Woodalls Open Roads Forum: Fifth-Wheels: BAD Tires on the toy hauler
Search only in Fifth-Wheels
 > BAD Tires on the toy hauler
beermug
Redding, CA. USA
Posted: 12/11/04 07:44pm Link  |  Print  |  Notify Moderator
I purchased my F37, toy hauler in March of 04. The first trip was 300 miles and one tire developed a 4" split in the sidewall. Dealer said it looked like I hit a curb. I hadn't but I couldn't prove it. Purchased a new tire.
Second trip was about 1200 miles and the tires were fine but the hubs overheated badly. All four brakes were finally replaced and the lock nut backed off and the problem went away. The third trip was going to be across the U.S. After 2500 miles, I suddenly had a blowout on the left front axle. AAA came out and changed the tire but said he thought he heard a leak in the other one. At his shop, he found that the wire in the sidewalls had flexed and was cutting through the casing of the right rear tire. I bought two temp tires to get me to Charlotte N.C. where I thought I could get replacements. I finally found some Goodyears after 4 days and as the shop was replacing all four, they found that the sidewall on the inside of the fourth tire was also split approx 6" long.
If you have not inspected the original tires on your forest River trailers I would suggest doing it soon. Apparently the original Carlisles are bad. Other have had problems and the company, SO FAR,
has been good about replacing them. I have been told that Carlisle will pay my replacement tire costs as soon as I return home and they can pick them up.
As much as this trailer weighs, four cheap tires were not the right way for Forest River to go. The tires were "Shield" made in Bejing, China. Load range G was okay but the steel wore through the casing under the thread and blew.
Good Luck
Paul and Sherry
2002 F350 Dually Crew
Banks brake and exhaust
2004 Sandpiper F37 w/Gold Wing
One very old cat
You have to take your toys
chesapeakecowboy
eastern us
Posted: 12/11/04 07:57pm Link  |  Print  |  Notify Moderator
My brother had this same problem with his Salem from forest river. The first blowout, he thought he might of hit something in the road that caused the damage, but after the third blowout on the same trip, something is wrong. He too had to replace all the tires when on the road. He weighed the trailer and was nowhere close to the grosses on the trailer. He too had carlisle tires and replaced with another brand. He was able to get them to pay for the replacement tires, but never did anything about the undercarriage and skirt on the side of the trailer. Even with the new tires he still has irregular tire wear on the trailer. I told him we need to check axle alignment and for some other problem. I hope everything works out for you, and you don't have anymore problems.
2000 Ford f350,drw,7,3,4.10 gears,viper ground effects,foldacover,lund sunvisor, stull grille,custom console,onboard air,twin hadleys,air bags,Husky 16k hitch,4" exhaust,dptuner chip,autometer gauges,amsoil,open air intake,levelairs,2005 citation 32.5v
Golden_HVAC
Fulltime, CA, USA
Posted: 12/11/04 08:06pm Link  |  Print  |  Notify Moderator
You should do a 4 wheel alignment on your trailer - to make sure the axels where installed properly.
You already know the bearing lock nut was set to tight, probably not enough greese too.
Most tires reach 8 years old without ever wearing out 1/2 of their original tread, unless you tow it over 15,000 miles per year. You have something wrong with the alignment on your tires to do this many blowouts in less than 10,000 miles.
Fred.
weewee
Posted: 12/11/04 08:33pm Link  |  Print  |  Notify Moderator
Its a dam wonder someone hasn't been killed because of these junk tires that Carlisle supplies to the RV manufactures, who knows, maybe they have, and they've just kept quiet, I know one thing for sure, after all the complaints I have read from owners such as yourself, and hundreds more just like you scattered about the different RV web sites and in magazine's, and that is, when I place my order for my new Fiver in the coming weeks, I'm going to have it written in the contract, if my 5er arrives with Chinese made Carlisle tires, I will be able to refuse delivery and get a full refund, unless they replace the tires with another brand to my liking.
Chuck&Gail
In the Colorado Mountains
Posted: 12/11/04 08:47pm Link  |  Print  |  Notify Moderator
How can you tell where the tires were made? Are all Carlisle tires, in all sizes, madxe in China?
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
2010 Outback 230RS Toybox, 5390# UVW, TBD# Loaded
RVJohn
Florida
Posted: 12/11/04 09:35pm Link  |  Print  |  Notify Moderator
That my friend is the tire story from hell.Hope you have much better luck with the new rubber.I don`t think it can get any worse then your tale.Yikes!!!!!!
tow vehicle-2004.5 Dodge 3500 SLT Quad Cab 4x4-600 Cummins Turbo Diesel-4-speed automatic,48RE,short bed-SRW
Prodigy brake controllar
2001 3280RL Montana
reese 16K slider,roll&lock bed cover
Yahama EF300iSEB
Garmin 7200 GPS
5th Air Borne/sidewinder
tandrus
Phoenix, AZ
Posted: 12/13/04 12:19pm Link  |  Print  |  Notify Moderator
Had a similar problem with my F37. Tires were Trail America brand distributed by Carlisle but made in China. Carlisle wanted to replace them with Shields. I said thanks but no thanks. They ultimately paid me what they said was fair market value for replacements - 5 tires x $135/tire plus mounting and balancing. (They also paid for the repairs that resulted from the Trail America thrown tread). I went and bought a set of Goodyear G614's and have been happy with them so far.
Unfortunately (as you have already learned), there isn't much in the way of name brands that offer a G rated tire in that size. I contemplated E rated Michelin RIB XPS (which are widely acknowledged as excellent tires) but decided to stay with the G rating instead.
'02 Ford F350 CC LB SRW PSD
'04 Sierra F37SP
'06 YFZ450
'02 300EX
'03 LT80
'84 LT50
EU2000Si
taxgod4u
Bay Area, CA
Posted: 12/13/04 03:38pm Link  |  Print  |  Notify Moderator
IS there a particular lot number, name, size, or other commonality for the bad vs. acceptable CArslisles? We pick up our FR in the next week or so.
All things in moderation, except acceleration!
Zip ties, the duct tape of the new milenia!
2001 F250 Powersmoke turbo diesel, 3.73LS
Crew Cab, SRW, SB, 6 inch lift, Single 28 inch semi airhorn underneath! SCMT, A Pillar mounted, Pyro, boost and Trans gauges.
