide, ISC 350 HP.
02 Grand Cherokee Toad. Brake Buddy, Aventa 2
