richmondnite
ottawa ontario canada
Any comments on advantages or disadvantages of towing 5er using cruise control.
1999 F250 4X2 short box
2005 Pilgrim 30ft
Turn Key
North Central Texas
Have tried it. On a "flat and level" strech, it's fine. In hilly terrain I find it tends to cause the truck to shift too low too often. This does keep the speed up but also plays havoc your milage. I find it much better in hilly terrain to control the speed myself. This way when I head into a climb I can let the truck shift down one gear. I then just let it loose a little speed and ease off the accelerator as it does. This way, I don't use as much gas and still don't lug down the engine.
Works for me and just my 2-cents. Happy Camping!
Turn Key and DW
Pepsi & Cherry, 2 Spoiled Boston Terriors
'03 Chevy 2500HD, 4X4, X-Cab, Long-Bed
'04 K-Z "Durango", 275RK ("Sunday Haus II")
Twin Kayaks, "The Ride" by Wilderness Systems
jdog
Some Place
You gotta be kidding, why would anyone do anything like that? That's nuts. You need to maintain full control of your TV and trailer while towing!!!!
krogan
Gobles, MI, USA
Use it, they would not have put it on if the transmission could not handle the cruise control.
Ken & Phyllis
Nip & Tuck (2 small dogs that look forward to the next vacation)
2004 Everest 293P
2004 Ford F350 Lariat CC 4x4 PSD
16k PullRite
Starchmill
Southern NH
We towed from NH to SD and back last May. As soon as we cleared the hilly terrain in NY, I had it on cruise the rest of the way. Sure cut down on driver fatigue and enabled me to put in a longer day on the road when we needed too. I should add that my old V8 couldn't have ever handled towing with the cruise on. I think you have to have a more than adequate TV, to tow with the luxury of cruise control on.
2 Camping Pomeranians...
PAUL3500HD
N.W.Ohio
I was never a fan of C.C. before. It seemed to be
just another gadget I didnt need.
Now I use it alot when towing. It does help with driver fatigue
and helps with fuel milage. If I am in hilly areas I wont use it But on flats I am all over it now.
2004 2500 HD Silverado EC SB 8.1 Allison Silver Birch
15K Hidden Hitch Slider
2005 K-Z Sportsmen 3052px2 Limited
Prodigy
MY PICTURES
More Pic's
3500 DUALLY CLUB MEMBER # 128
Dave Bristol
Leesburg FL
I use the cruise, like other folks have said, except in hilly stretches. It is great for keeping the speed steady, and for letting it creep up to where I might get a ticket. It is, of course, important to pay strict attention to traffic and road conditions. I find that if I keep it at a steady, reasonable speed, the fuel mileage is better. Especially if I keep it at 65mph or under.
Dave Bristol
PackerBacker
Home is Montreal Qc & Seasonal is NY Adirondacks
Quote: why would anyone do anything like that? That's nuts. You need to maintain full control of your TV and trailer while towing!!!!
That's pretty funny.
I do use cc on occassion if it is very flat, but I don't tow in overdrive with the hemi. With overdrive and cruise control it will hunt too much.
Eric
2009 Holiday Rambler Admiral 33SFS (34' 3")
2008 Jeep Liberty - North Edition (4x4 auto)
FQCC/Camping Quebec, KOA, Good Sam, Coach-Net
My Photos
MotorPsycho
Madison, Wisconsin
Overall, I'm still in the learning curve on the issue with only 2,500 miles towing a 5th wheel. However, with only partial results in my my read is that I get significantly better gas mileage towing with cruise than without. Also, using cruise is far less tireing than not.
I find that, on the average, I am far more in control of my vehicle when I am less weary than I am when I'm worn out and babysitting the gas pedal.
As others mentioned, I don't use cruise in very hilly or winding conditions. Also, on the really brutal grades, I kick off cruise control rather than allowing my truck to downshift to a gear that will run the rpms up over 3,500. It doesn't happen often, but I'm simply not in that much of a hurry.
MotorPsycho
Durango 275RK
2004 F150 5.4L FX4
TCFenton1
West Winfield, NY, USA
On the GM's with Allison transmission, when you engage tow/haul mode it also changes the cruise control characteristics, so that it will let your speed drop a bit more on a hill before forcing a downshift. I used the cruise control on my GMC diesel all the time this summer, except in very hilly terrain or on curvy roads where it wasn't safe to maintain a steady speed. But on the interstates or open stretches of highway, absolutely. I even used it sometimes when I had my F150/7700 with the 5.4L gas engine, but not nearly as much as I do now with the DMAX.
Tom
2006 Crossroads Cruiser CF28RL, Honda EU2000i generator
2004.5 GMC 2500HD X-cab 4*4 shortbox DMAX LLY/Allison
Reese 16K Slider, Line-x bedliner, TTT mirrors