2005 Wildcat 29RLBS, Prodigy, 2 EU2000i's Draw Tite 18K Signature Series, front receiver, on board air, Airlift HD airbags
2003 Ford Explorer XLT 4X4, V8, 5sp AT, 3.73LS
2003 Ford Explorer Eddie Bower 4X4, V8 5sp AT, 3.73LS, Dual semi air horns underneath
2002 XR50, PW50
jdog
Some Place
Posted: 12/14/04 12:18pm Link  |  Print  |  Notify Moderator
All Carlisle tires have problems and are junk. These blow outs with Carlisles have been going on for years, why? You would think the trailer and tire manufacture would wise up and do something. They just don't care. I won't buy any RV with those junk tires, they are dangerous and should be outlawed!!
RedRamMan
Northeast Kansas
Posted: 12/14/04 06:43pm Link  |  Print  |  Notify Moderator
Tire Plant Codes Use the "Find" key [Ctl+F in Windows] to find a plant code on this page. Check box for "Match Whole Word Only" and type in first 2 DOT letters/numbers. Code --> Plant --> City --> State/Prov. --> Country 0A --> SIAM RUBBER LIMITED --> KRANTHUMBAN --> SAMUTSAKHON --> THAILAND 0B --> BRIDGESTONE/FIRESTONE INC. --> WILSON --> NORTH CAROLINA --> US 0C --> MICHELIN SIAM CO., LTD. --> CHONBURI --> --> THAILAND 0D --> GUIZHOU TYRE FACTORY --> GIYANG --> GUIZHOU --> CHINA 0E --> PUENTE SAN MIGUEL --> TORRELAVEGA --> --> SPAIN 0H --> TRIANGLE TIRE CO., LTD. --> WEIHAI --> --> CHINA 0J --> BEIJING TYRE FACTORY --> BEIJING --> --> CHINA 0K --> GUANGZHOU PEARL RIVER RUBBER TYRE LTD --> HUADU --> GUANGZHOU --> CHINA 0L --> MRF LIMITED REGD. OFFICE --> MADRAS --> --> INDIA 0M --> TRANSPORTATION & ENGINEERING CO. --> SMOUHA, ALEXANDRIA --> PROVINCE --> EGYPT 1A --> UNION RUBBER INDUSTRIES COMPANY, LIMITED --> TAIPEI --> TAIWAN --> CHINA 1B --> PIRELLI DE VENESUELA, C.A. --> GUACARA --> ESTADO CARABOBO --> VENEZUELA 1C --> BRIDGESTONE/FIRESTONE INC. --> OKLAHOMA CITY --> OKLAHOMA --> US 1D --> BRIDGESTONE SHIMONOSEKI PLANT --> SHIMONOSEKI --> SHI --> YAMAGUCHI --> KEN --> JAPAN 1E --> LIANOING TYRE FACTORY --> LONGCHENG DIS. CHAQ YANG --> LIAONING --> CHINA 1F --> INDUSTRIA COLOMBIANA DE LLANTAS --> --> --> COLOMBIA 1G --> HANKOOK TIRE (JIAXING) CO. LTD. --> JIAXING --> ZHEJIANG --> CHINA 1H --> COMPANIA ECUATORIANA DEL CAUCHO S.A. --> CUENCA --> ECUADOR --> 1J --> XIAMEN PETREL RUBBER CO., LTD. --> XIAMEN --> FUJIAN --> CHINA 1K --> DONG FENG TYRE FACTORY --> SHI YAN CITY --> HUBEI --> CHINA 1L --> CONTINENTAL TYRE SA (PTY) LTD --> NEW BRIGHTON WEST --> PORT ELIZABETH --> SOUTH AFRICA 1M --> SHANDONG TAISHAN TYRE FACTORY --> FEICHENG CITY --> SHANDONG PROVINCE --> CHINA 1N --> TIANJIN KINGS GLORY TIRE CO., LTD --> YANG LIU QING --> TIANJIN --> CHINA 1S --> THAI SIN RUBBER INDUSTRY LTD., PART --> KRATUMBAN --> SAMUTSAKORN --> THAILAND 1T --> THE GOODYEAR TIRE & RUBBER CO. --> PARANG MARIKINA --> METRO MANILA --> PHILIPPINES 1U --> BRIDGESTONE (TIANJIN) TIRE CO., LTD. --> BEICHEN DISTRICT --> TIANJIN --> CHINA 1V --> THAI BRIDGESTONE NONG KHAE PLANT --> AMPHUR NONG KHAE --> SARABURI --> THAILAND 1W --> GOODYEAR INDIA LTD --> WALUJ AURANGABAD --> --> INDIA 1X --> SICHUAN LION TYRE CO., LTD. --> JIANYANG --> SICHUAN --> CHINA 1Y --> SHANDONG HUATAI RUBBER CO., LTD. --> LAIWU --> SHANDONG --> CHINA 1Z --> OTANI TIRE CO, LTD. --> --> NAKORNPATHOM --> THAILAND 2A --> JIUH SHUENN ENTERPRISE CO., LTD. --> TAICHUNG --> TAIWAN --> CHINA 2B --> DEESTONE LIMITED --> OAMNOI --> SAMUTSAKOM --> THAILAND 2C --> BRIDGESTONE/FIRESTONE INC. --> MORRISON --> TENNESSEE --> US 2D --> SILVERSTONE TIRE & RUBBER COMPANY SDN BHD --> TAIPING --> PERAK --> MALAYSIA 2E --> JIANGXI TAIFENG TIRE CO., LTD --> NANCHANG --> JIANGXI PROVINCE --> CHINA 2F --> PRODUCTORA NACIONAL DE LLANTAS S.A. --> CALI --> VILLE DEL CAUCA --> --> COLOMBIA 2G --> PT MEGA RUBBER LTD SEMARANG --> SEMARANG --> JAVA --> INDONESIA 2H --> DEWAN TYRES LTD. --> MEERUT --> --> INDIA 2I --> QINDAO GLEN GROUP CO. --> SOUTH OF YANGJIAQUN --> QINGDAO, SHANDONG --> CHINA 2J --> SHANGHAI TA CHUNG HUA RUBBER FACTORY --> SHANGHAI --> --> CHINA 2K --> LIAONING LONG MARCH TYRE CO., LTD. --> CHAOYANG CITY --> LIAONING PROVINCE --> CHINA 2L --> QINDAGO TONGTAI RUBBGER FACTORY --> QINGDAO CITY --> SHANDONG PROVINCE --> CHINA 2M --> BRIDGESTONE/FIRESTONE --> BLOOMINGTON --> ILLINOIS --> US 2Q --> KENDA RUBBER INDUSTRIAL CO., LTD. --> GUANGDON --> --> CHINA 2R --> P.T. BRIDGESTONE TIRE INDONESIA KARAWANG FACTORY --> KARAWANG --> WEST JAVA --> INDONESIA 2S --> VREDESTEIN FKR (M'SIA) SDN BHD --> KLANG, SELANGOR --> --> MALAYSIA 2T --> WUXI FAR EAST TYRE CO., LTD. --> --> WUXI, JIANGSU --> CHINA 2U --> CHENG SHIN --> TOYO TIRE & RUBBER --> KUNSHAN --> JIANGSU --> CHINA 2V --> S.O.D.L. --> SAINT RIEST --> --> FRANCE 2W --> YANTAI TYRE FACTORY --> ZHAOYUAN --> SHANDONG --> CHINA 2X --> MICHELIN NORTH AMERICA, INC. --> RENO --> NEVADA --> 2Y --> YUNNAN TIRE FACTORY --> KUNMING YUNNAN PROVINCE --> --> CHINA 3A --> HUALIN RUBBER PLANT --> MUDANIJIANG --> HEILONGJIANG --> CHINA 3B --> TIANJIN/UNITED TIRE & RUBBER INTL. CO., LT --> TIANJIN --> --> CHINA 3C --> MT. VERNON PLANT OF GENERAL TIRE, INC. --> MT. VERNON --> ILLINOIS --> US 3D --> COOPER TIRE & RUBBER CO. --> ALBANY --> GEORGIA --> US 3E --> QINGDAO NO.2 RUBBER FACTORY --> QINGDAO --> --> CHINA 3F --> HEBEI TYRE FACTORY --> XINGTAI --> HEBEI PROVINCE --> CHINA 3G --> TITAN TIRE CORP. OF TEXAS --> BROWNSVILLE, --> TX --> 3H --> BIRLA TYRES --> BALASORE --> ORISSA --> INDIA 3J --> RHODEN (M) SDN BHD --> PORT KLANG, SELANGOR --> DARUL EHSAN --> MALAYSIA 3K --> MARANGONI TYRE S.P.A. --> ANAGNI --> FROSINONE --> ITALY 3L --> SIAM TYRE INDUSTRY COMPANY, LIMITED --> NONGKAE --> SARABURI --> THAILAND 3M --> BRIDGESTONE/FIRESTONE --> BLOOMINGTON --> ILLINOIS --> US 3P --> HWA FONG RUBBER (THAILAND) CO., LTD --> BANQPOO INDUSTRIAL ESTATE --> SAMUTPRAKARN --> THAILAND 3Q --> CONTINENTAL AG --> HANNOVER --> --> GERMANY 3R --> SOCIEDADE MICHELIN DE PARTICIPACOES IND. E COM. LTD. --> ITATIAIA --> RJ --> --> BRAZIL 3S --> CONTINENTAL DO BRASIL PRODUTOS AUTOMOTIVOS LTDA. --> PONTA GROSSA PR --> --> BRAZIL 3T --> PT MEGA SAFE TYRE INDUSTRY --> SALATIGA --> JAWA TENGAH --> INDONESIA 3U --> SPECIALTY TIRES OF AMERICA (TENNESSEE) INC. --> UNICOI --> TENNESSEE --> 3V --> BALKRISHNA INDUSTRIES LTD --> WALUJ --> AURANGADAD --> INDIA 3W --> SHANDONG QI XIA TIRE FACTORY --> QI XIA --> SHANDONG --> CHINA 3X --> TIANJIN TYRE & RUBBER INDUSTRY CO., LTD. --> TIANJIN --> --> CHINA 3Y --> BRIDGESTONE/FIRESTONE