Woodalls Open Roads Forum: Dinghy Towing: Burnt smell
Search only in Dinghy Towing
 > Burnt smell
jzkbbi
Chicago
Posted: 02/20/05 04:25pm Link  |  Print  |  Notify Moderator
We took our first trip pulling the toad this weekend. When we got there, the inside of the toad has this burnt smell to it. The smell was there before starting up the toad. The longer I pulled, the worse the smell got.
It is a 2000 Kia Sportage. I put the transfer case in nuetral and the trans in nuetral.
Am I cooking some of the trans fluid? Or some diffrential fluid?
Toad drove fine after we got there.
Any ideas?
Thanks.
2004 Mandalay 40B
1994 Gulfstream Tourmaster
nelson
Clio,Mi USA
Posted: 02/20/05 04:29pm Link  |  Print  |  Notify Moderator
If you take out you Trans. dip stick and smell the fluid it should not smell burnt or be brown. Make sure your brakes are not hanging up.
old jeeper
everett,wa
Posted: 02/20/05 04:38pm Link  |  Print  |  Notify Moderator
If your pulling with a dp ,both my inlaws and mine leave asmell in are tow rigs.They have the smell for up to 2 weeks cause they tow over 2000 mi at atime
2005 Mandalay 40E /quads slides 350 cat Frieghtliner chassie,[ 98 Jeep TJ lock and loaded retired]2005 TJ Unlimited Rubicon Lock and loaded and a 2002 Durango R/T So many toys and time to play with them.
Warren&Karen
Austin, Texas
Posted: 02/20/05 04:48pm Link  |  Print  |  Notify Moderator
jzkbbi --
Just a thought -- my wrangler is towed transfer case in nuetral and auto transmission in park. Double-check Kia recommendations.
Karen and Warren
"Counting the days 'til retirement"
Sophie and Sam, our two Yorkies.
Austin, Texas is home. Also, look for us
at our getaway in Rockport, on the Texas Coast.
2003 38GH model Tiffin Phaeton
dicknellen
Northern Nevada, USA
Posted: 02/20/05 08:24pm Link  |  Print  |  Notify Moderator
Is it manual or auto transmission? Only manual can be towed 4 down without mods according to 2000 MH towing guide.
Regards,
Dick
Milo006
Farmington, NM
Posted: 02/21/05 07:14am Link  |  Print  |  Notify Moderator
The smell could be all of the road dirt, rubber etc., attached to the manifold and exhaust system during the tow. Mine usally has that burnt rubber smell for a short period after I tow it. I think that it is common with a towed vehicle.
Milo and Di
2004 Georgetown XL 370
Ford V-10
2005 Chevy Colorado 4x4 Crew Cab towed vehicle
2manytoyz
Central FL
Posted: 02/21/05 07:57am Link  |  Print  |  Notify Moderator
Have the brakes checked out. I suspect a pad might be dragging. I've seen a tow truck pull a vehicle before without releasing the parking brake. Oooh, that really has a burnt smell!
Robert
Cocoa, FL
2007 Rockwood TT 2502
Equalizer Hitch
Prodigy Brake Controller
2005 Nissan Xterra
2006 Jeep Wrangler Unlimited
Yamaha EF2400iS
http://www.2manytoyz.com/
2cyber71
Pennsylvania
Posted: 02/21/05 09:53am Link  |  Print  |  Notify Moderator
Do you use a Supplemental Braking System???...They seem to slam the brakes when they engage....On the brake buddy I suggest lower the pressure some...I lowerd mine to 45 lbs instead of the 55 lbs that brake buddy recommended.....the brakes aren't slammed as hard.
cyber
2007 Itasca Ellipse 40FD, Cummins 400 ISL
jzkbbi
Chicago
Posted: 02/21/05 11:23am Link  |  Print  |  Notify Moderator
I have not yet installed my braking system. The car is only 3000lbs. The smell was not an overheated brake smell. And I didn't leave on the parking brake either!!!
Thanks.
Houndawg
Milpitas, CA 95035
Posted: 03/05/05 08:38am Link  |  Print  |  Notify Moderator
We get the same odor. In our case it is a collection of highway that collects on the front of the toad and on the undercarriage, plus the diesel film that collects from the coach exhaust. The catalytic converters get really hot and burn off the road grime and that's most likely what you smell. I have two toads, and they both stink for about a day after towing.
 > Burnt smell
