joanne0012
Boston, MA
Pulling the valve on the black tank has gradually become a twisty gymnastic exercise, and of course I'm concerned that one of these days I won't be able to pull it at all. I can't imagine why it has gotten sticky, since it's only 14 years old. Anyway, I'd rather not replace it, so how do I get it to operate more smoothly?
Joanne
1994 Lazy Daze 23.5' TK
Dave H M
IL
Instead of messing with it, I would just replace it in a heartbet and lube the new one. You did not day if it was remote, but put some grease on the blade shaft for starters. At that age remote may need a new cable.
Twomed
On the road USA
Replace it while you have the option of an empty, clean tank.
MURPHY SAYS... it will finally break when: it's full, you have company, no place to dump, a long way from parts. Your choice
Happy Trails
06 Monaco Dynasty
Blue Ox Adventa
07 Hummer H3
FMCA 279843
mockturtle
Northwest
Granted, ours are not that old, but we find spraying them with silicone keeps them workable.
2000 Born Free 24RB Class C
2002 Honda CR-V toad
Roadmaster Sterling A/T towbar
VIP braking system
Eddyline Merlin kayak
ryanallie1
Magalia, Calif
Hi All.
Well, you have a couple of choices. Take it apart, and buy a tube of Plumbers Grease, its safe, and also can be used on any drinking water supply fittings, as it is safe for humans. It also will last you for many mnay years. I use it on our RV, and ours is 12 years old, and you only need two fingers to slide our valves. You can also, carefully drill a hole in the top and bottopn of the Blade housing, and cement in a Zert Fitting, so you can grease it, from time to time. Also, any good brand of a Dry-Lube Sprays works great also. Or you can replace it. Good Luck. Happy Camping, Dan & Jill
1997 Ford F-250, H.D. Extended-Cab, Short Bed, 7.3 PSD, K&N Air Filter, 5000 lbs air bags w/compressor w/guage, SuperChips Tuner/Programer. 1996 Nash 24fter 5er, 15K "Lil" Rocker Hitch w/BedSaver, Twin EU2000i Gen's W/Kit. Nam-Vet, 66-67-68,& 70-71
portablevcb
Tijeras, NM
Yep, I'd replace it. When we bought an older RV it had a sticky valve. I figured like Twomed. Better to do it with a clean tank, with the parts and tools at hand.
It is kinda like working on toilets. At first it seems like it will be a really messy, ucky, job. I was amazed how little mess there was once I flushed the tank good.
charlie
2006 Toyota Tundra Crew Cab
2003 Skyline Nomad 24ft Fiver
Me and Wife
Maggie the Old English Sheepdog
ArcticDodge
Sammamish, WA
I use water proof grease. The suggestions for replacement are a good option.
2009 Komfort 256TS
2001 Dodge Ram 3500 QC 4x4 Cummins DRW
2005 Dodge Durango Limited AWD HEMI
2001 Sebring Convertible
1995 Miata M-Edition
2005 DRZ400 - 2005 CRF150 - 2001 XR80
1 Wife 2 Boys
1 Trixie (Bichon Frise)
Only 26 years to retirement!!!!
C5man
West Coast
Last season I replaced both dump valves as a simple matter of preventative maintenance, even though they still worked. They are cheap and I hate nasty surprises when traveling, especially surprises of the black water variety.
SidKaye
Mt Dora Florida, Montreal QC for the Summer
Joanne, is it a cable pull valve OR is it external where you can see the whole assembly?
IF you can see it, you can lubricate it.
IF it is concealed, thetford makes a blade valve lubricant that you pour in the tank. Instructions on the container. The problem with old valves is that the blade itself can have a buildup of calcium like deposits that coat the blade creating a rough surface.
I replaced a cable actuated valve about a week ago and the blade was rough.
Sidney
2003 Dodge Ram 3500 SLT,48RE, 4:10,Cummins HO Diesel,Quad Cab,LWB,SRW,PacBrake,Prodigy, X-Monitor Gauges,Line-X,Bedsaver
2002 Excel,Ltd,30RGW,Hughes Autoformer,Honda Eu1000i, Hughes Direcway HN7000S, Satmex5,
http://www.kayepics.com
joanne0012
Boston, MA
Hi, I'm back.
It's a very simple external pull valve, I was LOL at the discussions of cables etc. Since I haven't had any hard-water issues elsewhere in the plumbing system, I guess I'll just try one of the lubricants mentioned above, and plan on buying the right replacement part in the near future.
Thanks, everyone!