POLAND (FIRESTONE) --> UL. BALTYCKA 65 --> POZNAN --> 4A --> VEE RUBBER COMPANY, LIMITED --> --> --> THAILAND 4B --> GOODYEAR CANADA, INC. --> NAPANEE --> ONTARIO --> CANADA 4C --> SOUTH PACIFIC TYRES --> SOMERTON --> --> CANADA 4D --> BRIDGESTONE/FIRESTONE, INC. --> MORRISON --> TENNESSEE --> US 4E --> ANHUI KAIYUAN TIRE CO., LTD. --> HEFEI --> ANHUI --> CHINA 4F --> CIA HULERA TORNEL --> FRACC. SAN FRANCISCO CHILPAN --> TULTITLAN --> MEXICO 4H --> SOUTH CHINA TIRE & RUBBER COMPANY, LIMITED --> PANYU --> GUANGZHOU --> CHINA 4J --> SVERDLOVSK TIRE MAKING WORKS --> --> --> RUSSIA 4K --> TIANJIN TYRE MANFACTURING PLANT --> TIANJIN --> --> CHINA 4L --> CARLISLE TIRE & RUBBER CO., LTD --> BU JI TOWN --> SHENZHEN --> CHINA 4M --> MICHELIN NORTH AMERICA, INC. --> GREENVILLE --> SOUTH CAROLINA --> US 4P --> PT. SURYARAYA RUBBERINDO INDUSTRIES --> CILEUNGSI, BOGOR --> --> INDONESIA 4Q --> FABRICA URUGUAYA DE NEUMATICOS S.A. (FUNSA) --> MONTIEVIDEEO --> --> URUGUAY 4S --> BELARUS TYRE WORKS BELSHINA --> BOBRUISK --> --> BELARUS 4T --> NANJING KUMHO TIRE CO., LTD. --> NANJING --> JIANGSOO --> CHINA 4U --> YOKOHAMA TIRE PHILIPPINES INC. --> CLARK FIELD --> --> PHILIPPINES 4V --> MICHELIN GUMMIRINGAR AB --> KUNGALV --> --> SWEDEN 4W --> STIP SOCIETE TUNISIENNE DES IND. DE PNEUMATIQUES --> M'SAKEN --> SOUSSE --> TUNISIA 4X --> SUPER EAST INDUSTRIAL COMPANY, LTD. --> PEITSUN YUNG CHING HIANG --> CHANG --> HWA --> TAIWAN 4Y --> RONG CHENG RUBBER FACTORY --> RONG CHENG --> SHAN DONG --> CHINA 5A --> VEE RUBBER INTERNATIONAL COMPANY, LIMITED --> --> --> THAILAND 5C --> THE FIRESTONE TIRE & RUBBER COMPANY --> BILBAO --> --> SPAIN 5D --> BRIDGESTONE/FIRESTONE, INC. --> MORRISON --> TENNESSEE --> US 5E --> MANFACTURE FRANCAISE DES PNEUMATIQUES MICHELIN --> --> --> FRANCE 5F --> CIA HULERA TORNEL --> APARTADO POSTAL 16 --> 020 --> AZCAPOTZALCO --> MEXICO 5G --> HOC MON --> HO CHI MINH --> VIETNAM --> 5H --> DEERUBBER CO., LTD --> OAMMOL --> SAMUTSAKORN --> THAILAND 5J --> SHANGHAI DA FU RUBBER PLANT --> SHANGHAI --> --> CHINA 5K --> PT. OROBAN PERKASA --> KEDUNGWARINGIN --> BEKASI --> INDONESIA 5L --> GUILIN SOUTH RUBBER INTERN'L CORP. --> GUILIN --> GUANGXI --> CHINA 5M --> HANKOOK TIRE KUMSAN PLANT --> KUMSAN KUN --> CHUNG CHONG NAM DO --> KOREA 5P --> GOVIND RUBBER LTD. --> BHIWADI --> RAJASTHAN --> INDIA 5Q --> RONGCHENG GUOTAI TYRE CO., LTD. --> RONGCHENH SHANDONG --> --> CHINA 5R --> FALCON TYRES LTD --> MYSORE --> --> INDIA 5S --> LANYU AIRCRAFT TIRE DEVELOPMENT CO. --> GUILLIN --> GUANGXI --> CHINA 5T --> BRIDGESTONE/FIRESTONE DO BRAZIL --> SANTO ANDRE --> EST. SAO PAULO --> --> BRAZIL 5U --> JIANGSU FEICHI CO., LTD. --> YANCHENG JIANGSU --> --> CHINA 5V --> SOCIETE DE DEV MECANIQUE --> SODEMECA --> NOYELLES --> LES SECLIN --> WATTIGNIES --> FRANCE 5W --> FUJIAN PRIME LAND TYRE CO., LTD. --> HUSHI TOWN, PURTIAN CITY --> FUJIAN --> CHINA 5X --> HENAN TYRE FACTORY --> JIAOZUO, HENAN --> --> CHINA 5Y --> TIANJIN WANDA TYRE GROUP CO., LTD. --> YIXINGBU TOWN, BEICHEN DIST. --> TIANJIN --> CHINA 5Z --> REFACCIONARIA VALATI S.A. DE C.V. --> CIUDAD JUAREZ --> CHIHUAHUA --> MEXICO 649 --> GE POLYMERSHAPES --> NAZARETH --> PA --> 6A --> ROADSTONE TYRE & RUBBER COMPANY, LIMITED --> NONTABURI BANGKOK --> --> THAILAND 6B --> MT. VERNON PLANT OF GENERAL TIRE, INC. --> MT. VERNON --> ILLINOIS --> US 6C --> THE FIRESTONE TIRE & RUBBER COMPANY --> BURGOS --> --> SPAIN 6D --> HENAN TYRE PLANT --> JIAZUO --> HENA PROVINCE --> CHINA 6E --> DOUBLE HAPPINESS TYRE IND. CORP., LTD. --> TAIYUAN --> --> CHINA 6F --> CIA HULERA TORNEL --> APARTADO POSTAL 16 --> 020 --> AZCAPOTZALCO --> MEXICO 6G --> CONTINENTIAL AUTOMOTIVE PRODUCTS S.R.L. --> TIMISOARA --> --> ROMANIA 6H --> SRICHAKRA TYRES LIMITED --> MADURAI DISTRICT --> TAMILNADU --> INDIA 6I --> TAURUS AGRICULTURAL TYRES LTD. --> NYIREGYHAZA --> --> HUNGARY 6J --> BARUM TECH --> ZLIN --> --> CZECH REPUBLIC 6K --> CEAT LIMITED --> AURANGABAD --> MAHARASHTRA --> INDIA 6L --> MAGOR DE MOGAMBIQUE, SARL --> MAPUTO --> --> MOZAMBIQUE 6M --> VEE TYRE AND RUBBER CO., LTD. --> TAMBOL CHAIMONGKOL, AMPHUR MUA --> SAMUTSAKORN --> THAILAND 6Q --> SHANDONG WEIHHAI RUBBER PLANT --> WEIHAI CITY, SHANDONG --> --> CHINA 6T --> BRIDGESTONE/FIRESTONE DO BRAZIL --> SANTO ANDRE --> EST. SAO PAULO --> --> BRAZIL 6U --> SODG --> CLERMONT --> FERRAND --> --> FRANCE 6V --> INDUSTRIAS DEL NEUMATICO S.A. --> E --> 03680 ASPE (ALICANTE) --> --> SPAIN 6W --> HWA FONG RUBBER (CHINA) CO., LTD. --> CHANG SHU JIANG SU --> --> CHINA 6X --> GUANGZHOU BOLEX TYRE LTD. --> HUADA CITY --> GUANGDONG --> CHINA 6Y --> CONTINENTAL MATADOR TIRES S.R.O. --> SLOVAK REPUBLIC --> --> 7A --> KINGS TIRE INDUSTRIES CO., LTD. --> CHAUGHUA --> TAIWAN --> CHINA 7B --> BRIDGESTONE/FIRESTONE INC. --> DECATUR --> ILLINOIS --> US 7C --> THE FIRESTONE TIRE & RUBBER CO. OF NEW ZEALAND --> --> --> NEW ZEALAND 7D --> HANGZHOU GENERAL RUBBER FACTORY --> HANGZHOU --> --> CHINA 7E --> LIMA CAUCHO S.A. --> --> --> PERU 7F --> CHENG SHIN RUBBER (XIAMEN) --> XIAMEN SEZ --> --> CHINA 7G --> BRIDGESTONE FIRESTONE POLAND LTD. LIABILITY CO. BRIDGESTONE BRAND --> POZNAN --> --> POLAND 7H --> CHINA SHENYANG NO. 3 RUBBER PLANT --> SHENYANG --> LIAONING PROVINCE --> CHINA 7I --> P.T. HUNG --> A INDONESIA --> WEST JAWA --> --> INDONESIA 7J --> NORTHWEST GENERAL RUBBER FACTORY --> XIANYANG CITY --> SHAANXI --> CHINA 7K --> FRIENDSHIP RUBBER INDUSTRY (M) SDN BHD --> SELANGOR DARUL EHSAN --> --> MALAYSIA 7L --> GOODYEAR TIRE & RUBBER CO. --> SHAHEKOU DISTRICT --> --> CHINA 7M --> WOLBER S.A. --> --> --> FRANCE 7Q --> SOCIETE MICHELIN DE FABRICATION --> CLERMONT --> FERRAND --> --> FRANCE 7T --> P.T. SUMI RUBBER INDONESIA --> CIKAMPEK, JAWA BARAT --> --> INDONESIA 7V --> MICHELIN SHENYANG TIRE CO., LTD. --> SHENYANG --> LIAONING --> CHINA 7W --> RONG CHENG RONGDA RUBBER CO., LTD. --> SHANDONG --> --> CHINA 7W --> SIAMESE TYRE CO., LTD. --> MINBURI (SANSAEB) --> BANGKOK --> THAILAND 7X --> AIKEN PLANT (BRIDGESTONE) --> GRANITEVILLE --> SC --> 7Y --> KENDA RUBBER CHINA CO., LTD. --> KUNSHAN, JIANGSU --> --> CHINA 7Z --> RONG CHENG RONGDA RUBBER CO., LTD --> SHANDONG --> --> CHINA 8A --> ZAPATER DIAZ I.C.S.A. TIRE CO. --> MUNRO PROV. DE BUENOS AIRES --> --> ARGENTINA 8B --> BRIDGESTONE/FIRESTONE INC. --> DES MOINES --> IOWA --> US 8C --> FIRESTONE --> FRANCE S.A. --> --> --> FRANCE 8D --> HANGZHOU GENERAL RUBBER FACTORY --> JIANDE --> ZHEJIANG --> CHINA 8E --> NEXEN TIRE CORPORATION --> KYUNGSANGNAM --> DO --> --> SOUTH KOREA 8F --> APOLLO TYRES LTD. --> VADODARA --> GUJARAT --> INDIA 8G --> HAIKOU HAIHUA TYRE CO., LTD. --> HAIKOU --> HAINAN --> CHINA 8H --> CEAT LIMITED --> NASIK --> MAHARASHTRA --> INDIA 8J --> JIANGSU HANTA TIRE BIAS PLANT --> HUAIYIN --> JIANGSU --> CHINA 8K --> CHONGING TYRE CHEIF FACTORY --> CHONGQING --> SICHUAN --> CHINA 8L --> CARLISLE TIRE & RUBBER CO. --> POINT FORTIN --> --> TRINIDAD 8M --> DEESTONE INTERNATIONAL CO., LTD. --> NAKORNPRATOM --> --> THAILAND 8R --> QINGDAO HUAQING INDUSTRIAL GROUP INC. --> JIAONAN DEVELOPMENT ZONE --> QINGDAO, SHANDONG --> CHINA 8S --> PETLAS TIRE INDUSTRY AND TRADE CO. --> KIRSEHIR --> --> TURKEY 8T --> FIRESTONE SOUTH AFRICA (PTY) LTD. --> BRITS --> --> SOUTH AFRICA 8U --> PIRELLI PNEUMATIC SPA --> MILAN --> --> ITALY 8V --> CHINA HUHHOT RUBBER PLANT --> HUHHOT --> INNER MONGOLIA --> CHINA 8W --> YUNNAN RUBBER GROUP IMP & EXP CORP. --> XINGYING DISTRICT KUNMING --> YUNNAN --> CHINA 8X --> AILEN PLANT (FIRESTONE) --> GRANITEVILLE --> SC --> 8Y --> KENDA RUBBER (VIETNAM) CO., LTD. --> HUYEN THONG NHAT --> TINH DONG NAI --> VIETNAM 8Z --> THE YOKOHAMA RUBBER CO., LTD. ONOMICHI PLANT --> ONOMICHI --> HIROSHIMA --> JAPAN 9A --> SIEMESE RUBBER CO., LTD --> MINBURI --> BANKOK --> THAILAND 9B --> BRIDGESTONE/FIRESTONE INC. --> JOLIETTE --> QUEBEC --> CANADA 9C --> THE FIRESTONE TIRE & RUBBER COMPANY --> BARI --> --> ITALY 9D --> P.T. INDUSTRI KARET DELI --> MEDAN --> --> INDONESIA 9E --> FIVE STARS INDUSTRIAL CO., LTD --> --> --> CHINA 9F --> J.K. INDUSTRIES LTD. --> --> --> INDIA 9G --> WEIFANG YONGGU MFG. CO., LTD. --> GAOMI CITY --> SHANDONG --> CHINA 9H --> JIANG SU TYRE FACTORY --> XUZHOU --> JIANG SU PROVINCE --> CHINA 9I --> SUNTEC TYRES LIMITED --> TRICHUR --> KERALA --> INDIA 9J --> YINCHUAN CC.S.I. (GREAT WALL) RUBBER CO., LTD. --> YINCHUAN --> NINGXIA --> CHINA 9K --> RONGCHENG GUOTAI TYRE COMPANY, LIMITED --> RONG CHENG --> SHANDONG --> CHINA 9L --> MRF LIMITED REGD. OFFICE --> MADRAS --> --> INDIA 9M --> ALEXANDRIA TIRE CO., S.A.E. --> AMRIA --> ALEXANDRIA --> EGYPT 9Q --> CHANGCHUN TIRE LTD. LIABILITY CO. --> CHANGCHUN --> JILIN --> CHINA 9S --> KEE LIBERTY TIRE, INC. --> SHANDONG --> --> CHINA 9T --> CHENG SHIN --> TOYO TIRE & RUBBER --> KUNSHAN, JIANGSU --> --> CHINA 9U --> GRANDTOUR TIRE (ANHUI) CO., LTD --> HEFEI --> ANHUI --> CHINA 9V --> GENERAL TYRE EAST AFRICA, LTD. --> ARUSHA --> TANZANIA --> AFRICA 9X --> AIKEN PLANT (DAYTON) --> GRANITEVILLE --> SC --> 9Y --> LANXI FUCHUEN RUBBER CO., LTD --> LANXI --> ZHEJIANG --> CHINA A1 --> PNEUMATICS MICHELIN --> 86 --> POTIERS --> --> FRANCE A3 --> GENERAL TIRE & RUBBER CO --> MOUNT VERNON --> ILLINOIS --> US A4 --> HUNG --> A CO., LTD. --> PUSAN --> --> KOREA A5 --> T.C. DEBICA S.A. --> DEBICA --> --> POLAND A6 --> APOLLO TYRES LTD. --> COCHIN 682016 --> --> INDIA A7 --> THE BRIDGESTONE TIRE CO., LTD. --> --> --> THAILAND A8 --> P.T. BRIDGESTONE TIRE INDONESIA FACTORY --> --> --> INDONESIA A9 --> GENERAL TIRE CO --> BRYAN --> OHIO --> US AA --> TIANJIN NORMANDY RUBBER CO., LTD. --> QIAO SAN DAO --> TIANJIN --> CHINA AB --> WEIFANG RUBBER FACTORY --> WEIFANG --> SHANDONG --> CHINA AC --> GENERAL TIRE CO. --> CHARLOTTE --> NORTH CAROLINA --> US AD --> GENERAL TIRE CO. --> MAYFIELD --> KENTUCKY --> US AE --> GENERAL FABRICA ESPANOIA DEL CAUCHO S.A. --> TORRELAVEGO --> SANTANDER --> SPAIN AF --> MANUFACTURA NACIONAL DE BORRACHA S.A.R.L. --> PORTO --> --> PORTUGAL AG --> CIA HULERS TORNEL S.A. DE C.V. --> AZCAPOTZALCO --> --> MEXICO AH --> GENERAL POPO S.A. --> MEXICO CITY 17 --> --> MEXICO AI --> LONGKOU XINGLONG HICON TYRE CO. --> LONGKOU --> SHAN DONG --> CHINA AJ --> UNIROYAL TIRE COMPANY --> DETROIT --> MICHIGAN --> US AK --> UNIROYAL TIRE COMPANY --> CHICOPEE FALLS --> MASSACHUSETTS --> US AL --> UNIROYAL GOODRICH TIRE COMPANY --> EAU CLAIRE --> WISCONSIN --> US AM --> UNIROYAL TIRE COMPANY --> LOS ANGELES --> CALIFORNIA --> US AN --> UNIROYAL GOODRICH TIRE MANUFACTURING --> OPELIKA --> ALABAMA --> US AO --> WEARWELL TIRE & TUBE CO. (PVT) LTD. --> BHOPAL --> --> INDIA AP --> UNIROYAL GOODRICH TIRE MANUFACTURING --> ARDMORE --> OKLAHOMA --> US AQ --> MEIYAN TIRE CO., LTD. --> MEIXIAN, GUANGDONG --> --> CHINA AR --> O.J.S.C. ORDENS OF LENIN AND OCTOBER REVOLUTION YAROSLAVL TYRE PLANT --> YAROSLAVL --> --> RUSSIA AS --> QINGDAO QIANJIN RUBBER GROUP --> QINGDAO --> SHANDONG --> CHINA AT --> COOPER --> AVON TYRES, LTD. --> MELKSHAM --> WILTSHIRE --> ENGLAND AU --> UNIROYAL GOODRICH CANADA, INC. --> KITCHENER --> ONTARIO --> CANADA AV --> SEIBERLING TIRE & RUBBER COMPANY --> BARBERTON --> OHIO --> US AW --> SAMSON TIRE & RUBBER COMPANY, LTD. --> TEL AVIV --> --> ISRAEL AX --> PHOENIX GUMMIWERKE, A. G. --> 2000 HAMBURG 90 --> --> GERMANY AY --> SHANDONG LUHE GROUP GENERAL CO. --> ZHUCHENG --> SHANDONG --> CHINA B1 --> PNEUMATICS MICHELIN --> LA ROCHESUR --> YON --> --> FRANCE B2 --> DUNLOP MALAYSIAN INDUSTRIES BERHAD --> SELANGOR --> --> MALAYSIA B3 --> MICHELIN NORTH AMERICA (CANADA), INC. --> BRIDGEWATER --> NOVA SCOTIA --> CANADA B4 --> TAURUS HUNGARIAN RUBBER WORKS --> BUDAPEST --> --> HUNGARY B5 --> OLSZTYNSKIE ZALADY OPON SAMOCHODOWYCH --> OLSZTYN --> --> POLAND B6 --> MICHELIN NORTH AMERICA, INC. --> SPARTANBURG --> SOUTH CAROLINA --> US B7 --> MICHELIN NORTH AMERICA, INC. --> DOTHAN --> ALABAMA --> US B8 --> CIA BRASAILIERA DE PNEUMATICOS --> RIO DE JANEIRO --> --> BRAZIL B9 --> MICHELIN NORTH AMERICA, INC. --> LEXINGTON --> SOUTH CAROLINA --> US BA --> UNIROYAL GOODRICH TIRE MANUFACTURING --> AKRON --> OHIO --> US BB --> B.F. GOODRICH TIRE COMPANY --> MIAMI --> OKLAHOMA --> US BC --> B.F. GOODRICH TIRE COMPANY --> OAKS --> PENNSYLVANIA --> US BD --> B.F. GOODRICH TIRE COMPANY --> MIAMI --> OKLAHOMA --> US BE --> UNIROYAL GOODRICH TIRE MANUFACTURING --> TUSCALOOSA --> ALABAMA --> US BF --> UNIROYAL GOODRICH TIRE MANUFACTURING --> WOODBURN --> INDIANA --> US BH --> UNIROYAL GOODRICH TIRE MANUFACTURING --> KITCHENER --> ONTARIO --> CANADA BJ --> JIANGSU HANTA TIRE RADIAL PLANT --> HUAIYIN, JIANGSU --> --> CHINA BK --> B.F. GOODRICH DO BRAZIL --> ESTADO DE SAO PAULO --> CAMPINAL --> BRAZIL BL --> CORPORATION FIANCIARA DEL VALLE S.A. --> CALI --> --> COLOMBIA BM --> B.F. GOODRICH AUSTRALIA PTY., LTD. --> CAMPBELLIFIELD --> VICTORIA --> AUSTRALIA BN --> B.F. GOODRICH PHILLIPPINES, INC. --> MAKTI --> RIZAL --> PHILIPPINES BO --> GENERAL TIRE & RUBBER CO. OF MOROCCO --> CASABLANCA --> 02 --> --> MOROCCO