Woodalls Open Roads Forum: Truck Campers: Call for pictures of your hitch extentions.
Search only in Truck Campers
 > Call for pictures of your hitch extentions.
gregorya
Torrance, CA, USA
Posted: 07/17/06 02:10pm Link  |  Print  |  Notify Moderator
From Brad's orignal post:
BradW wrote:
I made my own 24" extension 10 years ago.
Brad
I want to flat-tow our Jeep behind our rig. I'm going to need a roughly 30" extension to accomodate the Bigfoot. I'm assuming that in flat towing, I don't need to worry about tounge weight. I am concerned about the side-to-side play at the ball end of the towbar.
I've looked at the Tow Beast/Extention Bar on the Drawtite website, and I've heard mention that the extention is held in tension with some chains to stop the side-to-side play at the end of the extension.
Would anyone like to share pictures of this system rigged up? Drawtite's website had nothing to show, and no discussions on the subject. The installation manuals don't cover the topic, either.
I have a couple sketches of solutions using my factory hitch. I'd like to see some pictures for examples.
I am flat towing, not pulling a trailer. If I do decide to pull a trailer in the future, I will certainly upgrade the hitch.
Thanks,
Greg
"I have never been lost, but I will admit to being confused for several weeks."
Daniel Boone
2006 Silverado LT 2500HD, 4WD, CC, SB, D/A
2006 Bigfoot 25C9.4
kehale
Arizona 2011
Posted: 07/17/06 02:40pm Link  |  Print  |  Notify Moderator
I use a 42" superhitch extension.
there is no side to side play with the chain system.
I'm sure you could weld something up for any hitch, if you want.
06 Lance 1181 on a Ford (still under GVWR!)
notawordok
Polkville, NC
Posted: 07/17/06 02:55pm Link  |  Print  |  Notify Moderator
I do not hane any picks so I hope you can understand this. What we have done in the past is weld two more receivers to the reciver hitch on the truch the xtra ones were near the end. You could say that the ball mount looked like a E with the middle leg crossed like a t it served the same purpose as the chains shown above but it was used to pull 3 horse trailer with a lance TC. The left side of the leg had receiver so that diffrent drop hitches could be used.
2000 Ford F250 XLT Latiat Superduty Ext-cab longbed 4X4 7.3 POWER STROKE DIESEL
31' travel trailer
Happy Trails
NOTA
grizzly arts
on the road
Posted: 07/17/06 05:06pm Link  |  Print  |  Notify Moderator
Here is mine 24" extension 1 1/4 receivers welded to each end 1"x3/4 solid stock welded to 1 1/4 solid shank brought to middle and bolted to 2" solid extension Dan.
* This post was last edited 07/17/06 08:25pm by an administrator/moderator *   View edit history
Adacas
Abbotsford BC
Posted: 07/17/06 07:54pm Link  |  Print  |  Notify Moderator
kehale that superhitch looks impressive. Tell me whats the purpose of the dual receivers (over-under)? Just to house the twin beam or?
'05 F350 6.0L PSD DRW 4x4 LB CC
'06 AF 990
kehale
Arizona 2011
Posted: 07/17/06 07:57pm Link  |  Print  |  Notify Moderator
I believe they call it a truss arrangement. The hitch itself is very strong and with the double arrangement, I believe it to be the strongest pickup receiver hitch available. There's been some debate on what's stronger, the tow beast or superhitch, however.
Does the tow beast extension have the chain arrangement, too? For flat towing, I would think the chains would be a necessity.
Here's some more pics of the hitch itself.
http://community.webshots.com/album/547388732WOdYZr
BradW
Flat Rock, Alabama
Posted: 07/17/06 08:30pm Link  |  Print  |  Notify Moderator
I don't think there's much doubt that the Superhitch is stronger than the Tow Beast
The stock Tow Beast does not. My Tow Beast / homemade extension does have the chains/turnbuckles.
gregorya
Torrance, CA, USA
Posted: 07/17/06 09:29pm Link  |  Print  |  Notify Moderator
Thanks for the pictures and descriptions!
Brad, how do you rig the chains on your hitch? It didn't look like there were any attachment points on the hitch.
Thanks,
Greg
BradW
Flat Rock, Alabama
Posted: 07/18/06 05:00am Link  |  Print  |  Notify Moderator
I'll try to post some photos tonight.
Brad
DSeckt
Cedar Point , Northern Ohio
Posted: 07/18/06 05:55am Link  |  Print  |  Notify Moderator
My daughter welded this one up.. (35" ext) Yes she is a certified welder..
Yes we did rip off super hitch.. (but better)
06 Ford F350 Dually/ Crew/ PS / SB
Lance 820.......
