Woodalls Open Roads Forum: Class A Motorhomes: Accidentally filled gasoline in diesel tank
 > Accidentally filled gasoline in diesel tank
Page of 8
in2dp4u
USA
Posted: 06/09/08 06:11pm Link  |  Print  |  Notify Moderator
Brother in law borrowed the MH to go camping.
It had about 95 gallon of diesel in it. He stopped by his home for the night. He then decided to top it off. Instead of pouring a 5ga jerry can of diesel, he accidentally poured 5ga of gasoline in 95 gallons of diesel. He realized his mistake and called me immediately.
He mentioned he didn't start the engine. It is a Cummins ISC 330.
So what do i do? Can this be driven just fine?
Any advice??
kix
Racy Point, Florida USA
Posted: 06/09/08 06:21pm Link  |  Print  |  Notify Moderator
I would call Cummins or a diesel shop for advice. My guess and understand it's only a guess is that 5% gasoline in diesel probably would hurt the engine. but, I've been wrong before too.
KIX
'02 Winnebago Ultimate Advantage
350hp Cummins ISC
'06 Jeep Grand Cherokee Limited
5.7 L HEMI
BobMary8101
On the road again!
Posted: 06/09/08 06:23pm Link  |  Print  |  Notify Moderator
Do not start the engine, drain the tank and replace with clean diesel. Do not loan out motor home. JMHO
Bob
Bob and Mary
Isabelle, mini-daschund
Pace-Arrow Vision 36B
1999 Ford V-10 w/Banks Power Pack
Toad: 2008 Ford Focus
FMCA F398511
stevenicoldeactivate
Hillsboro, Oregon
...have you called your mechanic yet? I wouldn't drive it.
CSpenceFLY
Macon,Ga
Posted: 06/09/08 06:25pm Link  |  Print  |  Notify Moderator
I'm just guessing that it would be fine.He might drive a little while and stop and put some more diesel in. Hell, you might have the secret to better fuel mileage. I'll stand here and wait for the flames.
"You're lucky to be alive my friend."
Quote from the "Do it yourself police" and many others that have known me.
Big Katuna
Deland, FL
Send a PM to wolfe10 and wait for his response. If it were mine, I would have the tank pumped out, filters changed, tank refilled, BIL shot.
I'd talk to my sister about divorce.
My Kharma ran over my Dogma.
ottocontrol
Elburn,IL
Posted: 06/09/08 06:27pm Link  |  Print  |  Notify Moderator
Nice !!!
Ivylog
Blairsville, Ga. USA
Posted: 06/09/08 06:30pm Link  |  Print  |  Notify Moderator
If it was winter time I'd say not to worry but with the warmth of summer I'm not sure. I'd crank it up and see how it runs once the mixture gets to the engine. If it does not knock-pre detonate- I'd run it under light load and keep adding diesel as soon as possible. If you have a 55gal drum I'd fill it and top off with diesel and then use the mixture this winter.
Where am I?
How I tow.
J&R
jefferson,ga
Posted: 06/09/08 06:31pm Link  |  Print  |  Notify Moderator
You'll be fine. For many years before winterized diesel was widely available, we would mix up to 20% reg gasoline in our trucks. It would cut performance by about 20% but would keep it from gelling.
Ron & Joanne 06 Revolution LE 40E
henchman
Cardinal, Ontario
Posted: 06/09/08 06:34pm Link  |  Print  |  Notify Moderator
No problem at all. The engine can probably take up to 30% gas without any problems. At too high a level, the cetane rating drops too much and combustion happens too early. Diesel engines can run on almost anything. I run my passat diesel on straight vegetable oil, heated of course. I've run gas mixtures, kerosene, heating fuel, naptha, bio, methanol and so on.
Is the tank full now? If not, add even more diesel to further dilute the gas content, but as it stands you are at 5% or less. I would not even worry at all.
Ian
1991 Winnebago Warrior 30eu
OLD RIG
2006 Chevy Uplander 3.5l
2005 Jayco Sport 165 18' 3500lbs loaded
Putnam WD w/800lb bars
Acar friction type sway control
Hoppy digital display brake control
BALANCED tires! (Please everyone, balance your tires!)
Page of 8