BR --> SDF RUBBER CO., LTD. --> PUDONG --> SHANGHAI --> P. R. CHINA BT --> SEMPERIT, A.G. --> --> --> AUSTRALIA BU --> SEMPERIT IRELAND LTD. --> BALLYFERMONT --> CUBLIN --> IRELAND BV --> INTERNATIONAL RUBBER INDUSTRIES --> JEFFERSONTOWN --> KENTUCKY --> US BW --> THE GATES RUBBER COMPANY --> DENVER --> COLORADO --> US BX --> THE GATES RUBBER COMAPNY --> NASHVILLE --> TENNESSEE --> US BY --> THE GATES RUBBER COMPANY --> LITTLETON --> COLORADO --> US C1 --> MICHELIN (NIGERIA) LTD. --> PORT --> HARCOURT --> --> NIGERIA C3 --> MCCREARY TIRE & RUBBER COMPANY --> BALTIMORE --> MARYLAND --> US C4 --> DICO TIRE, INCORPORATED --> CLINTON --> TENNESSEE --> US C5 --> POZNANSKIE ZAKLADY OPON SAMOCHODOWYCH --> POZNAN --> --> POLAND C6 --> MITAS, A.S. --> PRAHA 10 --> ZAHRADNI KOMAROVOVA --> --> CZECH REPUBLIC C7 --> IRONSIDES TIRE & RUBBER CO. --> LOUISVILLE --> KENTUCKY --> US C8 --> HSIN CHU PLANT --> BRIDGESTONE --> HSIN CHU --> --> TAIWAN C9 --> SEVEN STAR RUBBER COMPANY, LIMITED --> PIN --> TOU HSIAND CHANG --> HUA --> TAIWAN CA --> THE MOHAWK RUBBER COMPANY --> AKRON --> OHIO --> US CB --> THE MOHAWK RUBBER COMPANY --> HELENA --> ARKANSAS --> US CC --> YOKOHAMA TIRE CORPORATION --> SALEM --> VIRGINIA --> US CD --> ALLIANCE TIRE & RUBBER COMPANY, LTD. --> HADERA --> --> ISRAEL CF --> TITAN TIRE CORPORATION --> DES MOINES --> IOWA --> US CH --> PIRELLI ARMSTRONG TIRE CORPORATION --> HANFORD --> CALIFORNIA --> US CJ --> INOUE RUBBER CO., LTD. --> IBI --> GUN, GIFU --> PREF. --> --> JAPAN CK --> PIRELLI ARMSTRONG TIRE CORPORATION --> MADISON --> TENNESSEE --> US CM --> CONTINENTAL AG --> HANNOVER --> --> GERMANY CN --> SICUP S.N.C. USINE CONTINENTAL --> SARREGUEMINES CEDEX --> --> FRANCE CO --> GOODYEAR LASTIKLERI TAS --> ADOPOZARI --> --> TURKEY CP --> CONTINENTAL AG WERK KORBACH --> KORBACH --> --> GERMANY CR --> QUINGDAO GUANGMING TYRES MANUF. CO., LTD. --> QINGDAO --> SHANDONG --> P.R. CHINA CT --> CONTINENTAL GUMMI --> WERKE, A.C. --> DANNENBERG --> --> GERMANY CU --> CONTINENTAL AG WERK STOECKEN --> HANNOVER --> --> GERMANY CV --> THE ARMSTRONG RUBBER COMPANY --> NATCHEZ --> MISSISSIPPI --> US CW --> THE TOYO RUBBER INDUSTRY CO, LTD. --> ITAMI --> HYOGO --> JAPAN CX --> THE TOYO RUBBER INDUSTRY CO, LTD. --> NATORI --> GU --> MIYAGI --> JAPAN CY --> MCCREARY TIRE & RUBBER COMPANY --> INDIANA --> PENNSYLVANIA --> US D1 --> VIKING ASKIM --> ASKIM --> --> NORWAY D2 --> BRIDGESTONE/FIRESTONE, INC. --> LAVERGNE --> TENNESSEE --> US D3 --> UNITED TIRE & RUBBER MANUFACTURING COMPANY --> COBOURG --> ONTARIO --> CANADA D4 --> DUNLOP INDIA, LIMITED --> WEST BENGAL --> --> INDIA D5 --> DUNLOP INDIA, LIMITED --> AMBATTUR --> MADRAS --> INDIA D6 --> BOROVO --> BOROVO --> --> YUGOSLAVIA D7 --> DUNLOP SOUTH AFRICA LIMITED --> LADYSMITH --> NATAL --> SOUTH AFRICA D8 --> DUNLOP SOUTH AFRICA LIMITED --> DURBAN --> NATAL --> SOUTH AFRICA D9 --> UNITED TIRE & RUBBER COMPANY, LIMITED --> REXDALE --> ONTARIO --> CANADA DA --> DUNLOP TIRE CORPORATION --> BUFFALO --> NEW YORK --> US DB --> DUNLOP TIRE CORPORATION --> HUNTSVILLE --> ALABAMA --> US DC --> DUNLOP TIRE CANADA, LIMITED --> WHITBY --> ONTARIO --> CANADA DD --> SP TYRES UK LIMITED --> BIRMINGHAM --> --> ENGLAND DE --> SP TYRES UK LIMITED --> --> --> ENGLAND DF --> QINGDAO NEWHAWK TIRES CO., LTD. --> JIMO QINGDAO --> SHANDONG --> CHINA DJ --> QINGDAO ANLI RUBBER CO., LTD. --> QINGDAO --> SHANDONG --> CHINA DK --> DUNLOP FRANCE S.A. --> MONTLUCON CEDEX --> --> FRANCE DL --> DUNLOP FRANCE S.A. --> AMIENS CEDEX --> --> FRANCE DM --> SP REIFENWERKE GMBH --> HANAU AM MAIN --> --> GERMANY DN --> SP REIFENWERKE GMBH --> --> --> GERMANY DP --> QINGDAO GUANGMING TYRES MANUFACTURING CO., LTD. --> QINGDAO --> SHANDONG --> CHINA DR --> WEIFANG ANTAI TYRE --> CHANGLE COUNTY, WEIFANG, --> SHANDONG --> CHINA DU --> YINCHUAN (GREAT WALL) TYRE CO., LTD. --> YINCHUAN --> NINGXIA --> CHINA DV --> N.V VEDERLANDSCH --> AMERIKAANSCHE --> ENSCHNEDE --> --> NETHERLANDS DV --> QINGDAO YELLOW SEA RUBBER CO., LTD. --> QINGDAO --> SHANDONG --> CHINA DW --> ONGLOU XINGLONG TYRE CO., LTD. --> LONGKOU --> SHANDONG --> CHINA DW --> RUBBERFABRIEK VREDESTEIN --> --> --> NETHERLANDS DX --> N.V. BATAAFSCHE RUBBER INDUSTRIE RADIUM --> MAASTRICHT --> --> NETHERLANDS DX --> QINGDAO HUAQING TYRE INDUSTRY CO., LTD. --> JIAONAN, QINGDAO --> SHANDONG --> CHINA DY --> DENMAN TIRE CORPORATION --> LEAVITTSBURG --> OHIO --> US E1 --> CHUNG HSING INDUSTRIAL CO., LTD --> TAIPEI --> TAICHUNG HSIEN --> TAIWAN E2 --> BRIDGESTONE/FIRESTONE DO BRAZIL --> AV. QUEIROZ DOS SANTOS --> SANTO ANDRE --> EST. SAO PAUL --> BRAZIL E3 --> SEIBERLING TIRE & RUBBER COMPANY --> LAVERGNE --> TENNESSEE --> US E4 --> THE FIRESTONE TIRE & RUBBER CO. OF NEW ZEALAND --> PAPANUI --> CHRIST CHURCH --> 5 --> NEW ZEALAND E5 --> FIRESTONE SOUTH AFRICA (PTY) LTD. --> PORT ELIZABETH --> --> SOUTH AFRICA E6 --> FIRESTONE --> TUNISIE S.A. --> MENZEL --> BOURGUIBA --> --> TUNISIA E7 --> FIRESTONE EAST AFRICA (1969) LIMITED --> NAIROBI --> --> KENYA E8 --> FIRESTONE GHANA LIMITED --> ACCRA --> --> GHANA E9 --> FIRESTONE SOUTH AFRICA (PTY) LIMITED --> BRITS --> --> SOUTH AFRICA EA --> METZLER, A.G. --> 8 MUNCHEN 2 --> --> WEST GERMANY EB --> METZLER, A.G. ZWEIGWERK NEUSTADT --> --> --> WEST GERMANY EC --> METZLER, A.G. --> --> --> GERMANY ED --> MICHELIN --> OKAMOTO TIRE CORPORATION --> BUNKYO --> KU --> TOKYO --> JAPAN EE --> NITTO TIRE COMPANY, LIMITED --> SAMUKAWA --> MACHI --> KANAGAWA --> KEN --> JAPAN EF --> HUGH AH TIRE COMPANY, LTD. --> --> --> KOREA EH --> BRIDGESTONE TIRE COMPANY, LIMITED --> KURUME --> FUKUOKA --> KEN --> JAPAN EJ --> BRIDGESTONE TIRE COMPANY, LTD --> TOSU --> SHI --> SAGA --> KEN --> JAPAN EK --> BRIDGESTONE TIRE COMAPNY, LIMITED --> AMAGI --> SHI --> FUKUOKA --> KEN --> JAPAN EL --> BRIDGESTONE TIRE COMPANY, LTD --> HIKONE --> SHI --> SHIGA --> KEN --> JAPAN EM --> BRIDGESTONE TIRE CO., LTD., TOKYO PLANT --> KODAIRA --> TOKYO --> JAPAN EN --> BRIDGESTONE TIRE CO., LTD --> KUROSIO --> SHI --> TOCHIGI --> KEN --> JAPAN EP --> BRIDGESTONE TIRE CO., LTD --> KUROISO --> SHI --> TOCHIGI --> KEN --> JAPAN ET --> SUMITOMO RUBBER INDUSTRIES, LIMITED --> CHUO --> KO --> KOBE --> JAPAN EU --> SUMITOMO RUBBER INDUSTRIES, LIMITED --> TOYOTA --> AICHI PREFECTURE --> JAPAN EW --> PNEUMATIQUES KLEBER, S.A. --> --> --> FRANCE EX --> PNEUMATIQUES KEBER, S.A. --> LA CHAPELLE ST LUC --> --> FRANCE EY --> PNEUMATIQUES KLEBER, S.A. --> --> --> GERMANY EYJ --> CHOICES TREAD --> COSA GRANDE --> AZ --> F0 --> FIDELITY TIRE MANFACTURING CO --> NATCHEZ --> MISSISSIPPI --> US F1 --> MICHELIN TYRE COMPANY, LIMITED --> DUNDEE --> --> SCOTLAND F2 --> C.A. FIRESTONE VENEZOLANA --> VALENCIA --> --> VENEZUELA F3 --> MANFACTURE FRANCAISE PNEUMATIQUES --> ROANNE --> --> FRANCE F4 --> CNB --> COMPANHIA NACIONAL DE BORRACHAS --> --> --> PORTUGAL F5 --> FATE S.A.I.C.I. --> BUENOS AIRES --> --> ARGENTINA F6 --> TORRELAVEGA --> TORELAVDEGA --> --> SPAIN F7 --> PUENTA SAN MIGUEL --> TORELAVEGA --> --> SPAIN F8 --> VIKRANT TYRES LIMITED --> MYSORE --> KARNATAKA --> INDIA F9 --> DUNLOP NEW ZEALAND, LIMITED --> UPPER HUTT --> --> NEW ZEALAND FA --> THE YOKOHAMA RUBBER COMPANY, LIMITED --> HIRATSUKA --> KANAGAWA --> PREF --> JAPAN FAY --> DON OLSON TIRE CENTERS --> TALLAHASSEE --> FL --> FB --> THE YOKOHAMA RUBBER COMPANY, LIMITED --> WATERI --> GUN --> MIYE --> PREF --> JAPAN FC --> THE YOKOHAMA RUBBER COMPANY, LIMITED --> --> --> JAPAN FD --> THE YOKOHAMA RUBBER CO., LTD --> --> --> JAPAN FF --> MANUFACUTRE FRANCAISE DES PNEUMATICS MICHELIN --> --> --> FRANCE FH --> MANUFACTURE FRANCAISE DES PNEUMATICS MICHELIN --> CLEMONT FERRAND --> --> FRANCE FJ --> MANUFACTURE FRANCAISE DES PNEUMATICS MICHELIN --> BOURGES --> --> FRANCE FK --> MANUFACTURE FRANCAISE DES PNEUMATICS MICHELIN --> CHOLET --> --> FRANCE FL --> MANUFACTURE FRANCAISE DES PNEUMATICS MICHELIN --> 45 --> MESMIN ORLEANS --> --> FRANCE FM --> MANUFACTURE FRANCAISE DES PNEUMATICS MICHELIN --> --> --> FRANCE FN --> MANUFACTURE FRANCAISE DES PNEUMATICS MICHELIN --> --> --> FRANCE FP --> STE. D'APPLICATIONS TECHNIQUES --> ALGIERS --> --> ALGERIA FT --> FRANK TRUCKING, INC. --> MILL CITY --> OR --> FT --> MICHELIN REIFENWERKE, A.G. --> BAD KREUZNACH --> --> GERMANY FU --> MICHELIN REIFENWERKE, A.G. --> BAMBERG --> --> GERMANY FV --> MICHELIN REIFENWERKE, A.G. --> HOMBURG --> --> GERMANY FW --> MICHELIN REIFENWERKE, A.G. --> KARLSRUHE --> --> GERMANY FX --> S.A. BELGE DU PNEUMATIQUE MICHELIN --> LEEUW --> ST. PIERRE --> ZUEN --> BELGIUM FY --> N.V. NEDERLANDSCHE BANDEN --> S'HERTOGENBOSCH --> BOIS --> LE --> DUC --> HOLLAND H0 --> THE GENERAL TYRE & RUBBER COMPANY --> KARACHI --> --> PAKISTAN H1 --> DELA S.A.F.E. NEUMATICOS MICHELIN --> VALLADOLID --> --> SPAIN H2 --> KUMBO & CO., INC. --> HWANGSAN --> GU --> KWANGJU --> KOREA H3 --> SAVA TIRES D.O.O. --> KRANJ --> --> SLOVENIA H4 --> BRIDGESTONE HOUF --> HOUFU --> SHI --> YAMAGUCHI --> KEN --> JAPAN H5 --> HUTCHINSON --> MAPA --> --> --> FRANCE H6 --> SHIN HUNG RUBBER COMPANY, LIMITED --> JINJU --> KYUNG NAM --> KOREA H7 --> LI HSIN RUBBER INDUSTRIAL CO. --> CHI --> HU --> CHANG --> HWA --> TAIWAN H9 --> REIFEN --> BERG --> CLEVISCHER RING --> --> GERMANY HA --> S.A.F.E.N.M. (MICHELIN) --> ARANDA --> --> SPAIN HB --> S.A.F.E.N.M. LASARTE (MICHELLIN) --> LASARTE --> --> SPAIN HC --> S.A.F.E.N.M. (MICHELIN) --> VITORIA --> --> SPAIN HD --> SOCIETA PER AZONI, MICHELIN ITALIANA --> CUNEO --> --> ITALY HE --> SOCIETA PER AZONI, S.P.A. (MICHELIN ITALIANA) --> MARENGO --> --> ITALY HF --> SOCIETA PER AZONI (MICHELIN ITALIANA) --> TURIN --> --> ITALY HH --> SOCIETA PER AZONI (MICHELIN ITALIANA) --> TURIN --> --> ITALY HJ --> MICHELIN TYRE COMPANY, LIMITED --> BALLYMENA --> --> IRELAND HK --> MICHELIN TYRE COMPANY, LIMITED --> BURNLEY(LANE) --> --> ENGLAND HL --> MICHELIN TYRE COMPANY, LIMITED --> BURNLEY --> --> ENGLAND HM --> MICHELIN TYRE COMPANY, LIMITED --> STOKE --> ON --> TRENT --> --> ENGLAND HN --> MICHELIN NORTH AMERICA (CANADA), INC. --> NEW GLASGOW --> NOVA SCOTIA --> CANADA HP --> MANFACTURE SAIGONNAISE DES PNEUMATIQUES MICHELIN --> SAIGON --> --> SOUTH VIETNAM HT --> CEAT, S.P.A. PNEUMATICI VIA LEONCAVALLO --> TORINO --> --> ITALY HU --> CEAT 10036 --> SETTIMO TORINESE --> --> ITALY HV --> GENTYRE S.P.A. --> --> --> ITALY HW --> BARUM CONTINENTAL --> OTROKOVICE --> --> CZECH REPUBLIC HX --> THE DAYTON TIRE & RUBBER COMPANY --> DAYTON --> OHIO --> US HY --> BRIDGESTONE/FIRESTONE INC. --> OKLAHOMA CITY --> OKLAHOMA --> US J0 --> KOREA INOCEE KASEI CO., LTD. --> MASAN --> --> KOREA J1 --> PHILLIPS PETROLEUM COMPANY --> BARTLESVILLE --> OKLAHOMA --> US J2 --> BRIDGESTONE SINGAPORE COMPANY --> JURONG TOWN --> --> SINGAPORE J3 --> MATADOR A.S. --> PUCHOV --> --> SLOVAKIA J4 --> RUBENA, N.P. --> NACHOD --> --> CZECH REPUBLIC J6 --> JAROSLAVI TIRE CO. --> JAROSLAVI --> --> J7 --> HOOSIER TIRE & RUBBER CORP. --> LAKEVILLE --> IN --> J8 --> DA CHUNG HUA RUBBER INDUSTRIAL CO --> SHANGHAI --> --> CHINA J9 --> P.T. INTIRUB --> BESAR --> JAKARTA --> INDONESIA K0 --> MICHELIN KOREA TIRE COMPANY, LIMITED --> --> --> KOREA K1 --> PHILLIPS PETROLEUM COMPANY --> STOW --> OHIO --> US K3 --> KENDA RUBBER INDUSTRIAL CO., LTD. --> YULIN --> --> TAIWAN K4 --> UNIROYAL S.A. DE C.V. --> QUERETARO --> QTO --> MEXICO K5 --> VEB REIFENKOMBINAT FURSTENWALDE --> --> --> GERMANY K9 --> TECH RUBBER C0., LTD. --> --> --> TAIWAN KM --> THE LEE TIRE & RUBBER COMPANY --> --> --> L0 --> MANUFACTURE FRANCAISE DES PNEUMATIQUES MICHELIN --> --> --> FRANCE L1 --> GOODYEAR TAIWAN LIMITED --> TAIPEI --> --> TAIWAN L2 --> WOOSUNG TIRE CORPORATION --> --> --> SOUTH KOREA L3 --> TONG SHIN CHEMICAL PRODUCTS COMPANY, LIMITED --> SEOUL --> --> KOREA L4 --> CENTRALA IND. DE PRELUCRARE CAUCIUC SI MASE PLASTI --> --> --> ROMANIA L5 --> BRISA BRIDGESTONE SABANCI --> IZMIT --> ALIKAHYA --> TURKEY L6 --> MODI RUBBER LIMITED --> --> --> INDIA L7 --> INTREPINDEREA DE ANVELOPE ZALAU --> ZALAU --> JUDETUL SALOJ --> ROMANIA L8 --> DUNLOP ZIMBABWE LIMITED --> BOMINGTON --> BULAWAYE --> ZIMBABWE L9 --> PANTHER TYRES, LIMITED --> AINTEE --> LIVERPOOL --> UNITED KINGDOM LH --> BRIDGESTONE AUSTRALIA, LIMITED --> SALISBURY --> --> AUSTRALIA LJ --> PNEU UNIROYAL ENGLEBERT S.A. --> B --> 4040 HERSTAL --> --> BELGIUM LK --> PRODUCTORS NIACIONAL DE LLANTAS S.A. --> CALI --> --> COLOMBIA LL --> SICUP S.N.C. USINE UNIROYAL --> --> --> FRANCE LM --> CONTINENTAL AG WERK AACHEN --> --> --> GERMANY LN --> UNIROYAL S.A. DE C.V. --> --> MEXICO, D.F. --> MEXICO LP --> UNIROYAL ENGLENERT TYRES LTD. --> NEWBRIDGE --> --> GREAT BRITAIN LT --> UNIROYAL ENDUSTRI TURK ANONIM SIRKETI --> ADAPAZARI --> --> TURKEY LU --> UNIROYAL, C.A. --> VALENCIA --> --> VENEZUELA LV --> GENERAL TIRE CANADA, LIMITED --> BARRIE --> ONTARIO --> CANADA LW --> TRELLEBORG UMMIFARIKS AKTIEBOLAG --> TRELLEBORG --> --> SWEDEN LX --> MITSUBUSHI BELTING LIMITED --> NAGATAKU --> KOBE --> JAPAN LY --> MITSUBISHI BELTING