Woodalls Open Roads Forum: Truck Campers: Honda Eu2000/dometic brisk air
Search only in Truck Campers
 > Honda Eu2000/dometic brisk air
Bigfootf350
Loveland, CO
Posted: 09/13/07 11:16am Link  |  Print  |  Notify Moderator
For all of you Honda owners. I have a question. I am thinking of buying a honda genny just for the silence involved. I have an onboard microlite that runs my AC just fine. After looking at the serial# on my A/C unit and looking on the web I believe it is the 7100 btu model. Will the Honda run this AC unit.
2000 Ford F350 Airlift bags overload extensions. 1999 bigfoot 3000 10.11
EricCO
Colorado
Posted: 09/13/07 11:23am Link  |  Print  |  Notify Moderator
I have a 9000 BTU unit that works great with a Honda Eu2000i. Haven't ran it in the Mountains though.
I'm also able to charge my boats 2 bank battery charger at the same time as long as the camper batter charger isn't pulling any amps. My point being, I think you'll be surprise at how much more the 2000 will run on top of your A/C.
2002 Ford F-350 CC LB PSD
2007 Travel Lite 960rx Ultra
2009 Lund 208 Pro V GL with 250 Verado
luv2skyski
Stockbridge, Georgia
Posted: 09/13/07 12:08pm Link  |  Print  |  Notify Moderator
My air conditioner is a 9000 BTU Polar Cub. When I went to go pick up the camper in Denver at the end of last year I brought my Honda 2000 just to make sure it would run the a/c and it worked just fine. Dave.
magic43
Brookhaven, Ms.
Posted: 09/13/07 11:33am Link  |  Print  |  Notify Moderator
My EU2000 runs my 9000 BTU AC with power of spare. Power to spare does NOT include the microwave, toaster oven, or hair drier.
magic43
BradW
Flat Rock, Alabama
Posted: 09/13/07 11:37am Link  |  Print  |  Notify Moderator
Our EU2000i will run our Dometic 11,500 at 800'elevation in econo mode.
Brad
Internet forums only exist to serve their members; never the other way around.
1996 Lance 500 and 2006 F-350 PSD 4X4 DRW
Our Truck Camper Photos........Visit the RV.net Blogs
racechaser1
Westchester County, NY
Posted: 09/13/07 12:30pm Link  |  Print  |  Notify Moderator
My (2) Honda EU 2000i's run my 13.5k A/C in econo mode and steps up to higher RPM when I also add in the microwave. More than enough with both running in combo.
John and Lucy
07.5 Silverado LTZ CC SB D/A
07 Cedar Creek 34 SATS 5th wheel
Pullrite Super Glide 16k
Air-Ride, Mor-Ryde Pin Box
(2) Honda EU 2000i Generators
Xantrex Inverter
Pictures of 2500 HD and Cedar Creek here
Left_coast*9
Bonney Lake, WA
Posted: 09/13/07 12:41pm Link  |  Print  |  Notify Moderator
I have the 7100 Doemtic Brisk Air on my EC 950, and my Honda 2000 runs it in econo mode. I usually turn the AC unit on w/the Honda in regular mode, wait 30 seconds until after the AC compressor starts, then hit the econo mode switch on the Honda. I've tested this up to 3000 feet elevation. Happy Camping!
2006 Dodge CTD, SRW LB 4WD AT, bags, 19.5 Visions and Hankook 265s, Hellwig Rear Swaybar, Ranchos
2007 Eagle Cap 950, EU2000i, dual Trojan 6V T105s, pretty well loaded
bcbigfoot
Okanagan
Posted: 09/15/07 12:00am Link  |  Print  |  Notify Moderator
I have a 2005 Bigfoot with a Dometic 7100 Brisk Air and a eu2000 Honda and have no problems.
2002 Dodge 3500 2wd dually, cummins, 4.10 gears, 10500gvwr,
2005 Bigfoot 259.6E, 80watt solar, 7100btu aircond. 3900lb no water ready for road.
