Woodalls Open Roads Forum: Snowbirds: Winterizing & Summerizing for Snowbirds
Search only in Snowbirds
Open Roads Forum  >  Snowbirds
 > Winterizing & Summerizing for Snowbirds
ka8mbkcamper
Dundee MI.
Posted: 12/21/08 02:33pm Link  |  Quote  |  Print  |  Notify Moderator
Yes you want to drain everything. You can blow out the lines under the house. I have a basement so everything drains by gravity.
Ka8mbkcamper
2000 American Tradition
Eddie Bauer Explorer Toad
Amateur Radio KA8MBK
CountryCoachrv
Niceville, Fl
Posted: 12/21/08 07:56pm Link  |  Quote  |  Print  |  Notify Moderator
I guess I have been lucky, I never winterize the house when I leave. Have an all electric house and just set the furnace at 60 degrees. We do turn our well pump off but do not drain anything. I guess the risk is that electricity would go out with a big ice storm and be off for an extended period of time.
CC Coach RVer
snowyowl.13
PEI
Posted: 09/17/09 05:17am Link  |  Quote  |  Print  |  Notify Moderator
We have been told that unless someone comes to the house daily to check on things, our insurance will not cover freezing etc. We are planning to go south this winter (Jan.,Feb., & March)but we will get a plumber to winterize the house. By doing that we should be able to turn off the furnace completely. This is how all the summer people that come here handle things and i don't see why it should be any different for a regular house.
Dan
Prince Edward Island
http://www3.islandtelecom.com/dankennedy/
thecampingman
Wilmington, OH, USA
Posted: 11/14/09 06:52am Link  |  Quote  |  Print  |  Notify Moderator
I once had a contract with Farmers Home Administration to "winterize" repo'd houses. If it froze the repair was on me.
Here's what I learned. If you get all the water out, nothing is going to freeze. The way to do that is drain everything, and blow out the lines with compressed air.
"Everything" would include ice makers, water filters water heaters, outdoor taps...everything. Compressed air needs to be regulated so you don't blow your plumbing apart. If you only drain your lines water will pool and freeze.
If you leave your heat on you're at the mercy of your heating system, utility company, maybe a low temp warning system, your neighbor, your insurance company...only one of which has to fail for it to cost you. If there's no water it ain't going to freeze!
'03 GMC 4500 Topkick with Duramax/Allison
'04 36' McKenzie Medallion triple slide
Honda Magna motorcycle mounted on the front of the truck
Snowbird W/Ohio camper dock
Coalminer UG
Grande Cache Alberta
Posted: 11/24/09 09:43am Link  |  Quote  |  Print  |  Notify Moderator
My One concern is Hot water tank.It will be turned off but what are pros and cons about draining it.
Ches and Marie
Harvard
51.37N 114.42W
Posted: 03/05/10 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
Do not leave a vacuum cleaner in any enclosed storage space because the VC may cause unwanted odors if left for extended period. Put it outside in a shed.