LIMITED --> --> --> JAPAN M1 --> GOODYEAR MAROC, S.A. --> CASABLANCA --> --> MOROCCO M3 --> MICHELIN NORTH AMERICA, INC. --> GREENVILLE --> SOUTH CAROLINA --> US M5 --> MICHELIN NORTH AMERICA (CANADA), INC. --> KENTVILLE --> NOVA SCOTIA --> CANADA M6 --> THE GOODYEAR TIRE & RUBBER COMPANY --> LAWTON --> OKLAHOMA --> US M7 --> GOODYEAR DE CHILE, S.A.I.C. --> SANTIAGO --> --> CHILE M8 --> PREMIER TYRES LIMITED --> LALAMASSERY --> KERALA STATE --> INDIA M9 --> UNIROYAL TIRE CORPORATION --> MIDDLEBURY --> CONNETICUT --> US MB --> THE GOODYEAR TIRE & RUBBER COMPANY --> AKRON --> OHIO --> US MC --> THE GOODYEAR TIRE & RUBBER COMPANY --> DANVILLE --> VIRGINIA --> US MD --> THE GOODYEAR TIRE & RUBBER COMPANY --> GADSDEN --> ALABAMA --> US MJ --> THE GOODYEAR TIRE & RUBBER COMPANY --> TOPEKA --> KANSAS --> US MK --> THE GOODYEAR TIRE & RUBBER COMPANY --> UNION CITY --> TENESSEE --> US MO --> NEUMATICOS DE CHILE S.A. --> COQUIMBO --> --> CHILE MX --> COMPANHIA GOODYEAR DO BRAZIL --> SAO PAULO --> --> BRAZIL MY --> GOODYEAR DE COLOMBIA, S.A. --> CALI --> --> COLOMBIA N1 --> MALOJA AG. PNEU --> UND GUMMIWERKE --> GELTERKINDEN --> --> SWITZERLAND N2 --> HURTUBLSE NETREAD, INCORPORATED --> TONAWANDA --> NEW YORK --> US N3 --> TOYO TIRE & RUBBER CO., LTD --> INABE --> GUN --> --> JAPAN N4 --> CENTRALA IND. DE PRELUCRARE CAUICUE SI MASE PLASTI --> JUDDETUL PRAHOVA --> SOCIALISTA --> ROMAINA N5 --> PNEUMANT --> 84 RIESA --> --> GERMANY N6 --> PNEUMANT --> --> --> GERMANY N7 --> INTREPRINDEREA DE ANVELOPE CARACAL --> --> --> ROMANIA N9 --> CIA PNEUS TROPICAL NM105 BR. 324 --> FEIRA DE SANTANA --> BAHIA --> BRAZIL NB --> THE GOODYEAR TYRE & RUBBER COMPANY --> WOLVERHAMPTON --> --> ENGLAND NC --> GOODYEAR FRANCE S.A. --> --> --> FRANCE ND --> DEUTSCHE GOODYEAR G.M.B.H. --> PHILIPSBURG BRUCHSAL --> --> GERMANY NE --> GUMMIWERKE FUIDA G.M.B.H. --> FULDA --> --> GERMANY NH --> GRAN INDUSTRIA DE NEUMATICOS --> GUATEMAL CITY --> --> GUATEMALA NJ --> GOODYEAR S.A. --> --> --> GRAND DUCHY OF LUXEMBOURG NK --> GOODYEAR INDIA LIMITED --> DISTRIC GURGAON --> HARIANA STATE --> INDIA NL --> THE GOODYEAR TIRE & RUBBER LIMITED --> BOGOR --> --> INDONESIA NO --> SOUTH PACIFIC TYRES --> WEST FOOTSCRAY --> VICTORIA --> AUSTRALIA NP --> COMPANIA HULERA GOODYEAR OXO, S.A. --> MEXICO CITY --> --> MEXICO NT --> COMPANIA GOODYEAR DEL PERU --> LIMA --> --> PERU NU --> THE GOODYEAR TIRE & RUBBER CO. OF THE PHILLIPPINES --> LAS PINAS --> RIZAL --> PHILIPPINES NW --> THE GOODYEAR TIRE & RUBBER CO. (S.A.) (PTY) LIMITE --> UITENHAGE --> --> SOUTH AFRICA NY --> GOODYEAR (THAILAND) LIMITED --> BANGKOK --> --> THAILAND P1 --> CONTINENTAL GISLAVED DAECK AB --> GISLAVED --> --> SWEDEN P3 --> SKEPPLANDA GUMMI, AB --> ALVAGEN --> --> SWEDEN P6 --> GENERAL POPO S.A. --> SAN LUIS POTOSI --> S.L.P. --> MEXICO P8 --> NO. 2 RUBBER PLANT OINGADO --> QUINGDAO --> SHANGONG --> CHINA P9 --> MRF, LIMITED PB NO.1 PONDA --> --> --> INDIA PA --> GOODYEAR LASTIKLERI TAS, PK 2 --> IZMIT --> KOCAELI --> TURKEY PB --> CA GOODYEAR DE VENEZUELA --> VALENCIA --> EDO CARABOBO --> VENEZUELA PC --> THE GOODYEAR TIRE & RUBBER COMPANY OF CANADA LTD --> MEDICINE HAT --> ALBERTA --> CANADA PD --> THE GOODYEAR TIRE & RUBBER COMPANY OF CANADA LTD --> VALLEYFIELD --> QUEBEC --> CANADA PE --> SEIBERLING RUBBER COMPANY OF CANADA --> TORONTO --> ONTARIO --> CANADA PJ --> THE KELLY --> SPRINGFIELD TIRE COMPANY --> FAYETTEVILLE --> NORTH CAROLINA --> US PK --> THE KELLY --> SPRINGFIELD TIRE COMPANY --> FREEPORT --> ILLINOIS --> US PL --> THE KELLY --> SPRINGFIELD TIRE COMPANY --> TYLER --> TEXAS --> US T1 --> HANKOOK TIRE MFG. CO., LTD. --> SEOUL --> --> KOREA T2 --> OZOS (UNIROYAL) --> OLSZTYN --> --> POLAND T3 --> DEBICKIE ZATTLDY OPON SAMOCHODOWYCH --> STOMIL --> DEVICA --> POLAND T4 --> S.A. CARIDENG (RUBBERFACTORY) --> LANAKEN --> --> BELGIUM T5 --> TIGAR --> PIROT --> --> --> YUGOSLAVIA T6 --> CIA HULERA TORNEL S.A. --> FRACCIONAMIENTO INDUSTRIAL --> SAN ANTONIO --> MEXICO T7 --> HANKOOK TIRE MFG. CO., LTD. --> MOKSANG --> DONG --> DAEDUK --> KU DAEJUN --> KOREA T8 --> GOODYEAR MALAYSIA BERHAD --> SELANGOR --> --> MALAYSIA T9 --> MRF, LTD. --> --> --> INDIA TO --> SOUTH PACIFIC TYRES --> CAMPBELIFIELD --> --> CANADA U1 --> LIEN SHIN TIRE CO., LIMITED --> TA --> TSUEN HSIANG --> CHANGHUA HSIEN --> TAIWAN U2 --> SUMITOMO RUBBER INDUSTRIES, LIMITED --> SHIRAKAWA CITY --> FUKUSHIMA PREFECTURE --> JAPAN U3 --> MILOJE ZAKIC --> --> --> YUGOSLAVIA U4 --> GEO. BYERS SONS, INC. --> COLOMBUS --> OHIO --> US U5 --> FARBENFABRIKEN BAYER GMBH --> --> --> GERMANY U6 --> PNEUMANT --> --> --> GERMANY U7 --> PNEUMANT --> --> --> GERMANY U8 --> HSIN FUNG FACTORY OF NANKANG RUBBER CO. --> TAIWAN PROVINCE --> --> CHINA U9 --> COOPER TIRE & RUBBER CO --> TUPELO --> MISSISSIPPI --> US UO --> SOUTH PACIFIC TYRES --> THOMASTOWN --> VICTORIA --> AUSTRALIA UP --> COOPER TIRE & RUBBER CO --> FINDLAY --> OHIO --> US UT --> COOPER TIRE & RUBBER CO --> TEXARKANA --> ARKANSAS --> US UU --> CARLISLE TIRE & RUBBER DIVISION --> CARLISLE --> PENNSYLVANIA --> US UV --> KZOWA RUBBER INDUSTRY CO., LTD. --> NISHINARIKU --> OSAKA --> JAPAN UW --> OKADA TIRE INDUSTRY LIMITED --> KATSUSHIKA --> KU --> TOKYO --> JAPAN UX --> FEDERAL CORPORATION --> TAIPEI --> --> TAIWAN UY --> CHENG SHIN RUBBER IND. CO. LTD. --> MECI KONG --> TEIPI --> TAIWAN V1 --> LIVINGSTON'S TIRE SHOP --> HUBBARD --> OHIO --> US V2 --> VSEOJUZNOE OJEDINENIC AVTOEXPORT --> VOLZHSK --> --> RUSSIA V3 --> TA HSIN RUBBER TIRE COMPANY, LIMITED --> TUCHEN VILLAGE --> TAIPEI HSIENG --> TAIWAN V4 --> OHTSU TIRE & RUBBER COMPANY --> MIYAKONOJO CITY --> MIYAZAKI PREFECTURE --> JAPAN V5 --> FIRESTONE EL CENTENARIO S.A. --> MEXICO CITY --> --> MEXICO V6 --> FIRESTONE CUERNAVACA --> CUERNAVACA --> --> MEXICO V7 --> VSESOJUZNOE OJEDINERIE AVTOEXPORT --> VORONEZH --> --> RUSSIA V8 --> BORAS GUMMIFABRIK AB --> BORAS --> --> SWEDEN V9 --> M & H TIRE COMPANY --> GADNER --> MASSACHUSETTS --> US VA --> BRIDGESTONE/FIRESTONE INC --> AKRON --> OHIO --> US VB --> THE FIRESTONE TIRE & RUBBER COMPANY --> AKRON --> OHIO --> US VC --> THE FIRESTONE TIRE & RUBBER COMPANY --> ALBANY --> GEORGIA --> US VD --> BRIDGESTONE/FIRESTONE INC. --> DECATUR --> ILLINOIS --> US VE --> BRIDGESTONE/FIRESTONE INC. --> DES MOINES --> IOWA --> US VF --> THE FIRESTONE TIRE & RUBBER COMPANY --> SOUTH GATE --> CALIFORNIA --> US VH --> THE FIRESTONE TIRE & RUBBER COMPANY --> MEMPHIS --> TENNESSEE --> US VL --> THE FIRESTONE TIRE & RUBBER COMPANY OF CANADA --> FAST HAMILTON --> ONTARIO --> CANADA VM --> THE FIRESTONE TIRE & RUBBER COMPANY OF CANADA --> CALGARY --> ALBERTA --> CANADA VN --> BRIDGESTONE/FIRESTONE INC. --> JOLIETE --> QUEBEC --> CANADA VO --> SOUTH PACIFIC TYRES --> UPPER HUTT --> WELLINGTON --> NEW ZEALAND VP --> THE FIRESTONE TIRE & RUBBER COMPANY --> BARI --> --> ITALY VT --> THE FIRESTONE TIRE & RUBBER COMPANY --> BILBAO --> --> SPAIN VU --> UNIVERSAL TIRE COMPANY --> LANCASTER --> PENNSYLVANIA --> US VV --> THE FIRESTONE TIRE & RUBBER COMPANY --> VISKAFORS --> --> SWEDEN VW --> OHTSU TIRE & RUBBER COMPANY, LIMITED --> IZUMI --> OHTSU CITY --> OSAKA --> JAPAN VX --> FIRESTONE TYRE & RUBBER CO --> BRENTFORD --> MIDDLESEX --> ENGLAND VY --> FIRESTONE TYRE & RUBBER CO --> DENBIGHSHIRE --> WREXHAM --> WALES W1 --> BRIDGSTONE/FIRESTONE, INCORPORATED --> LAVERGNE --> TENNESSEE --> US W2 --> BRIDGESTONE/FIRESTONE INC --> WILSON --> NORTH CAROLINA --> US W3 --> VREDESTEIN DOETINCHEM B.V. --> DOEFINEHEM --> --> NETHERLANDS W4 --> DUNLOP OLYMPIC TYRES --> SOMERTON --> VICTORIA --> AUSTRALIA W5 --> FIRESTONE DE LA ARGENTINA S.A.I.C. --> PROVINCE DE BUENOS AIRES --> --> ARGENTINA W6 --> MSF TIRE AND RUBBER, INC. --> SUCAT, MUNTINLUPA CITY --> --> PHILIPPINES W7 --> FIRESTONE PORTUGUESA, S.A.R.L. --> ALCOCHETE --> --> PORTUGAL W8 --> SIAM TYRE PHRA PRADAENG CO., LTD. --> --> --> THAILAND W9 --> INDUSTRIA DE PNEUMATICOS FIRESTONE S.A. --> RIO DE JANEIRO --> EST. DE GUANBARA --> BRAZIL WA --> FIRESTONE --> FRANCE S.A. --> BETHUNE 62 --> --> FRANCE WB --> INDUSTRIA AKRON DE COSTA RICO S.A. --> SAN JOSE --> --> COSTA RICA WC --> FIRESTONE AUSTRALIA PTY. LIMITED --> SYDNEY --> NEW SOUTH WALES --> AUSTRALIA WD --> FABRIK FUR FIRESTONE PRODUKTE A.G. --> PRATTIEN --> --> SWITZERLAND WE --> NANKUNG RUBBERTIRE CORPORATION --> WEST TAIPEI --> --> TAIWAN WF --> THE FIRESTONE TIRE & RUBBER COMPANY --> BURGOS --> --> SPAIN WH --> THE FIRESTONE TIRE & RUBBER COMAPNY --> --> --> SWEDEN WM --> DUNLOP OLYMPIC TYRES --> WEST FOOTSERAY --> VICTORIA --> AUSTRALIA WO --> INOCCE RUBBER CO., INC. --> PHATUMTANI --> --> THAILAND WT --> MADRAS RUBBER FACTORY LIMITED --> MADRAS --> --> INDIA WU --> CEAT TYRES OF INDIA LIMITED --> BHANDUP,BOMBAY --> MAHARASHTRA --> INDIA WV --> GENERAL RUBBER CORPORATION --> TAIPEI --> --> TAIWAN WW --> EUZKADI COMPANIA HULERA EUZKADI, S.A. --> MEXICO CITY --> --> MEXICO WX --> EUZKADI COMPANIA HULERA EUZKADI, S.A. --> LA PRESA --> EO DE --> MEXICO WY --> EUZKADI COMPANIA HULERA EUZKADI, S.A. --> GUADAJIARA --> JALISCO --> MEXICO X0 --> VSESOJUZNOE OJEDINENIE AVTOEXPORT --> MIZHNEKAMSK --> --> RUSSIA X1 --> TONG SHIN CHEMICAL PRODUCTS COMPANY, LIMITED --> YONGDONGPO --> KO --> SEOUL --> KOREA X2 --> HWA FONG RUBBER INDUSTRIAL CO., LTD. --> YUALIN --> --> TAIWAN X3 --> VASEOJUZNOE OJEDINERIC AVTOEXPORT --> BELAYA TSERKOV --> --> RUSSIA X4 --> PARS TYRE COMPANY --> SAVEH --> --> IRAN X5 --> J. K. INDUSTRIES LIMITED --> KANKROLI --> RAJASTHAN --> INDIA X6 --> VSESOJUZNOE OJEDINENIE AVTOEXPORT --> BOBRUYSK --> --> RUSSIA X7 --> VSESOJUZNOE OJEDINENIE AVTOEXPORT --> CHIMKENTSKY --> --> RUSSIA X8 --> DNIEPROSHINA JOIN STOCK COMPANY ("DNIEPROSHINA" JSC) --> DNEPROPETROVSK --> --> UKRAINE X9 --> VSESJUZNOE OJEDINENIE AVTOEXPORT --> MOSCOW --> --> RUSSIA XA --> INDUSTRIE PIRELLI S.P.A. --> MILAN --> --> ITALY XB --> INDUSTRIE PIRELLI A.P.A. --> TORINESE --> TORINO --> ITALY XC --> INDUSTRIE PIRELLI S.P.A. --> TIVOLI --> ROMA --> --> ITALY XD --> INDUSTRIE PIRELLI S.P.A. --> MESSINA --> --> ITALY XE --> INDUSTRIE PIRELLI S.P.A. --> FERRANDINA --> --> ITALY XF --> PRODUCTOS PIRELLI S.A. --> BARCELONA --> --> SPAIN XH --> PIRELLI HALLAS, S.A. --> PATRASSO --> --> GREECE XJ --> TURK PIRELLI LASTKLERI, S.A. --> ISTANBUL --> --> TURKEY XK --> PIRELLI, S.A. --> SAO PAULO --> --> BRAZIL XL --> PIRELLA, S.A. --> CAMPINAS --> --> BRAZIL XM --> PIRELLI COMPANIA PLATENSE DE NEUMATICOS --> MERIO --> BUENOS AIRES --> ARGENTINA XN --> PIRELLI, LIMITED --> CARLISLE --> --> ENGLAND XP --> PIRELLI, LIMITED --> --> --> ENGLAND XT --> VEITH --> PIRELLI, A.G. --> SANDBACH --> --> GERMANY XV --> DAYTON TIRE & RUBBER CO --> HAMILTON --> ONTARIO --> CANADA XW --> DAYTON TIRE & RUBBER CO --> CALGARY --> ALBERTA --> CANADA XX --> BANDAG, INCORPORATED --> MUSCATINE --> IOWA --> US XY --> DAYTON TIRE & RUBBER CO --> JOLIETTE --> QUEBEC --> CANADA Y1 --> COMPANHIA GOODYEAR DU BRAZIL --> --> --> BRAZIL Y2 --> DAYTON TIRE & RUBBER CO --> WILSON --> NORTH CAROLINA --> US Y3 --> SEIBERLING TIRE & RUBBER COMPANY --> WILSON --> NORTH CAROLINA --> US Y4 --> DAYTON TIRE & RUBBER CO --> BARBERTON --> OHIO --> US Y5 --> SHANGHAI TSEN TAI RUBBER FACTORY --> SHANGHAI --> --> CHINA Y6 --> SIME TYRES INTERNATIONAL (M) SDN BHD --> KEDAH --> --> MALAYSIA Y7 --> BRIDGESTONE/FIRESTONE, INC. --> LAVERGNE --> TENNESSEE --> US Y8 --> BOMBAY TYRES INTERNATIONAL LIMITED --> BOMBAY --> MAHARASHTRA --> INDIA Y9 --> P.T. GADJAH TUNGGUAL --> --> --> YA --> THE DAYTON TIRE & RUBBER COMPANY --> AKRON --> OHIO --> US YB --> THE DAYTON TIRE & RUBBER COMPANY --> AKRON --> OHIO --> US YC --> THE DAYTON TIRE & RUBBER COMPANY --> ALBANY --> GEORGIA --> US YD --> THE DAYTON TIRE & RUBBER COMPANY --> DECATUR --> ILLINOIS --> US YE --> THE DAYTON TIRE & RUBBER COMPANY --> DES MOINES --> IOWA --> US YF --> THE DAYTON TIRE & RUBBER COMPANY --> SOUTH GATE --> CALIFORNIA --> US YH --> THE DAYTON TIRE & RUBBER COMPANY --> MEMPHIS --> TENNESSEE --> US YJ --> THE DAYTON TIRE & RUBBER COMPANY --> POTTSTOWN --> PENNSYLVANIA --> US YK --> THE DAYTON TIRE & RUBBER COMPANY --> SALINAL --> CALIFORNIA --> US YL --> OY NOKIA A.B. --> NOKIA --> --> FINLAND YM --> SEIBERLING TIRE & RUBBER COMPANY --> AKRON --> OHIO --> US YN --> SEIBERLING TIRE & RUBBER COMPANY --> AKRON --> OHIO --> US YO --> KUMHO AND CO., INC. --> GOKSUNG --> GUN --> CHOLLA NAM --> DO --> KOREA YP --> SEIBERLING TIRE & RUBBER COMPANY --> ALBANY --> GEORGIA --> US YT --> SEIBERLING TIRE & RUBBER COMPANY --> DECATUR --> ILLINOIS --> US YU --> SEIBERLING TIRE & RUBBER COMPANY --> DES MOINES --> IOWA --> US YV --> SEIBERLING TIRE & RUBBER COMPANY --> SOUTH GATE --> CALIFORNIA --> US YW --> SEIBERLING TIRE & RUBBER COMPANY --> MEMPHIS --> TENNESSEE --> US YX --> SEIBERLING TIRE & RUBBER COMPANY --> POTTSTOWN --> PENNSYLVANIA --> US YY --> SEIBERLING TIRE & RUBBER COMPANY --> SALINAS --> CALIFORNIA --> US
2004 Red Ram SLT QC 3500 Auto CTD HO SB
2001 Cedar Creek 25RLMS 5er
